Josh Wimpey
Pete, the answer is that Quantum Syncro Wagons are the coolest and best cars ever made period. The only improvement is one that has a turbo conversion and isn't terminally ill with rust or impossible-to-find- replacement parts needed.
Like the windshield weatherstrip? (Or basically anything glass-related?) Been looking for one of those for a while. I did find a windshield for it, though, which is nice.
You'll be happy to know that I have an MC2 block powering a stand right now, has some nice ARP head studs sticking out of the deck, and the head is at the machine shop getting cleaned up/decked/cut for nice 034 Motorsport valves. The whole ECU setup from the 200 is going in, but not before being sent off to Ben Swann for his magic.
I was looking for a small-chassis car specifically for a turbo conversion, when I found this thing. It freakin' rules, it's like an ur-quattro but WAGON and VW idiosyncrasies instead of Audi idiosyncracies. (The HVAC works but the speedo breaks a lot, in other words)
BTW, swapping the vacuum l;ines so the rear locks first then the center locks at the second detent makes for more fun driving when you are out drifiting around.
It's quicker at rallycross with both locked, which doesn't make sense either but okay, run with what works. I only run it at Detroit region snow events, it's awful slow/tippy for the Ohio events which tend to be a bit faster and rougher, and that's what the RX-7 is for. I mean, why run AWD when you have a perfectly good rear drive car ready to go?
Also, only put snow tires on the front or at least if you run studs, only stud the fronts and you can drive the thing at any angle at any speed on the snow and ice with a single finger and change direction at will..... and put on gymkhana shows that rival KB's.
I did that, had only two snow tires left over from the Golf and they were the same diameter as the QSW's street tires, so I figured, hell, let's try it. Criminy. Leave the diffs open and use LFB to basically do a burnout around corners. Or in a straight line. Or stopped at a light. The next day, I had four proper snow tires on the car.
Edited 2 time(s). Last edit at 01/20/2012 05:08PM by Pete.
