MSD Rev Limiter
Posted by sagsert
sagsert
Mustafa Samli
Gaylant VR4
MSD Rev Limiter
May 17, 2006 10:00AM
Does anybody know how to wire an MSD Soft Touch (God ! It sounds do gay) 8728 to a Mitsubishi 4G63 ?
I asked MSD they say it can't be, but I have seen a Mitsu running with it so WTF ??
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
EVO III GSR (Stolen)
Rallies are no place for traitors
PAddy
Patrick McVeigh
Student Loans
Re: MSD Rev Limiter
May 17, 2006 11:35AM
I think the soft touch requires a reacharound cable, no?
Re: MSD Rev Limiter
May 17, 2006 12:05PM
Yeah, it needs a reacharound cable that is terminated with a deepthroat socket at the distributor.
Turbopit
Mike Hymbaugh
Re: MSD Rev Limiter
May 17, 2006 03:01PM
Soft Touch Rev Control, PN 8728, is designed to be used on standard points ignition or inductive ignition systems. This means that the PN 8728 can be installed on engines with a GM HEI Ignition, Ford or Chrysler electronic ignition, any standard breaker points systems or even with an MSD 5 or Blaster Ignition (non-CD ignitions).
The Soft Touch Rev Control is adjusted with plug-in modules and is supplied with 6,000, 7,000 and 8,000 rpm modules. When the engine reaches your set rpm, the Soft Touch circuitry kicks in and drops the spark to certain cylinders. These cylinders are fired on the next cycle to prevent fuel from loading up in the cylinder. This limiter produces very accurate and smooth, backfire-free rev limits.
Can be used on 4, 6 or 8-cylinder engines with inductive ignitions.
NOTE: Not for use with CD Ignitions.
Soft Touch Rev Control, Non CD Ignitions
PN 8728
Are you positive it was the 8728 part and that everything else on that car was the same as yours?
Mike Hymbaugh
"Converted" drag racer smiling smiley
Castle Rock, CO
http://www.four-banger.net/first.html
sagsert
Mustafa Samli
Gaylant VR4
Re: MSD Rev Limiter
May 17, 2006 04:07PM
Well it is AC Delco labeled with part #10037379 which cross references to PN8728.
The Mitsu I have seen had the stock coil setup so it was not one of those MSD ignition jobbies. It did say "Soft Touch".
Again I am reluctant to try anything that says Soft Touch on it, especially on my Galant. The built in rev limiter is inop so I need something to keep me from revving over 6300. Even the 690cc injectors are jumping up to 98% duty cycle at like 6250 rpm, basically i am running out of injectors in a hurry.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Re: MSD Rev Limiter
May 17, 2006 04:35PM
What about OMEX rev limiters?
http://www.omextechnology.co.uk/Revlimiters/revlimiters.htm
Checkpoint Racing carries them through Demon Tweeks.
sagsert
Mustafa Samli
Gaylant VR4
Re: MSD Rev Limiter
May 18, 2006 02:29AM
I already have the MSD, anybody wanna buy it off of me ???
Cheap, $50 including shipping.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Scott Manley
Scott Manley
XR4Ti
Re: MSD Rev Limiter
May 18, 2006 01:35PM
Fuel cut would be better then spark cut on a turbo charged car, IMHO. That's how it's done on most OEM EFI, at least ford and dodge.
Scott Manley
Spokane, WA
86' XR4Ti
37
Ted Andkilde
Ted Andkilde
1968 Mini
Re: MSD Rev Limiter
May 18, 2006 09:31PM
> in a hurry.
If you're still running the factory ECU, Jeff (Keydiver) will burn a custom chip for your Galant for free, set the rev-limit wherever you'd like it.
You can find him on the Galant board http://www.galantvr4.org or on his business site http://www.dsmchips.com.
Cheers, Ted
mack73
Jason Wine
Re: MSD Rev Limiter
May 18, 2006 10:31PM
> Scott Manley
> Spokane, WA
> 86' XR4Ti
> 32
maybe I don't understand the workings completely, but wouldn't this cause a lean condition + Boost = very bad things?
-Jason
sagsert
Mustafa Samli
Gaylant VR4
Re: MSD Rev Limiter
May 18, 2006 11:42PM
> very bad things?
> 94 Golf
> www.Mack73.com
You do indeed understand the workings basics. The whole point behind me looking for a rev limiter is to avoid fuel starvation I get in high rpms. I already destroyed enough engines and I don't have the slightest intention to destroy this one. Fuel Cut = Disaster + Mo Money Down The Drain. As a matter of fact my car even had a Fuel Cut Defencer at one point to make sure there was always an ample supply of fuel.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Scott Manley
Scott Manley
XR4Ti
Re: MSD Rev Limiter
May 19, 2006 11:21AM
Mack and Mustafa- You cann't have a lean condition with NO FUEL. Think about it, how can you get detonation with an AFR of 14 to 0? You have to have some fuel to create a lean condition. Whereas with spark cut you may have fuel but no ignition ( and plenty of heat in a turbocharged app.) = detonation = BAD. This is pretty well reseached by the OEMs. All OEM have fuel cut on decel, but how many cars do you hear of blowing up from this? Zero.
mack73 Wrote:
> turbo
> most
> > Scott Manley
> > Spokane, WA
> > 86' XR4Ti
> > 32
> very bad things?
> 94 Golf
> www.Mack73.com
Scott Manley
Spokane, WA
86' XR4Ti
37
Edited 1 time(s). Last edit at 05/19/2006 11:22AM by Scott Manley.
John Lane
John Lane
Volvo 262turbo AKA the SPE
Re: MSD Rev Limiter
May 19, 2006 11:49AM
Scott if the air & fuel are delivered to the exhaust unburned one *could have plenty of excitement in the exhaust to keep things on the boil when engine speeds drop back to where they should be...
JohnLane
Volvo 260turbo AKA The Fire Breathing Monster
sagsert
Mustafa Samli
Gaylant VR4
Re: MSD Rev Limiter
May 19, 2006 12:14PM
Here is the problem with Keydiver chips, they are mostly street oriented and heavily rely on the stock ecu, also against common belief they are a far cry from being perfect. We already broke the code to the Mitsu ECU like Keydiver did and we can load completely customised maps/functions on chips. We already burned a bunch of EPROMs with our parametres, including the rev limiter. They work on other cars that don't have harnesses bastardised by the Russians but not on mine. Until I replace the whole harness i will not be able to see what signal i am missing coming in to the ECU. It is crazy, ECU gets the RPM reading, OBD sends out the real time RPM value signal to logger, tach doesn't work, rev limiter doesn't work. Which brings us to my need for an external rev limiter and an external tach.
Cheers
M.Samli
Phoenix AZ
Gaylant VR4
Re: MSD Rev Limiter
May 19, 2006 12:33PM
Or a new harness.
