Mark Mark Malsom Ultra Moderator Location: Denver, CO Join Date: 02/06/2006 Posts: 153 Rally Car: Subaru Impreza |
Took the car out to CORE yesterday with Mark and Dave and Allison Kern in their monster hill climb Evo. It was a fun day and beat the piss out of the car. Drove home on three cylinders, a problem which came up right as we were getting ready to leave. Suppose I might actually change the spark plugs. I've not even looked at them. Ever. Guessing it's that since with the BOV it has rich little moments. Though it could easily be injectors or even something worse.
But I did come upon one thing which will be an issue that I was curious as to a fix. I never had a problem with this at the rally, but as I said, I was driving like a bit of a nanny most of the time. When I'm really hammering on it I find I'll often be flat out down a long straight after some tight twisty stuff and my brake pedal is so soft I have to brake early to pump it up. I went straight off the outside of two hairpins during the course of the day because I couldn't get stopped in time. Is there anything out there that keeps the piston knock back to a minimum? Grant Hughes |
Sofa King Monika Hawkinson Elite Moderator Location: Seattle Join Date: 12/18/2005 Age: Possibly Wise Posts: 240 Rally Car: 2006 Tacoma |
------------------------------------------------------- > to pump it up. I went > straight off the outside of two hairpins during > the course of the day because I couldn't get > stopped in time. Is there anything out there that > keeps the piston knock back to a minimum? > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO Yeah. Big fresh wheelbearings, hefty flanges, secure caliper mounting. And a STIFF pedalbox. Ever heard of residual pressure valves? Monika Hawkinson Seattle, WA |
Tim Taylor Tim Taylor Godlike Moderator Location: Oakland, CA Join Date: 02/02/2007 Age: Possibly Wise Posts: 622 Rally Car: Mazda 323 GTX |
Put a light 2lb residual pressure valve in the lines to keep the pads from getting knocked back PN/260-1874
http://www.wilwood.com/Products/006-MasterCylinders/010-RPV/index.asp |
Sofa King Wrote:
------------------------------------------------------- > Yeah. Big fresh wheelbearings, hefty flanges, > secure caliper mounting. > And a STIFF pedalbox. > > Ever heard of residual pressure valves? Well, I've got new wheel bearings, a reinforced firewall for the pedal box, and secure caliper mounting. Guess I'll add in the residual pressure valve, and no, I'd never heard of them. Thanks Tim for the part number! I also need to get some shoes with better support. My foot hurts from stomping the brakes. Grant Hughes |
pikespeakgtx Michael LeCompte Mod Moderator Location: Arcata, CA (Sverdlotsk, Siberien) Join Date: 11/11/2007 Age: Midlife Crisis Posts: 714 Rally Car: Mazda GTX BPT - - - - - Not full-fledged - - - - - More like fledgling. |
Floating rotors are supposed to help the knockback issue too right?
But probably in a minor way, not so far as Grant is talkin. My SC does this sometimes. When you first hit the brakes the pedal drops a bit but subsequent braking the pedal is all the way up and firm. I'll be looking to see if this valve saves the day. Michael LeCompte Edited 1 time(s). Last edit at 09/22/2008 12:41PM by pikespeakgtx. |
Do It Sidewayz Chris Martin Mega Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
Sofa King Wrote:
> > Ever heard of residual pressure valves? > > Kevin Hawkinson > Seattle, WA > 83 Volvo 240 Gp5 (in progress) > 34-ish this may be a silly question, but can you use those on any system? aka something other than wilwood. -Mark www.nocoastmotorsports.net |
------------------------------------------------------- > Took the car out to CORE yesterday with Mark and > Dave and Allison Kern in their monster hill climb > Evo. It was a fun day and beat the piss out of > the car. Drove home on three cylinders, a problem > which came up right as we were getting ready to > leave. Suppose I might actually change the spark > plugs. I've not even looked at them. Ever. > Guessing it's that since with the BOV it has rich > little moments. Though it could easily be > injectors or even something worse. > But I did come upon one thing which will be an > issue that I was curious as to a fix. I never had > a problem with this at the rally, but as I said, I > was driving like a bit of a nanny most of the > time. When I'm really hammering on it I find I'll > often be flat out down a long straight after some > tight twisty stuff and my brake pedal is so soft I > have to brake early to pump it up. I went > straight off the outside of two hairpins during > the course of the day because I couldn't get > stopped in time. Is there anything out there that > keeps the piston knock back to a minimum? > > Grant Hughes > www.nocoastmotorsports.net > Denver, CO i got to drive the car too and it was awesome. the set up wasn't to my liking in terms of pedals and such, but it's not my car so ok. it definitely is a different driving style when really going at it. in my car (awd no fancy diffs) i expect the front to slide a lot more. in grant's, when it slides it slides straight, and when you hammer the throttle hoping to pull out of a partial spin, you just end up backwards. good times, but i think the car needs another 50-100 hp. just because. -Mark www.nocoastmotorsports.net |
Mark Wrote:
------------------------------------------------------- > Sofa King Wrote: > > > > Ever heard of residual pressure valves? > > > > Kevin Hawkinson > > Seattle, WA > > 83 Volvo 240 Gp5 (in progress) > > 34-ish > > > this may be a silly question, but can you use > those on any system? aka something other than > wilwood. Sure, everybody sells them like AP, they just cost more someplaces. > > -Mark > www.nocoastmotorsports.net > www.coloradorallycup.org Monika Hawkinson Seattle, WA |
nick leone Nick Leone Ultra Moderator Location: Westminster CO, usa Join Date: 05/14/2007 Age: Fossilized Posts: 71 Rally Car: 1982 AMC SX/4 V8 |
grant just posted this up. footage from rfkac:
http://videos.streetfire.net/video/Elkhead-Flats-on-board_186617.htm -Mark www.nocoastmotorsports.net |
