brianallmotor
Brian R. Barton
Mazda 323 BP-T
May 11, 2009 10:12PM
turned the shell/body into a boat to circumnavigate the world... =)
tipo158
Alan Perry
May 12, 2009 12:32PM
On Wednesday, I was trying to remove the broken exhaust manifold bolts.
On Friday, a spider egg had hatched nearby and there was a web spun between the left strut tower and the fender on both sides of the tower. Dozens of baby spiders were hanging out.
On Sunday, they had all moved out and the web was gone. So, I resumed trying to remove the exhaust manifold bolts.
alan
mack73
Jason Wine
May 12, 2009 02:24PM
On Saturday, pulled the rally car out of the garage and onto the gravel next to the house and leveled it F/R and Side to side to prepare for rear independent suspension install. Removed rear suspension and mounts.
Finished making the stationary "steering rack" to allow the stock tie rod ends to be used to lock the rear steering so it goes straight.
-Jason
May 20, 2009 01:04PM
NOTHING!
BUT.....ohhhhhhhhhhhhhhhhhhhhhh
I have packages waiting for me at home right now....
ohhhhhhhhhhhhhhhhhhhhhhh
seat, harness, net
Christmas in May!!!
can't wait to get home!!!
can't sit still at work......
May 21, 2009 09:24AM
Loaded the thing in the trailer and sent it off for a cage.
May 21, 2009 01:59PM
Drove mine to work to align it. first time I have driven it, good times.....
May 24, 2009 12:46PM
Got my red xr down to the bone and started stitching it up cutting the back split window out today
tipo158
Alan Perry
May 24, 2009 07:38PM
Removed the headliner, a-pillar covers, b-pillar covers and the panel behind the seats. Made space in the garage to store the interior bits that will be going back in the car after the cage goes in.
alan
May 24, 2009 11:51PM
more gutting of the interior.
worked on the pin jack stands, should be done with all 4 by tomorrow.
tipo158
Alan Perry
May 25, 2009 05:57PM
Removed the remainder of the interior behind the seats. Removed the rear window. Removed the taillights and rear side marker lights. Pulled the rear harness into the cockpit. Removed a bunch of rust.
alan
May 25, 2009 08:41PM
> all 4 by tomorrow.
FINI!!
You can see on the closer one where I put little feet on the bottoms, and spray painted w/rubberized undercoating.
Edited 3 time(s). Last edit at 05/25/2009 08:46PM by Jon Burke.
tipo158
Alan Perry
May 26, 2009 06:02PM
Removed a bunch of sound deadening material. It came up pretty easily with a putty knife. Removed a bunch of old adhesive with 3M adhesive cleaner. Took pictures of the car and posted them on Facebook.
alan
krisdahl
Kris Dahl
Integra, Civic
May 26, 2009 06:54PM
Do yours wobble at all?
Also how is the undercoating holding up? Which stuff did you use? I bought some duplicolor stuff that I was going to use, but I test sprayed on a piece of scrap and it didn't seem to be very durable.
May 26, 2009 08:44PM
> little
> durable.
wobbles if you push and put some weight into it....it is 3000lbs suspended 2 feet in the air winking smiley
the duplicor is what I used as well...what I found is, even though it says '10 minutes', you really need a few days for it to cure and harden up. I'm sure there's better stuff out there, but I'm cheap and lazy and this stuff is easily found at Kragen.
tipo158
Alan Perry
May 27, 2009 08:31PM
Continued removing sound deadening material. There are seven sections of it and the first one came up really easy with just a putty knife, so I was pretty happy. Until I got to the second section. Got most of it off today, but not all of it. I guess I will be doing the dry ice trick.
In preparation for this, I pulled the seats and carpet under them. The brown carpet that was once black went straight into the trash. The seats are hardly faded at all and in really nice condition, so I hope that I can sell them. I also continued to pull the wiring harness forward. There is now no wiring in the car rear of the instrument panel.
I think that the car is gonna pretty close to minimum weight without doing a lot of work.
alan
