DMack Rally Tyres in the USA
Posted by Greasecar
electric_eel
James Roberts
'02 Mazda Craprotege 5
Re: DMack Rally Tyres in the USA
April 14, 2012 09:44PM
What is the recommended pressure for the medium compound tires?
http://rallyhq.weebly.com/
April 16, 2012 09:40AM
electric_eel
I'm sure you can get more nitty gritty facts from DMACK USA,
but 30-32 PSI hot is recommended, regardless of tire compound
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
April 16, 2012 01:57PM
Littlelina
more interest : may try 14 inch with the 175 70 14s
and would still like to see
185s 70 13s that should fit on 5.5 wheels, I think thats some of what John was saying ?
since it fits street tires on there now 185 and 205s on the same type of small wheel
Lina, Unless you are upgrading your brakes and need a 14" rim to clear them.
STAY ON 13S !!! i ran 165 and 175 tires on a 13X5" rim .. the width never gave me any issues.
For racing, you always want the smallest rim that will clear your brakes, and the lightest rim that gives you enough strength to not break. I haven't read about you upgrading your brakes, so don't change your rim size.
Now if you have an amazing hookup on 14" alloy rims, but nothing for 13's You'de have a good reason to upsize. but 13s will be cheaper than 14s... give you more sidewall between your rim and a rock you hit, and it will have a smaller radius for the weight of the rim . (every so slightly better braking and acceleration ) probably a better OA diameter for your gearing/hp too
thumbs up smiley
Greasecar
Justin Carven
'79 VW Rabbit TDI, '02 VW Golf
April 16, 2012 02:08PM
I have ordered some 165/80-13"s in the shipment due next month, these are suitable for 5.5" rims.
In regard to 13" being cheaper, that is not so in the case of DMacks. I don't know of anyone else importing 13"s at this time but due to the low interest, stock levels will be much lower than the 14 and pricing similar.
www.DMackTyresUSA.com
April 16, 2012 09:18PM
A1337STI
Littlelina
thumbs up smiley
Of course all of Alex advice MUST be prefaced with one ionescapable fact: The brakes are the most powerful system in the car. Learning to use with control the most powerful system in the car OUGHT to be a high priority since braking, which requires JUDGEMENT, is, other thing not even being equal, the easiest way to gain a massive advantage.
Of course nobody will do this because they are all already ex-spurts.
Greasecar
Justin Carven
April 23, 2012 11:37AM
Last Chance To Order Tires For Oregon! We're finalizing a pallet of tires to send out to Portland tomorrow so anyone needing tires needs to place their order today!
We're also running low on several sizes and don't anticipate the next shipment arriving in time for STPR. So get you STPR orders in soon.
alosix
Jason Powers
April 25, 2012 11:35AM
How's the 195R15 stock doing? Looks like I'll need a set around mid may.
Thanks
Jason
This isn't floor mat anarchy
Greasecar
Justin Carven
April 25, 2012 11:44AM
Jason-
We only have 195-15 in soft compound right now with the exception of one pair in medium. The next shipment of medium 195s is due in June. We do have stock of 205 and 175-15s available in both soft and medium.
alosix
Jason Powers
April 25, 2012 11:51AM
Hmm.. I'll probably kill softs out here.. First entry is projected to be Gorman in August, not a cool event @ all.
Anyone have thoughts on 175s on a 'poorly tuned' PGT WRX? I know the car doesn't have the a$$ for 205s, I've got a set about that size on it now.
Thanks
Jason
Greasecar
Justin Carven
April 25, 2012 12:10PM
Jason-
I will have 195s in medium and possibly even hard with plenty of time for Gorman. Please send me an email with your information and what you need and we can take it from there.
-Justin
info@dmacktyresusa.com
