WorldHazard Jace Tuttle Elite Moderator Location: PTown, Oregon Join Date: 03/09/2009 Age: Midlife Crisis Posts: 19 Rally Car: Prizm FTMFW |
On my way to the rallycross today i hear my tires start an un-usual howl a few miles away from my desination. Figured it was just a change in surface/pavement/concrete. :shrug:
so after my oil filter blows off during the first practice and i get 5 brand new quarts of oil all over the passenger side wheel well and such i get a new filter that fits 'properly' and new oil... do my runs. everything is 'fine'... i mean i sucked so it's fine right? lol now on my way home i aired up to 45 psi, as soon as i hit pavment, my tires are howling.. like a lot? i pulled off into a bus zone thingy to check em, and they're not low or anything... but holy crap the entire way from the fairgrounds in hillsboro to my place in salem they were just howling. ya know like when u take corners too fast and loose traction howling.. ya.. i pull into the garage and WHOA!!!! they're purdy flippin torn up now! like i lost a ton of tread! take the wheels off and see all the oil EVERYWHERE in the pass wheel well, wheel, brake system, so im gonna work on cleaning it up right now... but i don't get why they're so torn up? sorry, im no mechanic. but couldnt this maybe be an alignment issue? what would you guys guess Edited 2 time(s). Last edit at 06/26/2010 09:07PM by WorldHazard. |
it was both.. i thought maybe the oil affected it, but they both are pretty messed up. i guess it could very well be they just got worn out naturally. im just use to street tires and not this kinda tread. the alignment looks fine eyeballing it, and its even wear throughout the contact surface too.
edit: but would BF Goodrich AT's really howl like that when balding? Edited 1 time(s). Last edit at 06/26/2010 10:36PM by WorldHazard. |
heymagic Wrote:
------------------------------------------------------- > Possibly an alignment issue. Oil softened them then unusual sun-spot activity coupled with a full moon with a partial eclipse lat night after midnight---was at the machine shop till 12, so I saw just the beginning... It couldn't be alignment, he said he eyeballed it. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
ya... i thought about that after i left... eyeballing an alignment.. w/e.. would the oil have any effect on it?
just finished with cleanup for the night, and after rotating tires i do see a difference between the pass vs the drivers.. passenger is worn down more... kinda lame as i was gonna swap over my spares, but AGAIN.... my lugnuts are too fat for the wheels... any recommendation around pdx and the couv for a machine shop to enlarge the holes? |
------------------------------------------------------- > heymagic Wrote: > -------------------------------------------------- > ----- > > Possibly an alignment issue. > > Oil softened them then unusual sun-spot activity > coupled with a full moon with a partial eclipse > lat night after midnight---was at the machine shop > till 12, so I saw just the beginning... > > It couldn't be alignment, he said he eyeballed > it. > > > > > John Vanlandingham > Sleezattle, WA, USA > > Vive le Prole-le-ralliat > > www.rallyrace.net/jvab > CALL +1 206 431-9696 > Remember! Pacific Standard Time > is 3 hours behind Eastern Standard Time. I didn't know about the partial eclipse..pretty obvious then. |
SteveL Steve Leitch Godlike Moderator Location: Ocean Shores, Washington Join Date: 01/25/2009 Posts: 280 Rally Car: Can't decide which to use... |
SteveL Wrote:
------------------------------------------------------- > Did you string line your alignment before you > drove it?? > > > > SteveL > “This is the point in the killing spree when you > really should turn the gun on yourself…†no i didn't. didn't feel it necessary at the time. BEFORE i left at least. as i drive the truck occasionally i never noticed anything out of the ordinary. i plan on gettin an alignment done now though. how often does a rally car want an alignment? more/less after every stage event? (if i can afford it, SURE!) |
Morison Banned Mega Moderator Location: Calgary, AB Join Date: 03/27/2009 Age: Ancient Posts: 1,798 Rally Car: (ex)86 RX-7(built), (ex)2.5RS (bought) |
WorldHazard Wrote:
> how often does a rally car want an alignment? > more/less after every stage event? (if i can > afford it, SURE!) For the top teams... the alignment will get checked against a string at every service. First Rally: 2001 Driver (7), Co-Driver (44) Drivers (16) Clerk (10), Official (7), Volunteer (4) Cars Built (1), Engines Built (0) Cages Built (0) Last Updated, January 4, 2015 ![]()
randyzimmer randy zimmer Godlike Moderator Location: Buffalo, NY Join Date: 03/12/2006 Age: Fossilized Posts: 196 Rally Car: rallycross 13B Miata |
Hmmm,
I drove a car w/ 1.5" toe-in and never heard them. you have 3"+ ?? Get an accomplice and a tape measure. Have the dumber one stick the tang into a tread groove on the forward edge of one of the front tires. Have the smarter one look under to see the tape isn't hitting stuff and then read the result on a groove on the other tire. Do the same thing on the back edge in the same grooves (this is important). Compute the difference. This will work fine for what you need to know now. You are looking for +/- 1/4" difference in the two measurements. If you have a large amount of camber, the two measurement heights need to be equal ie: 3" from the ground, front and back/both sides Once you do this, see why. Something is broken or re-installed badly. |
MikeColangelo Michael Colangelo Mega Moderator Location: California Join Date: 10/21/2009 Posts: 209 Rally Car: Spec Miata |
Anders Green Anders Green Junior Moderator Location: Raleigh, NC Join Date: 03/30/2006 Age: Possibly Wise Posts: 1,478 Rally Car: Parked |
