Lookie what I just won--finally .
August 26, 2010 03:37PM
Poll
28 votes were received.
All visitors can vote.
Could you be interested in a Soooper Bitchin Lower control arm
This is what I've wanted to snag so I can see about making these as sorta a universal part so we know that it is dimesionally proven at far higher loading than any of us will subject it to.
Hmmmmmmmm, Xratties, Volvos, VWs, GTX, Corolla, Fucuses hmmmmmmmmmm
Now if we make em in a big enough production run.......
Oh Timmmieee Taylor! where are you????
Re: Lookie what I just won--finally .
August 26, 2010 04:43PM
Sweet talk Kevin into making a SW model or ship one down to measure when you get them. Be warned...there is no amount of money that will get me to anodize parts that gawdawful '90 purple color tongue sticking out smiley
Ted Andkilde
Ted Andkilde
1968 Mini
August 26, 2010 04:45PM
I wouldn't worry too much, John will want it anodized that heinous Kawasaki green colour winking smiley
t
August 26, 2010 04:53PM
Oh my god John. Dare I ask how much money you spent on those ridiculous things?
Are the gravel ones green too. So what use does a purple arm even serve?
Just kidding. Get on it.
August 26, 2010 04:58PM
Thankfully Sooper Bitch GreenTM errrr...John's favorite color is not an available color for anodizing
(Thanks for the updated software Skye. This is way more fun grinning smiley)
Edited 1 time(s). Last edit at 08/26/2010 04:59PM by Tim Taylor.
August 26, 2010 05:19PM
We'll see.........tongue sticking out smiley
August 26, 2010 07:45PM
Some questions that I'll no doubt get flamed for...
1) How many people are actually bending control arms?
2) Of those people how many had boxed their control arms? Would boxing the control arms do the same thing?
3) Would the final price of these actually warrant their purchase if 30 minutes worth of fabrication could box a control arm, add little weight (its not even unsprung weight... it's inboard of the strut....) and solve the problem?
4) How can you have a universal arm when sway bar mounts are in different locations? Or is everyone willing to forgo the ability to use a sway bar when they want/need to?
5) What about radius rod vs however else control arms are located, how will these attachment points be universal?
Just a few thought's I have on these. Flame away, although, try to answer if you remember how to.
SteveL
Steve Leitch
Can't decide which to use...
August 26, 2010 07:56PM
Explain how you'd box this...
Does that answer you question?
SteveL
Edited 1 time(s). Last edit at 08/26/2010 07:58PM by SteveL.
August 26, 2010 08:47PM
Don't worry about it Timmy, everything is under control.
noypiesky
Donald Wong
1980 Toyota Corolla
August 26, 2010 09:00PM
I want a set for my Escort. I gather that it'll be adjustable, by the look of it.
August 26, 2010 09:01PM
Answer: The purpose isn't just strength. It's also adjustability. Ability to change camber and caster on the front of cars that aren't able to stock.
Oh, and sway bars are for pussies. But for those that must have them, they have to be one of the easiest things to fabricate a circle track one to work.
I can tell you right now that with almost no ingenuity a full Merkur front upright along with a set of adjustable control arms could easily be used on a Toyota Starlet (and thus probably a Corolla and most other RWD Toyotas) for an easy upgrade to affordable bigger brakes and better strut options. Not to mention the ability to get stronger and better uprights with bigger bearings. Oh yeah, you do have to flip sides so a Merkur front right goes on the front left of the Starlet. Combine that with a Celica Supra or Toyota truck rear axle and Tim's Hayabusa setup and you have one of the most wicked fun rally cars in the USA.
August 26, 2010 10:23PM
SteveL
You maybe should point out the integral nature of the ball-joint, that pound a little slop into that ball-joint and you get to shit can the whole arm.
So how about boxing ......
This:
Or this:
Or this:
or this:
or this:
SteveL
Steve Leitch
August 26, 2010 10:37PM
Oh, don't worry John, I'm with the program. After all, these are my front control arms...
So yes, I'd like to see a stronger TCA than I have right now, oh, here's the car...
Just your typical 2400lb 300hp/tq 302 with a T5, and a 3.70:1 9" rear end...
SteveL
August 26, 2010 10:38PM
confused smiley
SteveL
Steve Leitch
August 26, 2010 10:43PM
confused smiley
That's useless for me, why would I want to build a subframe just to use something like that??
SteveL
