OffThePace
Michael Waterhouse
1990 Eagle Talon AWD
Wireless Motorcycle Intercom?
January 02, 2016 09:50PM
Hello,
I'm wondering if anyone has experience with the wireless intercoms made for motorcyclists like from the manufacturer Sena: http://www.sena.com/product/20s/
The Sena intercom gets decent reviews and I'm guessing the noise from a motorcycle is similar to the inside of a rally car.
What do you recommend? Price is a factor of course but I like the convenience of a wireless system. The alternative I'm considering is the Terra Trip Professional V2.
Thanks!
-Michael
Michael Waterhouse
Voorheesville NY
1990 Eagle Talon
Re: Wireless Motorcycle Intercom?
January 03, 2016 02:32AM
OffThePace
Hello,
Thanks!
-Michael
Comparisons are useless without knowing effectiveness and importantly price.
What's it cost..no obvious prices in you links and I won't waste time on moronic web-sites that don't show prices.
And Terrible Phone is called that for a reason.
So ANYTHINg is likely to be better than the Terror-phone
January 03, 2016 07:28AM
OffThePace
Hello,
Thanks!
-Michael
I was always quite happy with my Terraphone. It always worked perfectly and I never had a problem with it. Hardwired so no batteries to run out at the worst moment plus it had an actual volume knob for each headset. Why do you think the Terraphone is so bad? Personal experience?
Perry
Perry Seaman
under construction
January 03, 2016 12:12PM
I think it may work if needed, but isn't a solution I'd buy just for rally.
I have the smh10 stuff for moto use and have used the peltor intercoms in course cars. In the end the money is similar for either setup, so if you own the sena stuff already it'd be worth a try but if it's pure rally use just get a wired intercom.
I'd worry about damaging the wireless intercom on the drivers helmet inside a caged car.
The performance of both is similar although all my Sena use has been with closed face helmets, I'd bet the peltor stuff I've used is better with open face but I haven't tried it.
The battery life on the smh10 is around 12 hours of continuous use. You can charge it while using it too, which I've done on the bikes on long days.
I used to use a Peltor helmet kit wired to the ham radio directly on the course bike. Now I use a pair of SMH10s with modifications which puts the ham radio into my helmet when doing course work on the bike. you need LOTS of volume for that, and even at 80 something mph flat out on the bike I can clearly hear the rally net on both setups. I'm also half deaf for a week afterwards.. It takes about 4 to 6 watts at the speakers to do this.
The bigger issue with all these coms is the helmet, and blocking ambient noise around your ears. In a rally car I'd try the molded earplugs with buds in them hooked to whatever system you use. On the course bike I have to talk to people on the road all the time so I just crank it up, although recently I have discovered acoustic filters in hearing protection so I'll try running that with the open speakers at sandblast.
I feel like I just dumped a bunch of random info on ya, specific questions?
Perry
Perry
FE570s course bike
KTM 950 ADV
74 Beetle turbo-efi etc..
72 Beetle stage rally project WRX powered
Attended about 15 rallies, usually a volunteer in a course car.
OffThePace
Michael Waterhouse
January 03, 2016 01:39PM
Hey Perry, that was good information from someone who's actually used a Sena system. One of the interesting features that some of the Sena systems have now is an "ambient" mode that sends the ambient noise around you to the earphones so you can hear what's going on around you so you can talk with other people.
I like the idea of the molded ear buds to block out the ambient.
John, the Sena systems range from $180 for a set to $750 on Amazon depending on the model. The Sena website makes it very hard to cut through to the specs and compare models. I'm hoping other people with experience with the wireless intercoms can comment on their effectiveness. The Terra Trip systems are a great price...I'm interested to hear why you don't like them and what you suggest as an alternative. Also, how old was the system you used and what model? I like the volume limiter feature of the Professional model so you can communicate with the control people easier and not deafen the other driver.
-Michael
Michael Waterhouse
Voorheesville NY
1990 Eagle Talon
January 03, 2016 01:45PM
OffThePace
Hello,
Thanks!
-Michael
Yes.
And from experience with simple stuff that was way better...worked--ie cancelled noise--better
czwalga
steve czwalga
95 awd celica
January 03, 2016 06:59PM
OffThePace
Hello,
Thanks!
-Michael
I lost a total of 4 headsets during rallies, between my co-driver and driver. Couple that with a few broken exhausts I remember having to let off throttle just so my dad could scream some notes at me.
Terrible-phone...is right. I'm not for spending money to spend money, but the stilo intercom upgrade was very nice in the new car. First rally I had to constantly tell my dad to be quiet; normally used to yelling with the terrible phone.
BobOfTheFuture
Rob
None, anymore.
January 04, 2016 12:28AM
You can put me in as 'not a fan' of terraphone as well. With my aviation-grade hearing my volume is nearly maxed with normal rally car noises. And the big square dealie housing the 1/4 jack is begging to grab something (belts) and get torn off.
If you can get into contact with Gary D (V8 Ranger guy) he is always going on about some wireless intercom he uses.
Enablers, All of you.
January 04, 2016 03:38AM
Well, I've certainly heard people complain about Terraphone for years but like I said I never had an issue with mine. I must have bought the only good unit. It is an early unit, I bought it right after they came out so maybe that helps.
January 04, 2016 02:57PM
I reverse-engineered a Terraphone Clubman awhile back. They're ok. Could be better.
http://www.specialstage.com/forums/showthread.php?77313-Reverse-Engineered-Terraphone-Clubman-(first-Gen)
After having run two events with them last year, I was really happy to get back into cars with Peltor intercoms.
Paul Buck
Paul Buck
Volvo 242 in progress
January 04, 2016 04:23PM
I just found your schematic over there a few days ago and thanks for putting it up. I think your suggestions for filtering are spot on and i'll also bet one could find a drop in replacement (maybe) for the amp chip that puts out a bit more juice. I halfway tempted to burn a few out next time i make boards...
January 04, 2016 04:40PM
Sheesh. I just reread my post. It's pretty obvious I wrote it at 4:30am - there're all sorts of grammar mistakes.
Anyway...I don't think you'll find a drop-in replacement for the amp chip. I looked around on both Mouser and DigiKey and didn't find anything. I keep thinking I should just make a surface-mount kit that's a replacement for the original board though.
January 04, 2016 07:20PM
The word I got from a fellow who was Senior Instructor at British Telecom's Tech School in Harrogate and who made for years the superb Brantz tripmeters was "The Terror-phone is a direct copy of a very early prototype version of the excellent Greytronics intercom which was made by a friend of mine who is (was) also a Senior Instructor at Harrogate...direct right down to a fault in the filtering part of the amp circuit"...and "and it went downhill from there"..
Probably better things to reverse injur-near.
czwalga
steve czwalga
95 awd celica
January 04, 2016 07:34PM
Hard part is reverse engineering the software. Terrible trips are using off the shelf parts; I wouldn't be surprised if peltor/stilo use a PLC with custom software; even if its very generic, just so people can't buy the parts and easily reverse engineer it.
January 04, 2016 09:59PM
Well, we're talking intercoms here, and they're all just analog. Even the low-end Peltors like the FMT-100/110, both of which I took apart a few years ago because I was curious. The FMT-200 presumably has some sort of microcontroller to handle button presses and the LED's, but I haven't taken apart one.
John: If you can remember more details of what the fault was, I'd be curious to know. I only reverse-engineered it because I was fixing one for someone. I didn't see anything egregiously wrong, just a lot of "well, this could be better" stuff. The only filtering issue I see is what looks like an RC high-pass filter that should cut off anything below about 15Hz, which seems sort of useless to me.
