March 14, 2009 04:22AM
Dazed_Driver Wrote:
> Flocking is like powder coating with glue (instead
> of heat) right? shoot a bunch of little powdered
> things at a gluey surface?
> Feisty Peacock?
Basically yeah but it's very simple. You clean the hell out of the dash with brake cleaner, Paint it with LATEX spray paint then you brush on the adhesive goop (which is colour matched to the flocking material) then you put the powdered suede in this little canister and pump away. All the suede that doesn't stick to the dash can be recovered if you put a drop cloth under the dash while you're doing it.
March 15, 2009 03:20PM
finished the 1st 'test' piece. Still have to do the lower cross-bar, but here's the top piece after I grinded down some welds to make it prettier.
JohnLane
John Lane
The Fire Breathing Monster
March 15, 2009 03:36PM
This sure sounds like a lot of effort to make the dash not shiny.
I use sandpaper on it when it gets too shiny. *Presto!! No more dashboard in the windshield when driving into the sun!
JohnLane
JohnLane
John Lane
March 15, 2009 03:37PM
> prettier.
I dunno about those cage gussets!
JohnLane
AnthonyLatham
Tony Latham
2015 Subaru WRX
March 15, 2009 04:06PM
The Mazdog has now been blessed with:
New Chapman struts (including top mounts - the originals had rotted away)
New half shafts
Trinder and I also took the left front window switch apart in an attempt to resuscitate the contacts. This became a comedy routine as we tried to reassemble the springs and sliders in the correct order. It made it back into one piece and now doesn't work in an entirely new way. At least the down function now works.
New switch to be ordered on Monday. Next task: sunroof repairs and VHF radio install.
2015 Subaru WRX
Traded the Audi for the above
Sold the 1993 Honda Civic EG w/B16A Conversion to the Raw Racing boys
6 bicycles because, you know, global warming and all
March 15, 2009 05:40PM
JohnLane Wrote:
> do
> piece
> > prettier.
> JohnLane
> Overkill is consistently more fun
fabbed them up myself! 2 whole 2"x1" triangles!!
finished product.....still needs to be tested for structural durability
Edited 1 time(s). Last edit at 03/15/2009 05:41PM by Jon Burke.
March 15, 2009 06:22PM
Jon Burke Wrote:
> JohnLane Wrote:
> have to
> > do
> > piece
> it
> > > prettier.
> > JohnLane
cHOP OFF THE LEGS FLUSH WITH THE CROSS bar and the load will be spread better.
> Jon Burke - KI6LSW
> Blog:
> 'Holy Shit!' @ 4:10
> Edited 1 times. Last edit at Mar 15, 2009 by Jon
> Burke.
March 15, 2009 07:47PM
Weld a big washer at the base of the pin where it goes in to the bigger tube and cut a similar sized chunk of rubber to go on the washer so that when you're all enthusiastic and you thrust it in there balls deep before shes ready you dont mangle the hole.
March 16, 2009 01:07AM
Carl S Wrote:
so that
> the hole.
funny, that's what she said.
<snicker snicker>
March 16, 2009 04:53AM
> dash not shiny.
> JohnLane
Yeah but as Grant hughes once pointed out it's just one of those things that make a rally car a RALLY CAR!
gkd
George Doganis
Civic
gkd
March 16, 2009 02:56PM
> RALLY CAR!
Curious... How do you clean this "suede" dashboard after a dusty rally? Can you just wipe it down like a stock dash in 30 seconds? Does it look good once and then it just looks like dirt so need to clean it anymore?
...George
Civic Rally Car
March 16, 2009 03:11PM
gkd Wrote:
> it's
> car a
> > RALLY CAR!
> clean it anymore?
> ...George
Compressed air + blow gun
Sofa King
Monika Hawkinson
2006 Tacoma
March 20, 2009 09:57PM
What did I do to my car today?
Filled up the 3 flat tires and drove it to work.
Monika Hawkinson
Seattle, WA
March 21, 2009 11:22AM
Well done!
Max
1983 MKI GTI
March 22, 2009 03:42PM
I broke off a banjo bolt in the CIS injection for the freakin CSV. now i have to try and drill it out, retap it, and figure out what im going to use.
