1fastben
Ben Hetland
None, right now
Just for advice sake: Tire Groovers
August 22, 2011 10:21AM
Are the sub-$100 tire groovers worth having? I don't "need" a tire groover, but I'd like one. And spending $350 on one isn't really in the budget.
For instance, in the event we run a broken tarmac rally sprint here in UT next year, I was thinking of finding some Radial T/A's or something to that effect and carving in them a bit to help for the more loose stuff. It seems to work pretty well for the rallycross (not rallyX) guys.
Re: Just for advice sake: Tire Groovers
August 22, 2011 10:42AM
1fastben
I've used the cheaper ones, they'll work just not as fast and easy..gotta push more.
(in before the "whaaaaaa! whaaa! they're rubbish! you need a the $475 with the LCD screen and digital readout self propelled tire groover at a minimum, or you'll DIE!!!!"winking smiley
Get extra blades and think what you'll typically want to do. Ie how wide.
Oh yeah, a note on the confusing terms for the forms of racing: if we just call the one "Grass-o-cross" it instantly clarifies whatcha mean.
August 22, 2011 11:13AM
1fastben
///be cool everybody, this is a threadjack...
are these the tires you're talking about?
While I can't say I've followed the extreem(tm) rallycross stuff, my impression was that almost everybody was using either dedicated rallycross tires or full depth r-compounds or 'super-duper' summer tires (same vein as those falkens you used to have).
Coincidentally, a full-depth treaded r-comp (something like the nitto nt-01 or the toyo ra-1) or summer tires would be my personal recommendation if we put together this event - it's certainly not pristine tarmac like you'd find on track at miller, but it's not _that_ bad. A little gravelly in places, but after two passes of recce in each direction, it'd probably be pretty clean.
//on topic - having a groover to open up a treaded r-comp or summer tire would probably be prudent, however...
1fastben
Ben Hetland
None, right now
August 22, 2011 11:44AM
Sweet, I'll probably pick one up, in that case.
I honestly don't know if the Datsun would even be fun on tarmac, with how beastly the steering is on it with no-PS. Once I get it back to being roadworthy, I'll to some fun tarmac testing and see what I think. smiling smiley
You're probably very right on the Falken summers I had. I really liked them, so a set for the Datsun would probably be good. Whatever I end up with, they'll likely be used so I can get them cheaper.
August 22, 2011 11:49AM
Get the Falken Azenis 615. They work fine on tarmac and are reasonably priced. Don't worry about grooving them - they work fine rain or shine. I took two minutes off my closest 2wd competitor on a 12 mile stage at Tennessee in the Colt in pouring rain with two inches of standing water in places on those tires without a worry.
August 22, 2011 12:22PM
1fastben
It can't be any worse than a civic with a clutch diff, non-ps 2.3 turns lock-to-lock rack, and marginally sticky tires. (By which I mean to say - once you're moving faster than 5mph the steering effort will be pretty low.)
August 22, 2011 02:33PM
GRM just did a tire test, and the new Hankooks were fastest, and cheapest too! They tested 6 tires.
Ascona73
Bob Legere
1971 Opel Ascona
August 22, 2011 03:21PM
1fastben
I used a cheapo Ideal grooving iron to prep the tires for my friend's hillclimb car (Mt. Washington). It's a LOT of work if you're doing more than a few grooves. I changed one blade per tire. Took me about 40 minutes to do one tire. I'd guess that with a Van Alstine or Rillfit groover you could knock 20-25 minutes off that time. Fatigue was definitely a factor for me! But for just a few tires, the cheapy will work.
August 22, 2011 03:48PM
I picked up a used Rillfit like this: off of Ebay for $150. It was much much better money spent than the $70 I paid for one of those cheapo groovers. My advice is to keep searching Ebay. Cheap used Van Alstines and Rillfits do come up from time to time.
Edited 1 time(s). Last edit at 08/22/2011 03:48PM by Doivi Clarkinen.
modernbeat
Jason McDaniel
August 22, 2011 09:29PM
I used the cheapie to tune-up the skinny vintage rally tires on the SAAB 96 and to groove the hillclimb tires for the Subaru. At Pikes Peak this year I ended up completely grooving 16 slicks in 8 hours. And the blade cut was still cutting as well on the last one as it did on the first one. I did some more grooving during practice the next morning. The only issue was I had tennis elbow after all that pushing.
I've got no issues with the cheap groover. The only issue I'm worried about is eventually breaking off the plastic handle.
shiza
Dan Norkus
94 Integra
August 23, 2011 01:11AM
Was this the new compound 615's? I haven't tried any of the new ones. I had a set of the old ones and when they got hot they got really greasy. I've also run the Hankook RS3's and was MUCH happier.
Also as far as cutting R Comps goes from what I understand they aren't allowed.
3.12.1 Additional Tire Rules For Tarmac Events
1. A tread pattern depth of 5.5mm (6/32”) must be molded into the tire and at all times during the event, the tread depth of the tires must be not less than 1.6 mm (2/32”) over at least three quarters of the tread pattern.
2. The method of measuring the tread depth shall be averaging two measurements, both taken in the center of the width of the tire, with the measuring points being at the 10 o’clock and 2 o’clock positions.
3. Shaving of tires is permitted. Siping/grooving of tires is permitted. Tires do not need to be homologated.
4. Full racing slick and some “DOT” R-spec road race tires (some examples are Hoosier R3S04, A3S04 & A3S05; Avon Tech R; Kumho ECSTAV710; Hankook Ventus Z214, Goodyear GS-CS Eagle) are disallowed.
August 23, 2011 08:16AM
shiza
(emphasis mine)
Aren't you a co-driver? tongue sticking out smiley
Both the tires I mentioned meet the letter of the rules - both have something resembling a real tread pattern, the RA1 is molded at 8/32, the NT01 is molded at 6.3/32 - while they're looked down upon by lots of the 'SRS BZNS' road racers, I'd wager they're still going to be faster than any "true" street tire.
(as of right now, it's all a moot point, because the soonest I'll be planning a tarmac event will be 2013...)
August 23, 2011 12:54PM
More often than not, buying cheap stuff is buying cheap stuff. Almost every time I buy cheap stuff I regret it sooner rather than later.
If you don't want to stalk ebay for a used one, could you go into a co-operative buy on a good unit with another rally guy near you? It'll probably end up with one of you buying out the others half of it eventually... but then you're spreading out the cost.
August 23, 2011 01:53PM
Oh no, mang, this is America, co-opertaive things smack of Communism and is an offense against Gawd.
Of course it would be smrat, but this country wasn't built by being smrat, it was built by every individual doing everything themselves, all the time..
We know about you filthy subversive Canajians, the hint is kinda obvious with the RED leaf in the flag, oh yeah..
Next thing you know you'll be suggesting that all the Seattle Toiletta Commodah guys split the cost of a spare front strut...
Oh wait, I suggested that and am just doing that tube right now..
Well, I can suggest things like that cause I am only half American, and I was "turned" at age 20 by hard core Commies, deep cover and all so don't tell anybody that I am secretly Red.
August 23, 2011 02:06PM
Good point John.
Rather than a co-operative purchase, why not considered a capital partnership with equally shared equity. Based on the idea of renting it out to others in addition to your personal needs, you could split the net revenues based on the percentage of your capital share. Of course partners would have the first right of refusal to buy-out shareholders wanting to liquidate their stake in the venture.
Is that better?
