Lesson for today
Posted by Racinkid13
Robert Culbertson
Out of this dumpster fire
Re: Lesson for today
August 17, 2011 03:05PM
I tried the screw in studs on our MK2. I kept on rechecking the lug nut torque and they were always loose! So I got tired of that, and decided to switch to ARP ones (Honda, super long and bullet nose 5pk is $14). When I went to remove the studs they were basically hand tight! That was with loctite!
So me experience with screw in studs is no good.
The ARP bits took a bit of machining in the rear disks to get them to clear, about an hour total on a lathe. All you really need is a 15/32 drill bit, a drill press, and an evening.
August 18, 2011 09:53AM
Reamer
I believe the no extractors rule is to keep it an even playing field. There only the size of a dime so I dont think they will decap any fans. They are used to maintain tire pressure. You set them at 30 psi your tires will maintain 30 psi or less. If the tire temps go up and the pressures rise to 32 psi the valve will let pressure back down to 30 psi. Ive ran them in the past. I took them off after a dnf. Debris in the valve give me a flat under caution.
Yo Jeff, in the context of rally cars and rally RULES prohibiting "extractors" mounting to the outside of the wheel----the rules are referring to very skinny discs which you can see on the fronts in this very Soooper Bitchin piccie of a very Sooooper Bitchin car:
Now I gotta go read some cool comparison of works cars on this nutso good French site i found..
Gawddam they dig deep and post so much archival stuff, amazing.....same in bikes, amazing,
Here's another, not quite so soooooper but clear.
So your whatever "tirelief" or whatever is one thing, but rally rules prohibiting 'extractors' refer to these things which were once the rage for those asphalt pervs----and which indeed MIGHT be capable of cleanly slicing off a speccie's head, considering how cheesily that some peoples would mount them...
August 18, 2011 10:42AM
Reamer
Thanks JV, that is what I always had in mind when I read that rule. I can only imagine how many souveniers we'd have around after a rally if those were used.
August 18, 2011 10:54AM
Reamer
Well now you see the violence in the---wait, wrong taunt!
Now you see some advantage of being er uh having been around and involved 20 years ago when these were the rage--in Europe---on asphalt, and knowing they were banned by FIA start of 1993 season.
And ya also know that the US rule was simply adopted and sat there without thought or purpose for nearly 2 decades.
Now today's lesson:
Vatanen 1987 1000 Lakes works Ford Sierra. 2nd OA against a fleet of Lancias, GTX, Audis....Blomqvist 3rd..or vice versa,,, whatever it was we long sighted sorts knew the Xratty could be a car capable of any OA result, if the driver had skill.
Edited 1 time(s). Last edit at 08/18/2011 10:57AM by john vanlandingham.
Max
1983 MKI GTI
August 18, 2011 04:25PM
So..........John.............Im guessing you have a lathe?
August 18, 2011 05:00PM
Ain't mine but I have the key to the shop. Manual lathe, 4 CNC lathes, manual mill. Across the way is Blanchard surface grinder, a mile away is kake's with a couple more CNC lathes and 3 multi-axis CNC machining Centers for mill work.
Here's the latest NEW! NEW! NEW thing:
Volvo steel flywheels
Here's other things:
Volvo 8 and 16v steel cam cores:
Volvo to Borg-Warner T5 gearbox bellhousings
Volvo 11.75 x 1.25" disc and alloy bell;
Yeah a variety of things.
Whaddya have in mind?
Robert Culbertson
August 18, 2011 05:13PM
With those dirt track rotors for them volvos, how do you get the calipers to fit. Different calipers, a spacer? I like my volvo's brakes, but THOSE WOULD BE AWESOME!
August 18, 2011 05:34PM
Robert Culbertson
You don't need calipers...those hats are so pretty that spectators jump out and stop the car to get a better look.grinning smiley
August 18, 2011 05:59PM
Robert Culbertson
We got them under the BBS looking Volvo 15", under the 'Sirius" 15", and under Omega 15"things that look like Compomotive TH or Sparco OZ.
More piccies are taken but not uploaded yet..
I use the same specific Wilwood Forged Superlite that I do on the Xratty set up:
Very powerful, yet easy to modulate just short of lock up.
Todays lesson:
the most important performance system and the most rewarding in terms of better stage times and safety is the brake system....
These brakes are good enough brakes that you are on par with, par--parity--with the top cars in the US in terms of braking--hairsplitting of 1% type stuff excepted (Sure sure AP calipers are better, but at $780 a caliper I don't see many Anarchistas de rally buying APs).
SO: if we can have torque like anybody else, decent ratios like anybody else, at most speeds we do stages good enough grip, similar or same final drive, and now brakes as good....
What's stopping you from top 3 stages times?
August 18, 2011 06:08PM
Testicles.
August 18, 2011 08:51PM
Testicles.
A lack of them, anyway. grinning smiley
August 18, 2011 10:39PM
Testicles.
Wrong.
Practice.
Max
1983 MKI GTI
August 19, 2011 12:24PM
Well, the quick release adaprt gear is welded to the steering shaft. I need to get of seperated so i can swap out the upper bearing since its toast. But, the gear is too big to get the old off much less the wiper/turnsignal switch off. Trying to figure out how to remove such critter.
August 19, 2011 03:05PM
ummm ... thinking that hairsplitting of 1% things don't add up to measurable pace gaps?
(John. Before you go all 'JVL' on my ass... this is really intended as a humorous comment... not as anything else.)
Ascona73
Bob Legere
1971 Opel Ascona
August 19, 2011 05:44PM
Ummm, a running car....and money.
