david amor david amor Elite Moderator Location: Stoney Creek Ontario Join Date: 03/22/2006 Age: Possibly Wise Posts: 458 |
Morison Wrote:
------------------------------------------------------- > david amor Wrote: > > I hate Jemba because it gives distances > EXACTLY as > > they measure out. > > When I write my own notes I can call 200M > what I > > think 200m LOOKS like. Then on subsequent > passes > > and the actual stage that 200m will ALWAYS > look > > like 200m to me even if it's really 500m. > > Dave, you missed April 1 by a couple of days. > > Every time I have used an odo to measure > 'perception' distances I have found that they are > usually astoundingly inconsistent. After enough > pace noting with measured distances, perception > gains accuracy and consistency but I still prefer > to recce with an odo. > > The drivers who have been the most adamant about > wanting 'their perception' in the notes are the > ones that I've found have the biggest float in > that distance. 200+ isn't a biggie, although in > limited visibility you'll be feeling for the > corner without the ability for the codriver to > zero the interval and count down the straight. L4, > 300, ! ruf cat grd, 500, R3 ... in dust you'd > seriously want to be able to get a solid reference > on all of those elements. > > If your 70 is sometimes 100 and sometimes 40 (seen > this in real life pace noting) then exactly how > will you take the crest, 70, L @ T? > > For the record, I've had discussions about this > with co-drivers with strokes through and/or dots > above letters in their names. I know you're probably right but when I've decided what the distance/severity of a corner is I don't find my perceptions changed when I see it at speed. Yes on stupid long straights like the one at Baie where I hit 205kph before I backed off, My co-driver was counting down by hundreds for a KM cause I was sure I'd miss the L at T at the end. But Jemba scared me. The distances just SEEMED so wrong and I could not go fast on them. Gone fishing |
I know what David means. I remember hearing an interview with Nicky Grist and he was talking about how the note is which gear they're in. When I make my pace notes, I do a mix of this concept and severity of corner. So if it is a 4 in Jemba notes, but is downhill and off camber, I'll make it a 3 or 3+ so that I go into it at an appropriate speed and caution. This does cost me time, but hey, I'm still young.
![]() I don't mind the distances, my biggest pet peeve is when their close to the same. 200 L4 200 R3 200 over crest 200 into L2 into R2 200. That's a bit of an exaggeration and the worst I've experience this in was someone elses pace notes that I used as a starting point, but we didn't have time to make our own. Driver and myself both got a little confused. I went through and added 20-30 and subtracted 20-30 just to differentiate between them. Grant Hughes |
