Brake Pad Question
Posted by SgtRauksauff
SgtRauksauff
Jorden
Brake Pad Question
December 15, 2009 12:47PM
I need to replace the pads on my car (Mazdog Protege 4WD), which made me think a bit (now I've got a headache!).
Do Rallyists tend to use different compound brake pads in the winter vs. the summer?
I guess in winter the ambient temperature tends to be colder by 80° or more, but on the scale of brake temperatures, is that really even so much as a blip?
--sarge
Jorden R. Kleier
Baraboo, Wisconsin, USA
1990 Mazdog Protege 4WD
1973
Re: Brake Pad Question
December 15, 2009 01:20PM
> got a headache!).
> a blip?
> --sarge
> ---** To be in compliance with the Anarchy **---
> Jorden R. Kleier
> 1973
Nope. You change compounds based on Mu values and what works for your app, not based on ambient temps.
SgtRauksauff
Jorden
December 15, 2009 03:29PM
Different pads will have different coefficients of friction, though, and tend to operate best within a certain temperature range.
How much effect does the ambient temperature affect getting to this effective range (I suppose this could be termed "initial bite" ) ?
Especially, say, on a really long straight with a bunch'o'twisties at the end of it? Do you need to get the pads warmed up on the straightaway so that you actually HAVE some bite to your pads in the corner, and don't just shoot off the other side?
Or in other words, does the pad that works perfectly on your setup in 90° hot sunny weather give you the exact same performance when it's -20 with windchill?
--sarge
Jorden R. Kleier
1973
Jay
Jay Woodward
'90 Mazdog Frankenprotege
Jay
December 16, 2009 10:30AM
I'm no rallyist but I use Porterfield r4e on the so-called rallycar and when they wear out I'll put another set on and I don't give a good goddamn what the ambient temp is...
Jay Woodward
Snohomish, WA
Chronologically, 46...
December 16, 2009 02:27PM
> with windchill?
> --sarge
> Jorden R. Kleier
> 1973
Like I mentioned before, the ambient temps are not a concern cause it wont have an effect on getting the brake temps up to op range.
The coeficient of friction is the Mu value I refered to, and that again doesnt mean that the pad wont have cold bite even if it has a high coef of friction.
The initial bite term you use has nothing to do with temperature, it has to do with the friction properties of the pad, some pads have higher initial bite with the same overall TQ output of a pad with less initial bite for example. These are the properties that Pro race teams test in order to fine tune suspension setups, a less initial bite pad would work great for the rear axle while maintaing high brake torque.
Anyways, back to your original question - NO, ambient temps even if they differ 80F from summer to winter will not make much of a difference when your disc temps will run anywhere from 900-1200F. Now, if you have a ton of cooling, and you have a half mile portion with no brake input, the temps will come down, if the pad has bad low temp friction it will be a puckering situation!
December 16, 2009 03:57PM
Brakes work by converting the kinetic energy of the rotor into thermal energy (heat). That range is the range that the pad will work efficiently (convert energy the best) and then the limit before it starts to die. I assume it gets glossy and then cracks? I've never seen a pad blow up, so I'm not really sure how they die.
Like cosworth said, the ambient temp is just the ambient temp... but as tires are the contact patch to the ground and actually slow you down, if you WANTED to be technical, lol, it would influence your tire compound choices to get efficient traction to actually stop well. But for the brake pads, no.
Oh yeah, heres a random fun fact, When something is sliding, say, a locked tire on tarmac, it has kinetic friction. When that tire is just sitting on the surface, again, we'll use tarmac, and you go to push it (with the brakes on so the wheels dont roll) it's got static friction between the tire and the surface. The static friction is actually STRONGER then the kinetic friction.
This is why when you brake, (not in special instances where you want to lock anything up) you usually dont want to lock up the wheels, because a rolling wheel has static friction to the ground. The small bit of sliding that actually causes normal tire wear is negligible. So you have MORE friction, thus more traction.
But if you look at brakes, if you stomp on the pedal, and lock them up, you've stopped the pad on the rotor. Now you have static friction between the pad and the rotor, as the rotor is trying to break free. Once it does, its back to kinetic friction. But the static friction will have a much higher Mu, although you can't really use it because you'll be dragging the tires along with their kinetic friction... increasing stop distances.
Funny how that works out? That's why brake pads give you the Mu of their Kinetic friction.
(go physics midterms, lol)
(fixed a typo)
Edited 1 time(s). Last edit at 12/16/2009 03:57PM by Dazed_Driver.
December 16, 2009 04:24PM
> pads, no.
> distances.
> (fixed a typo)
> Feisty Peacock?
> Edited 1 times. Last edit at Dec 16, 2009 by
> Dazed_Driver.
WTF did you just planted on the intranetz? lol Geebus, the Mu is not kinetic friction, its the unit measure of the friction coeficient at a particular temp, disc speed, and clamp load, and, and, and... What kinetic energy is really is in this case is the momentum of the vehicle.
December 16, 2009 05:38PM
^^ no, he's right.....he just worded it funny.
Kinetic = dynamic
Force of 'Dynamnic' Friction = Mu(D) X Force
Force of 'Static' Friction = Mu(S) x Force
Brake companies give you the Mu(D) of their brake pads, which, yes...is a constant for the particular material, and assumes a given temperature and rotor material/surface, etc.
FYI, clamp load has nothing to do with Mu. Clamp load = Force in the above equation.
and yes, brakes essentially xfer kinetic energy/momentum into heat energy.
again, Tim likes to word things funny to keep us on our toes.
December 16, 2009 06:13PM
Which part did I word funny? I thought i only mentioned Mu as the coefficient of friction (as it should be). I probably just typed the wrong word. It happens, lol.
December 17, 2009 08:24AM
No man, I'm talking real world not text book, clamp load has nothing to do with Mu true, but clamp load will affect Mu. Many reasons, but one of them being the compressiblity and integrity of the friction material under different pressures.
Regards.
Jay
Jay Woodward
Jay
December 17, 2009 10:52AM
See now, all them guys are rallyists! All I know is one pedal makes it go, one better make it stop and I care not how as long as it does. ambient temp shmambient temp.. What gets my full attention is how they behave when you're most of the way through a stage and you come into that !!!hairpin R exposure don't cut oh crap you better not have brakefade here...
Jay Woodward
Snohomish, WA
SgtRauksauff
Jorden
December 17, 2009 02:50PM
I kind of already understood most of that, regarding Mu (although I dislike using a random greek letter that sounds like a cow to mean "Coefficient of Friction"winking smiley. "Mu" can have any value you choose to give it, as it's a variable in whatever equation you want to use. The greek letter Mu is used IN NOTATION to indicate "Coefficient of Friction" for shortening of said notation. In my own opinion, they (greek letters) should'nt be pronounced when speaking or referring to said notation. Like I said, this one sounds like a cow. Others sound like food (Pi) or fish (beta).. etc....
The maths (new or old) were not really the questions, I was just wondering how super-cold weather affected the aforementioned sphinctorial clench when late-braking into the '!!!Hairpin R exposure don't cut'.
But to add, what does snow and ice and moisture do when they're brought into the equation? a little snow, fine, it melts, now you've got moisture sitting around your brakes.
Lately, with the two or so feet of snow around here, I've been taking the back roads in my Mazdog. Kinda like Jay's, but the testicles haven't dropped yet, it's all stock where it counts.. Vaguely plowed roads, but not salted, only lightly sanded. Playing around with bits of ditch-hooking at a few corners, being sideways as much as possible and generally being a hooligan on unused roads.
Consistently, I've found that if I don't get the brakes heated up before I actually have to slow down, I've gotta give it a LOT of pressure, with nearly zero effect. It's like the pads are completely glazed, then suddenly I've got friction and it slows down.
So, it's either the pad itself not being in its operating temperature, or it's something blocking the friction surfaces from meeting properly.
continue!
Jorden R. Kleier
1973
December 17, 2009 04:14PM
Not having a bizillion dollars to go do testing of pads etc with I have found that Porterfield R4's work for me in all applications and all temps, since they work I have not looked at any other option. Never could figure out why Jay uses the R4e version witch technically stands for endurance, likely since he found they worked for him and thus why would he chance changing to the R4. I used the Porterfields on my 323GTX and Golf.
December 17, 2009 04:33PM
> option.
That seems to be the final say in just about anyone who's ever used Porterfield's that I've ever talked to.
December 17, 2009 05:49PM
Jordan what I've seen on cars doing double duty---ie street and occasionally "more vigorous play" often have a glaze on the rotors deposited even in light use from the binding agents in the pad, the glues and shit (see there's an excellent word that coveys exactly the idea, sorta like "junk-n-stuff"---so we could say the glaze is from the pad binding crap and junk-n-stuff).
Sometimes it seems that varishy shit needs to be roasted off.
Or lightly sanded off.
