Volvo Porn for your viewing pleasure
Posted by Vorpal_Rally
Re: Volvo Porn for your viewing pleasure
April 25, 2009 07:55PM
SEANT Wrote:
> Got to love the navigators pen, in-car asphalt, on
> the dash moving back and forth like a G meter ...
In the second video methings that is a tire guage, not a pen. (but I could be wrong)
SEANT
SEAN TENNIS
SAAB 99, SAAB 96 850, SAAB 99T, SAAB V4
April 25, 2009 11:54PM
Morison Wrote:
> asphalt, on
Could be, still it's fun to watch ...
As always IMHO
SEAN TENNIS KF7JJR
SEATTLE, WASHINGTON
SAAB 99, SAAB 850
SAAB V4, SAAB 99T
April 26, 2009 12:42PM
Funny that Volvo does look like a blast, but I'll bet those prissy AutoX, Solo whatever guys would shit their pants. Wrong line, too much tire spin, air pressure all wrong, early apex, car is set up wrong and so on.
April 26, 2009 01:59PM
absolutely - the in-car is amazing stuff...
rallybrick
rallybrick
April 28, 2009 03:42PM
> Is that about how a gravel spec car would behave
> on tarmac without sway bars installed?
Yep, that's how a 240 with soft suspension and no sways (or just front) will behave. The back end of my 240 squatted down quite a bit until I replaced the soft SAM springs with 240 overload springs in the rear to match the stiffer coilovers up front.
> Do you know what it has for a drivetrain? The
> shifts are pretty lightning and the engine sounds
> like a BDA or something. Is it volvo powered? b23?
> Quad throttles?
He has Group H tags in his Youtube videos, which is (I believe) a regional historic class. I'll make a wild guess that he's running a Kent Karlsson B230 Evo rallycross motor (I can't listen to this at work, so I didn't hear the audio) mated to that sequential in the on-board, which may be an Xtrac, which happens to be a Scandinavian supplier of racing trans. There was another white GrH 240 on Youtube last year that I seem to recall seeing those same specs on, so that would make sense. The trans has a drop gear, so you can change the gearing on it pretty easily (ie. rev at 7000 rpm in 5th gear at 65mph if you want).
Cheers.
...Brian...
April 28, 2009 07:30PM
> behave
> up front.
> The
> sounds
> b23?
> > Quad throttles?
No it's just their National class. Historic is called "Historic"
probably H for "Hemma" of 'home'
2wd Normal aspirated, 8v
I'll
Can't use rallycross stuff in rally cars, it's more restrictive, they are trying to have some sensible lid on wasteful extravagance.
mated
Xtrak is in Woking in Surrey, last time they were Scandinavian was when the Angles overran the place.
Could be a Sellhom.
> Cheers.
> ...Brian...
rallybrick
rallybrick
April 28, 2009 09:28PM
> which
> called "Historic"
Does that translate to Finn? I hear there is Gr.H there, too.
> I'll
> listen
Like I said it was a wild guess. But go here (Flash, so bear with the instructions):
http://www.pmotorsport.se/flash/main_v8.swf
Click on the "Historic Rally Cars" at the top and select Volvo 242 - 75. Check out the specs. Former Gr.H and Kent motor, though not an Evo. Probably an SF Pyora M45 dogbox mated to that motor (lots of other SAM stuff on it, so why not?)
Here are some more cool pics:
http://gallery.pmotorsport.se/#9.11
Also check out the Amazons on the main Flash page.
> place.
> Could be a Sellhom.
Who is the group who's main business is boring machines (think the thing that built the Chunnel), but who happened to make race sequentials as an "afterthought" because they happened to have the manufacturing equipment and right hardened metals laying around? Thought it was Xtrak. Whoever they are, that's what Malik's got in his 240. Too rich for my blood, so I never really worried about it.
...Brian...
