T-5
Posted by heymagic
Re: T-5
February 03, 2011 04:07PM
eat project Tim.
EAT PROJECT, TIM! *rude gesture*
We'll see what Michel or Timm want to do.
Well, maybe we can get it on a nor/sou express. Seems like there should be someone coming up to do Olympus from here. Or do you need to get rid of it pronto?
Re: T-5
February 03, 2011 05:21PM
Picky fuks... NEAT project
Re: T-5
February 03, 2011 05:32PM
Wait, Tim Tim or Timm Me?
You did put two M's on it....
Re: T-5
February 03, 2011 06:01PM
Does it really matter, you're never going to finish that garage queen tongue sticking out smiley
Edited 1 time(s). Last edit at 02/03/2011 06:01PM by Tim Taylor.
Re: T-5
February 03, 2011 11:04PM
Hey John, that reminds me:
Are your redblock<->T5 bellhousings for GM or Fnord snouts?
Re: T-5
February 03, 2011 11:39PM
They're for the GM box. The Frod shifter box thang is about a hands width further forward on all USA cars so in a Xratty or a 240 if you don't use some swooopie back stick you'll be changing the radio station ever 1st, 3rd and fifth gearchange.
The GM thing has the box in same position as the T5 for the Cosworth and shfter is short and nice..
Of course the S-10 thang you'll be goosing the co-driver in the nuts on 2nd and 4th shifts, outta keep him awake anyway.
Robert Culbertson
Out of this dumpster fire
Re: T-5
February 04, 2011 12:01AM
I hope you don't plan on rebuilding that flathead, everything for those is expensive.
I am still looking for parts to finish my '38 ford truck... anyone have a dual carb intake and a spare Holley 94?
Re: T-5
February 04, 2011 03:39AM
Naw, you goose yourself on the 2nd shifts and the codriver on the 4th ones. Equal goosage for everyone. It's a commie thing.
At this point having that as a GM adaptor sure makes things easier. Otherwise I'd have to mix'n'match. Sorta like, well...
Well, clearly, I need to charge up the ol' cell phone and give you a call.
Edit: meh. That embedding thing didn't work as well as I'd hoped. Oh well.
Edited 2 time(s). Last edit at 02/04/2011 03:41AM by hoche.
Re: T-5
February 04, 2011 09:26AM
Robert Culbertson
It's going to run in stock form for the first outing to stay on budget. After we blow it up the first time we're going to get stupid. The max 0.187" overbore removes about 16lb of cast iron from the block, I can easily fix aluminum heads that most people toss, and we have a guy on the team who is a professional motorsports wiring/engine tuner. Best guess right now is that it will end up with an intake that uses two racks of gutted motorcycle carburetors as air doors with crossed CAN-AM style intake trumpets...because we can smiling smiley
Re: T-5
February 04, 2011 05:09PM
Robert Culbertson
What about the Angry Hamps-turd?
Robert Culbertson
Re: T-5
February 04, 2011 11:36PM
That looks like a 59a block, does it have the later crank with insert rod bearings or the early style with floating rod bearings? The inserts are much nicer and way cheaper/easier to work on.
As far as the multi-multi-multi carb setup, that sounds awesome and should look great. I though of doing two or three S&S carbs on my truck, but common sense took over.
To help with over heating get new water pumps for sure (might not need aluminum heads), the ones from mine on tear down were in pieces.
Re: T-5
February 05, 2011 08:55PM
Still have it and we'll probably race it at at least 3 events this year.
Robert Culbertson
It's a 59a block. We're not even going to open it up before racing it to see what bearings it has. Just adding an accusump and running it until it blows up. I was planning new water pumps and the aluminum heads are partially for weight reduction...same deal on the eventual overbore and fancy intake, cast iron is heavy.
modernbeat
Jason McDaniel
Re: T-5
February 13, 2011 10:53AM
I've stuck the S-10 tailhousing on the back of stronger T5 transmissions and adapted them to the late flathead using the stamped steel bellhousing. Wrote it up and it's been "general knowledge" on the HAMB since then.
