What is this GTX Chassis brace deal?
Posted by pikespeakgtx
hudson
Andrew McNally
Re: What is this GTX Chassis brace deal?
November 06, 2009 05:53PM
Pete Wrote:
> If a car is rusty enough that the suspension falls
> off, bracing the weak spots before they break is
> just cutting the wires to the warning siren that
> should scream GET A NEW CAR ALREADY.
> BTDT twice. The first time was my Subaru where
> the seatbelts pulled through the floor when it was
> 10 years old. That's dangerous. The second time
> I kept shoring the car up until finally the engine
> died at me and I came to my senses.
> Okay the 323GTX is rare. There's a reason it's
> rare, it's a disposa-car. I bet that there are
> some safety razor enthusiasts who are upset that
> some people have 1989 vintage Schick razor blades
> that they're using up and throwing out instead of
> preserving.
> Instead of braces, maybe find someone who can
> punch out the GTX-specific panels so you can fix
> the shells. (Just a thought) Or work out a way
> of using FWD shells, which probably won't happen
> since the nose of that thing looks vastly
> different, FWDs have a crossmember where that
> brace thingy goes and the control arms bolt to the
> crossmember like the Good Ford intended.
Brilliant post.
Are you sure some sort of seatbelt brace wouldn't have solved your first problem?
Andrew M
Onterrible
30ish
November 06, 2009 08:48PM
The solution was to jack up the license plates and drop them onto a different car.
The second car was funny. It was an RX-7, and I had bits of angle iron welded to the lower suspension link mounts (the uppers were LONG gone) that went forward to the floor where it bolted through the floor to some plates on the inside of the car. Why? When I tried welding it, it kept blowing through because it was so rusty. Clue and a half right there.
Bracing to prevent breakage due to awesomeness is one thing, but rust isn't awesome.
brianallmotor
Brian R. Barton
Mazda 323 BP-T
November 06, 2009 09:35PM
i love trying to jack up a rusted car... put the jack on the rusted uni-body jack points, try to raise the car..... every pump of the jack you just hear CRUSH, look under the car and notice the jack is thru the floor.
and yeah, this awesome GTX brace is total crap.
hudson
Andrew McNally
November 07, 2009 10:37AM
> is thru the floor.
I've had volvos where the "frame" bits would crush when jacking
Andrew M
Onterrible
30ish
