What I've been up to
Posted by hudson
hudson
Andrew McNally
February 08, 2009 10:22PM
So I took a break from working on the house proper and have been doing some work in the garage.. I've finally gotten some real tools.. like a MIG box and air compressor that don't suck! The problem with the air compressor was where was I going to put the damn thing so that it wasn't going to take up floor space.. I had just finished redoing all my work benches, shelves etc a couple months earlier.. and the damn thing didn't fit under and I wasn't going to re-redo the work bench... so my solution..
Andrew M
Onterrible
30ish
open | download - tiny garage concrete forms just stripped.jpg (146.2 KB)
open | download - Tool box side - small.jpg (132.1 KB)
hudson
Andrew McNally
Missed the victory picture!
February 08, 2009 10:48PM
Woops smiling smiley
Andrew M
Onterrible
30ish
open | download - air compressor under bench.jpg (118.6 KB)
hudson
Andrew McNally
Platform Finished
February 18, 2009 05:22PM
So I can use my work bench again winking smiley
Andrew M
Onterrible
30ish
open | download - Removable Work Platform.jpg (135.5 KB)
open | download - Removable Work Platform Pulled Back.jpg (142 KB)
Re: Platform Finished
February 18, 2009 08:38PM
Is this one of those trick posts where we are supposed to spot the differences in the first two photos??
Pretty clever use of space.
Doesn't ever flood down there does it?
hudson
Andrew McNally
February 18, 2009 08:46PM
> photos??
The second picture shows that I can just pull it back and there's more hole underneith.. nothing spectacular, you're right. smiling smiley
Gene, you're not the first person to ask the WTF will you do when it's full of water question. I put a drain in tied into the sewer, problem solved.. I even had the presense of mind to spend an extra bit to get a bell trap style drain so if I drop a small widget and it bounces towards the drain, it won't go down smiling smiley
When your garage is as small as mine, you gots to be inventive (couldn't put the compressor in the basement, or outside in a hut) winking smiley
Andrew M
Onterrible
30ish
WAit whaaat??
February 19, 2009 04:53AM
You couldn't fit the air compressor under the workbench in the garage so you cut the floor out, installed a drain, made forms, poured new concrete and then built a steel platform to stand on just so you didn't have to move the workbench up the wall 6 inches???
U coulda taken that compressor and just hang that baby from the ceiling with burly nylon tie down straps and anchors held into the roof trusses by 4" lag screws? That would clear up floor space.
Thats pretty insane... So was the pit there before the bench? Is the rest of that a plywood floor? You really modified it to suit then! That's a pretty tricky-dick setup there making use of every sq-in.
Edited 2 time(s). Last edit at 02/19/2009 05:12AM by pikespeakgtx.
hudson
Andrew McNally
Re: WAit whaaat??
February 19, 2009 06:05AM
You got it Mike.
The workbench was already too high and I had just finished remaking it for the 3rd time in no more than 5 years. If I had raised it high enough to clear the air compressor, it would have been a workshelf!
Also I've already taken up pretty much all the room above with selving that's being used. I didn't want to put the air compressor up there anyways because there is a room above the garage.. was afraid of vibrations going into the room, the thing eventualy coming down unanounced.
Sure it was a bit of work.. but not as much as it seems, pretty easy really. I lowered my whole basement, that was a lot of work.
Andrew M
Onterrible
30ish
Re: WAit whaaat??
February 19, 2009 11:39AM
VIVA LA ANARCHY!!!!! ANDY UR ONE CRAZY SUMBITCH!
My friends think some of the shit I do is crazy wait till I show them this!
They might not lock me up in that home after all. winking smiley
hudson
Andrew McNally
Re: WAit whaaat??
February 19, 2009 07:52PM
> Michael LeCompte
Mike, I'm glad you think I'm nuts for that. It was really nothing.. maybe 2 1/2 days of actual work.. and that would be taking it easy.
I've attached pics of work.
Andrew M
Onterrible
30ish
Edited 1 time(s). Last edit at 02/19/2009 07:59PM by hudson.
open | download - this is work.jpg (122 KB)
open | download - work as well.jpg (110.7 KB)
open | download - finished.jpg (93.3 KB)
Re: What I've been up to
February 20, 2009 02:07AM
Hey Andrew you were supposed to let me dump the body BEFORE you poured the new concrete. My trunks starting to smell!
hudson
Andrew McNally
February 20, 2009 06:34PM
> starting to smell!
Sorry! Once the weather warms up I've got to redo the threshold at the garage door.. your trunk might be a bit rank by then tho!
Andrew M
Onterrible
30ish
JohnLane
John Lane
The Fire Breathing Monster
Re: WAit whaaat??
February 22, 2009 10:49AM
> Michael LeCompte
Andy is nuts....
Mike you will get locked up. The food is good.
JohnLane
hudson
Andrew McNally
Re: WAit whaaat??
February 22, 2009 11:21AM
JohnLane Wrote:
> Andy is nuts....
That's a compliment coming from you! smiling smiley
Andrew M
Onterrible
30ish
JohnLane
John Lane
Re: WAit whaaat??
February 23, 2009 09:02AM
Andy get that car together!
JohnLane
Morten2
Morten
1974 Dodge Colt
February 23, 2009 11:30AM
It looks like the ceiling is open.
Why not attach vertical 2X4's to the joists or trusses, then attach 2x4's to the 8"x8"x16" blocks and build a shelving unit off that. It'll be easy to get multiple shelves in the sizes that you need (ie. tires), as well as getting the compressor elevated into an overhead position.
Free up the floor space, get everything into the air.
You'll have waaaay more room.
Edited - for poor spelling
Edited 1 time(s). Last edit at 02/23/2009 11:31AM by Morten2.
