Re: Really? Buy not build?
December 23, 2008 01:24PM
I did know that. I just did not know they made pipe benders in that style. I know you can "use" crush pipe benders supposedly if you fill the tube with sand.
Looks like you've got it covered though.
As to the original buy or build question, I dont think I'll ever buy a car, unless I know who made it. Even then, I'll have to go through it and REbuild it, making sure all bolts/nuts are tight, stuff's greases, etc. I get that peace of mind knowing I built my car, and I know whats what. However, I dont EVER want to do a cage again. Pay someone to do it. Build the rest. It will be nicer, faster, and a hell of a lot better then you will your first time. Or second time. Cage builders, IMO, have an experience that you only get by building LOTS of cages. Whats that saying? "There's no substitute for practice?"
So, pay for a cage, build the rest.
December 23, 2008 01:27PM
I've used the Greenlee pipe benders from the rental stores before, too with good results. Like you say, use the 1.75" dies for 1.5" tube. However, that $4000 Greenlee pipe bender is not as easy to use and doesn't make as nice bends as my $500 JD Squared tube bender. What you have to watch out for is the pipe benders that squash the tube from the middle like this: http://toolsandmore.us/index.asp?PageAction=VIEWPROD&ProdID=1614
Those are not suitable for buildiing rollcages and will not produce a legal bend.
DR1665
Brian Driggs
Keyboard. Deal with it.
December 23, 2008 02:06PM
Do It Sidewayz Wrote:
> you do understand the only difference between a
> "pipe" and a "tube" bender is the naming
> conventions for pipe/tube size right??
I do now!
This kinda puts the kibosh on my plans to build the cage out of EMT from the electrical department at Home Depot, though. Sure we can't just use PVC and fill it with marshmallows or somethin? winking smiley
December 23, 2008 02:29PM
> a
> I do now!
> Brian DR1665 | Phoenix, AZ
> 86 245GL - daily | 91 GVR4 - rally project
fill it with solder.
DR1665
Brian Driggs
December 23, 2008 08:32PM
Nothing can stop the 9,000lb Gaylant.
hudson
Andrew McNally
December 23, 2008 11:54PM
Doivi Clarkinen Wrote:
> What you have to
I was thinking of picking one up like that fairly soon..
Good thing I read this thread!
Andrew M
Onterrible
30ish
JonArmstrong
Jon Armstrong
Rallycross Civic
December 24, 2008 07:39AM
December 24, 2008 12:58PM
JonArmstrong Wrote:
> How 'bout this type:
> Anyone know if this is a professional kinker or
> bender?
Looks kind of ghetto. Although it may produce a legal bend I would want to see an actual bend first up close. Bend circle is kind of big, too. And it doesn't look like it would that good at out of phase multiple bends (such as with side lateral bars.)
You're way better off with one of these: http://www.jd2.com/m3b.htm
It's what I've used for 18 years.
hudson
Andrew McNally
December 24, 2008 02:11PM
> bars.)
Looks nice.. and also like they make their money in the die sets.
Andrew M
Onterrible
30ish
December 24, 2008 11:55PM
> in the die sets.
Well the dies are the most important part, the rest is just thick steel plate with some holes and some bolts and pins. Try pricing some dies for a Greenlee bender!
December 25, 2008 07:22PM
bender, shmender. Just find two trees close together and...
randyzimmer
randy zimmer
rallycross 13B Miata
December 27, 2008 03:51PM
> together and...
its an hour show - the sound sync is bad
but check out Frank Sprongl bending a bar at 22:45
http://www.randyzimmer.com/video/warowheels/warowheels.avi
also somebody is sneaking a drive in a GpB Audi on rz.avi
January 01, 2009 03:03PM
Some people should not build ever because:
1) They have no clue
2) They do not learn
3) They never finish anything
4) They can not afford to build
5) They do not have space, tools, time.
Others should never buy because:
1) They are going to change everything anyway
2) They like working on on cars better then driving them
3) They want something no one else built
4) They are the types that might blame the builder for problems
5) They are anal
6) They use special math and think they can save money building.
I have done both several times but
1) I have a clue
2) I finish things and know the 7 P's
3) I am not anal
4) I can afford it
5) I know what stuff to have someone else do for me
January 01, 2009 11:08PM
> driving them
> for problems
> 5) They are anal
> money building.
> 1) I have a clue
> 3) I am not anal
> 4) I can afford it
> me
> See me go at:
> www.11tenths.com
> In the long run Reality always wins.
This should be a sticky at the top of the construction forum since it's a question that's asked perpetually.
Usually we see the oh so typical response that you NEED to decide if you're a driver or a builder. Well it's not so simple. I've had a passion for driving cars since before I could walk. I knew how to drive stick before I ever drove. BUT I want my car to be exactly the way I want it. I like to make it better, stronger, lighter, more powerful and well just MINE.
ftwelder
Frank Wadelton
likely a VW
February 07, 2009 04:22AM
actually rigid conduit is tube, not pipe. Greenlee bender is an excellent product for cages.
www.frankthewelder.com
www.sinisterbikes.com
learning the ropes by wrapping them around my neck
