Rally TN?
Posted by GRMPer
GRMPer
Per Schroeder
1977 Saab 99
Rally TN?
May 20, 2008 06:53PM
Besides Anders, who else here is going to TN?
I'd prefer to be running on gravel, but at least I'm familiar with asphalt.
Per
Per
Vorpal_Rally
Stinkfinger Lipschitz
Re: Rally TN?
May 21, 2008 05:22AM
I have plans for working the event. Anyone else?
It is useless for the sheep to pass resolutions in favour of vegetarianism, while the wolf remains of a different opinion.
William Ralph Inge
TANSTAAFL
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
Re: Rally TN?
May 21, 2008 08:02AM
I will be there.
mothra
Matt Smith
xr4ti
Re: Rally TN?
May 21, 2008 12:03PM
Same here. Tires are mounted, installed, and I am ready to go. THe XR looks bad ass on fat, sticky tires.
Matt Smith
Re: Rally TN?
May 21, 2008 12:32PM
> sticky tires.
Piccies or it didn't happen!!
> Matt Smith
> Of course the car has graphics...
> We did them in satin black, flat black, and gloss
> black
Lurch
Eric Burmeister
Mazdaspeed3 and Mazda Protege
Re: Rally TN?
May 21, 2008 01:23PM
Present. Crewing.
Lurch
Eric Burmeister
The west coast...of Michigan
Re: Rally TN?
May 21, 2008 02:39PM
> Still work at Ford...for now...check back
> tomorrow.
> Not anymore. Fired.
Sorry to hear that!
Re: Rally TN?
I'll be there running the "combo" course car between the bikes and the cars. Other Colt with Stu Wood behind the wheel is competing. Hooper is in the Pacific NW.
kentmdavis
Kent Davis
1990 Eclipse GSX fwd-only
Re: Rally TN?
May 21, 2008 04:04PM
I'll be riding shotgun for my first time in the XR with Matt.
I've never really seen that car point straight for more than a few seconds.....
I may be known as Kent-the-Hurler after RTN.
Brian Johnson
Brian Johnson
Co-Driver - Old School Motorsports WRX
Re: Rally TN?
May 21, 2008 06:43PM
Co-driving for Jose Vicente in the A4.
-Brian
Vorpal_Rally
Re: Rally TN?
May 25, 2008 02:05PM
> and I
> fat,
> > sticky tires.
> > Matt Smith
> gloss
> > black
> John Vanlandingham
> Sleezattle, WA, USA
> Vive le Prole-le-ralliat
> www.jvab.f4.ca
The XR does look badass on fat sticky rubber. I saw it for the first time Friday night at the Civic Center.
Per's Saab looks awesome!!!
I rode with Darrell Pugh as fast sweep and Wow!! I know why driver's like notes.
A very fun event that was extremely low key and seemed to enjoy the support of the community. I'll say that if you're within a days drive of the event, I'd encourage you to plan on attending next year's event.
William Ralph Inge
TANSTAAFL
GRMPer
Per Schroeder
1977 Saab 99
Re: Rally TN?
May 25, 2008 08:24PM
Thanks, now if we could keep it from popping out of gear...
Per
Re: Rally TN?
May 25, 2008 08:57PM
> of gear...
Per, the gearshift console is bolted to the floor somewhere between the seats. When you wiggle the lever, the rod going plongé plongé into the växellåda pushes on shift forks and selects gears.
That's presuming everything works like its 'spossed to.
No if the gear level and the rod stay still but the motor changes its position, then its more or less equivalent to the same thing.
The motor is rocking, and pulling away from the rod, which calmly slide some shift forks over and ziiiiiiing ziiing!! Insta-neutral!
Shoot a piccie of your motor mount up front.
Post it here.
We can draw up a simple copy of what the Squareheads did might take a wee bit of welding but it is worth it.
Any links to RESULTS???????
Edited 1 time(s). Last edit at 05/25/2008 08:58PM by john vanlandingham.
WideFNopen
John Thomas
1988 Toiletta All Trash Sillycar, thanks JV for the name.
Re: Rally TN?
May 25, 2008 10:13PM
Unreal rally!
It was my 1st tarmac rally and my second total rally but I am starting to feel more comfortable going through the trees at speed.
We had some issues with a blow off valve tube popping off on a few stages but we got it fixed at the first service and pressed on. On stage five and six the car was pulling hard and felt great but the upper radiator hose was bubbleing even though it was not hot (clinderhead leak introducing air into the system?). The overflow tank was also overflowing.
Our fuel pump craped out on stage seven. We were hoping to get a tow out from the "heavy sweep" which was a 4 cylinder ranger but they declined so a guy in a Galant VR4 towed me out at speed which was pretty fun..
Dual fuel pumps on seperate switches are going in for rally WV.
John Thomas
RTN car #22
1988 St165 Alltrac
Here is a link to the results JVL:
http://www.rallytennessee.com/2008/results/
(edited 4 times because I am a fooking dummass.)
Edited 4 time(s). Last edit at 05/25/2008 10:39PM by WideFNopen.
Brian Johnson
Brian Johnson
Re: Rally TN?
May 26, 2008 05:56AM
That was too much fun (other than our agricultural expedition into the tree). Anyone who can squeeze an extra event into their budget really ought to consider this for next season. Fast flowing roads with non-stop elevation changes and crests... Can't wait to go back. And the people of Linden were amazing as well. Rally Tennessee (IMO) is a must do if it's even remotely in range.
-Brian
