July 20, 2009 11:56PM
some more prepwork...and then off to Lars' for the cage to commence!
forst, ome last minute work in my backyard over the weekend....
(my grill was doing double duty as my 'tool caddy', haha)
And then off to the cage builders w/177lbs of DOM tubing!!!
its going to be a fun couple of weeks....
July 27, 2009 10:01PM
I figured out why my volvo was driving funny:
Whoops! I wonder how that happened...
Skidplate just got bumped up the "to do" list.
August 08, 2009 01:29PM
Wednesday I took the car over to Derek's house, and he welded in a couple more bars, harness bars on each side of the main "X", as per Gene's request, just trying to prevent the "I am going to bust your balls at tech if you don't do that".....
Also, while he was doing that, I used the plasma cutter and brake to make the drivers and co-drivers foot well plates
Last night i welded in 14 small filler panels to cover the "Slotted" reliefs in the floor, and prepped the foot wells for welding today.
August 09, 2009 03:42PM
blew a hole in # 2 piston and caught on fire on the freeway!!! fun
August 09, 2009 05:40PM
I prepped a door and 2 fenders for paint on my golf.
Josh Wimpey
Josh Wimpey
Sneak the Golf
August 11, 2009 09:20PM
Building a spare shell. Eric Langbein is doing the amazing cage work...
The shell is now ready for paint & drivetrain (with the exception of 2 gussetts missing from the X in the main hoop in these pictures)
The floors have both been replaced with fresh sheetmetal (Actually the last set of new replacement mk2 VW floors in North America)
The rockers are doubled
The seat bases are installed
The areas around the front and rear strut towers have been seam welded....
Ordered some discount kevlar fabric and epoxy resin to make floor protection.
One. Class -- 2WD
www.quantumrallysport.com
August 13, 2009 03:14PM
Sweet man is that the other set of VW strut tops!
gilbrock
Eli Gilbert
91 Galant, 02 WRX
August 13, 2009 08:55PM
I sold it.
August 13, 2009 09:27PM
Finished my pin mounts, welded some plugs onto the shell, finished the fuel cell floor area, stitched the underside of the car, cleared off all the undercoating (ok, those two are reversed) and some other stuff. Thats all in the last week or so. Paint soon.
August 14, 2009 12:40AM
I am working on paint soon also... Are we going to unveil our cars at the same event? Whats your completion goal?
August 14, 2009 02:24AM
I've stopped making goals. Lol, life kicks my ass. Or school does. Or both sometimes. I'm hoping sometime this season.
August 14, 2009 03:06AM
Carl S Wrote:
> Learn to do the string alignments. They work
> great once you do it a couple times. The trick
> I've found is to make sure you use turning plates.
> My turning plates are 2 squares of hpde with
> grease in between. Works great, costs cheap.
Ditto, except that I use four pieces of linoleum, two back-to-back on each
side with grease in the middle. They're small 1x1's that I got for free
by dumpster-diving.
Someone once asked me what I used to align my car. Answer: Messenger Flats!
(Former Rim Of The World stage, known for knocking things out of alignment.)
For the van and subaru and anything I drive long distances in, I pay for a
laser alignment. When you're trying to get 60K miles out of a set of tires it
makes a difference. For the rallycar I'm mostly worrying about handling and
"reasonably close" is generally "close enough", especially since it'll likely
get knocked around a lot anyway.
August 14, 2009 07:30PM
almost finished my head back exhaust build and installation need to shorten my after cat pipe. no increase in diameter but the volume and flow should show some improvement.
scored a 24"x48"x1/4" plate aluminum of some grade (never had a skid plate before...).
next few weeks will be a used windscreen and a rear disk package.
would anyone highly recommend against the idea of widening the rear wheel base using plate between the beam and stub axle? 1/2" more width i think could help
shit i have got to switch to metric.
August 15, 2009 12:56AM
painted the cage.
August 15, 2009 10:55AM
pictures and how you did it....
