slidewaysrally Kevin Aartsen Mod Moderator Location: White Rock BC Join Date: 02/12/2009 Age: Midlife Crisis Posts: 23 Rally Car: Integra |
Rallymech Robert Gobright Ultra Moderator Location: White Center Seattle Join Date: 04/27/2008 Age: Possibly Wise Posts: 1,292 Rally Car: 91 VW GTI 8V |
I agree with Gene. The real question is if CARS will accept an older homologated cage at all and if so with an American log book. Remember that a homologated cage cannot be altered in any way. The cage must also be installed as per the manufacturer's instructions by a certified technician.
How old are you? Do you have kids? Do they have kids? Don't worry about Grandfather Clause. But Christmas is coming!!!! And Santa Clause knows if you've been naughty or nice! What car? Details!!!--how the hell we 'spossed to answer questions bout a car we've never even seen? Remember Sandy Claws knows if you've been naughty or nice, BUT we don't know shit till you tell us, tell us more. WHO what where when how and why---car cage built by, tube diameter numbers!!! Figures...come on. |
This is what I was sent from the builder of the car.
It is a 94 Acura Integra. Located in Bellingham. Builder was JSport. The main hoop is 2'' .080 chromoly, the rest is 1.575 .060 chromoly. Here are the specs. Engine: “brand new, hardly broken in†just spent $13,000 on engine build alone Dependable NA 210+ whp and 130tq Built and tuned by Kinetic Motorsport in BC AEM engine management Installed and tuned by Kinetic Head: B18C1 GSR head Skunk 2 intake manifold, port matched to head and gasket 3 angle valve grind Extrude hone ported head and flow bench P&P Valve guides relieved Toda cam belt All oem Honda timing components Toda spec B cams Toda valve springs Skunk 2 Ti valve spring retainers B18C5 valves (necked in) Koyo aluminum race radiator with custom fan mount Short block: B18C5 type R Rotating mass lightened and dynamic balanced block guard sleeve “welded†Approx stock bore Endyne rollerwave pistons 14:1 Eagle rods Endyne block breather system ( not installed) Moroso race aluminum oil pan Jsport custom oil cooler Relocated oil filter Fuel: Aem fuel rail Aem adjustable fpr with gauge Fuel test release “scca rules compliable†Rc 225cc injectors Hondata intake insulation gasket Walbro fuel pump Exhaust: ANR equal length 4-1 header thermal coated “crazy†Header, gasket to head port matched Custom Kinetic motorsport stainless exhaust “super lite†Gearbox: ACT clutch Indigo flywheel GSR grearbox Stock 1st gear Type R 2nd gear 3rd 4th and 5th ATS short gearset “super close†Diff = drag spool Custom Raxels axels Custom tall short shifter built by kinetic motorsport Also a heel toe tall short shifter Suspension: Custom Jsport steering quickener instillation Polly bushings through out Jsport reinforced trailing arms Jsport reinforced control arms DMS gravel coilovers Compomotive racing TH2 wheels 15in Spare set of stock wheels 15in Skunk 2 upper front adjustable control arms “not installed†Cryo treated rotors and carbotech pads all around Willwood pro rally front brake setup “not installed†Type R rear control arms Rally sway bars Body: Sprayed Subaru sonic yellow Sparco FIA homologated cage “complete with certification papers†Momo true race steering wheel Peltor onboard comunication with headsets Fiberglass Hood “functional scoops†FAL rear hatch glass Custom Lexan windows Jsport front tubular subframe with skid plate (indestructible!) Jsport custom under body armor with fuel tank protection Momo race seats Momo steering wheel Sparco harnesses Terra trip rally computer with 2 probes installed Custom fiber glass dash upholstered with alcantara with carbon fiber gauge cluster VDO gauges Stack tachometer Spa speedometer Rally functional roof vent Custom carbon fiber floor inserts Custom fiberglass hood mounted night rally quad light system “PIAA†Seamed welded Strut towers reinforced and plated |
$13000 for the engine---somebody got fuck up the ying yang royally for the few piddly bhp more than a combination like that of standard parts could do..
That is the cool thing with the Hondas is the power available for cheap when mixing and matching things commonly available. $13000 is twice what a Cosworth YB fully rebuilt would cost and those are rare 9even if there are 2 downstairs fully rebuilt at the moment: ![]() As to the cage, better ring somebody up there in BC and ask THEM. You know Tony Latham? That's a good start, he can tell you whoever the tech-geniuses are now. How much for this? Gots any piccies? |
BJosephD Brian j Dyer Ultra Moderator Location: southern maine Join Date: 05/01/2009 Age: Midlife Crisis Posts: 381 Rally Car: 04 Rocky Mountain MTB... |
I'm sure the car will need a CARS logbook if owned by a Canadian and have to meet whatever CARS spec they require. I'd be surprised if the cage passed muster nowadays, papers or not. I'm even more surprised to see it have an actual SCCA rally logbook, if indeed it does.
Does anyone know about this car? It is a yellow Integra. It last competed in the 2003 Mt. Hood rally.
I have serious doubts about the cage. The seller says that it is a homologated Sparco cage. It's made out of cromoly. The pictures indicate that it is mig welded. Robert. "You are way too normal to be on Rally Anarchy." Eddie Fiorelli. |
Couple of quick points on this.
1) The car will retain its SCCA logbook but if run by an entrant on a CARS License - and Canadians MUST run on a CARS license in Canada - the car must meet CARS rules. 2) The CARS rulebook is available online - download it and get familiar with it. 3) In the appendix at the back of the rule book (pg. Appendix 1) are the cage rules for cars completed between Jan 1, 2000 and Dec. 31 2008. Homologated cages are acceptable provided they are installed correctly AND have a valid homologation certificate. The essence of the grandfather clause is that cars need to meet the spec for when construction is completed. So, if you buy a car that had its first log-book issued in 1995 you it would have to meet the specs for pre 2000 cages (page Appendix 6.) Those rules mirror the SCCA rules fairly closely. After 2000 there were some differences which makes SCCA cages really iffy. I know two cars (including a 'free' golf from Seattle) that needed to be re-caged to meet CARS spec. The trick with a Homologated cage is that it must be installed as required and can't be modified. I know of a car in BC where they added elements to the cage which voided the homologation. I think they were told to by someone at a track they were running at... expensive mistake. |
Yes - we see imported cars running on their old logbooks all the time. The book is supposed to be a running history of the car and it should only have one logbook (until its been filled) - why would you actively remove that history or transfer it to a new book.
Also of note, under CARS the logbooks are held until the end of the event an the stewards are the ones to make note of any incidents and/or results so the history is accurate, not a simple event/result list. (IE it will list DNF Mechanical - gearbox or Off road - light impact mostly cosmetic or Off road - major impact significant damage.) Under RA(RC) you could centre punch a tree and get away with noting it in your logbook as DNF - coolant leak because the coolant leaked out after the tree obliterated the rad. CARS does put a permanent sticker on the cage that indicates that it meets the standard it needs to meet. A homologated cage that has a serial number from the manufacturer would still receive a numbered sticker from CARS. I can't think of why CARS would want to issue their own log book. |
Anders Green Anders Green Senior Moderator Location: Raleigh, NC Join Date: 03/30/2006 Age: Possibly Wise Posts: 1,478 Rally Car: Parked |
We do this in the Atlantic Rally Cup as well, it's pretty straightforward. Anders Grassroots rally. It's what I think about. |
