another VW 020 ring & pinion group order
Posted by cblakely
Re: another VW 020 ring & pinion group order
June 09, 2009 07:14PM
Carl S Wrote:
> Unless you can come up with a better reason why
> the splined shaft sheared off of the outer cv
> joint right where it goes into the hub. Too tight
> was all we could come up with. And thats how both
> failed.
They simply shear off there.
Minor diameter of the spine is whatever but too little diameter
Major weakness in owning a VW is the outer CV shearing off and other drive line evilnesses.
> Edited 1 times. Last edit at Jun 9, 2009 by Carl
> S.
Josh Wimpey
Josh Wimpey
Sneak the Golf
Tom B Wrote:
> Over tightening the axle nuts? how would this
> affect the axles other than stripping the threads
> on the end?
Happened to us in 2006 as well. Road racers always complain about losing wheelbearings on these cars if the nuts aren't at like 250ft-lbs and we had wheelbearing noise. We kept checking the nuts (2ft bar on 1/2" drive rachet) because we thought they were coming loose. Pulling out of service #3 the whole splined part snapped off. Not sure if the cracks were from over tightening or what.
One. Class -- 2WD
www.quantumrallysport.com
June 09, 2009 10:34PM
I was thinking that, but since I saw them as "peloquin shim kits" I thought you had to buy a peloquin in the first place to use it, which didn't make much sense to me. But now it all does because you use it without a diff installed.
June 12, 2009 07:10PM
Well bill if i beat you to it i will let you know how well it works, the fellow i got my donor from had one installed in his 020 (that didnt come with the donor). he said it worked fantastic. he could drive it around town and long distances. when it came down to business it sufficed.
June 15, 2009 09:10AM
Any update on this? I'm guessing if we're ordering from Europe these won't come in time for NEFR?
Josh Wimpey
Josh Wimpey
Sneak the Golf
June 15, 2009 09:50AM
The Peloquin Shim kits are useless junk when it comes to limiting slip. These are the old kits made by Velocity Sport Tuning way back in the day. When Velocity went under, Peloquin picked up the parts and sells them.
They ARE good for one thing thought---They have a bolt kit for the output flanges so you can get rid of the pesky circlip and dust-cover setup that is prone to failure.
One. Class -- 2WD
