Littlelina
Lina Lipilina
1971 BMW 2002
'02 update & exciting stuff at wrc
February 27, 2012 11:59PM
back form rally sweden (yep I got to go as guest team member from usa - was anyone else out there?) and I learned a lot of stuff and things!!
anyway, soon will be back in the car getting it ready for cage installation - found a master builder (actually he found me when I was purchasing my materials at the mill) and offered me a PT apprenticeship where I can notch & TIG the cage into the old bmw I chose as my race car -
so does everyone drop the co-drivers seat ~2.5" below the level of the drivers seat here as well?
and how did that rallysolo thing go so far? sounds like a fine idea to me, anything to allow more access and other options to the sport
- my least favorite thing is that some people (usa) think I went to a protest in sweden ;p
-most favorite is knowing that I have educated pretty much everyone at work about rally
Re: '02 update & exciting stuff at wrc
February 28, 2012 12:10AM
In a 2002 you will need to do what ever you can just to get the seats to fit. I am currently trying to get two wide Sparco seats stuffed into a 1602.
In my opinion TIG welding a cage in a club level car is a huge waste of time.
Littlelina
Lina Lipilina
1971 BMW 2002
February 28, 2012 12:20AM
yea but it will be pretty (TIG that is) it will be a learning experience and club car nothing, I want full racing FIA priveleges (its superior form of welding 0 the metal starts out being nearly gapless at the joints
...and Im going with sparco corsa (arent those the narrower variety?)
SeanP
Sean Lane
2000 Dodge Neon G2, bruised
February 28, 2012 12:44AM
sounds like a fun trip. now where did I put that "this thread is worthless without pics" icon?
I can run a mig gun pretty well, but I wouldn't want my first TIG experience welding joints on a race car. YMMV
February 28, 2012 01:22AM
Littlelina
Lina, listen to Robert. Do things for real advantages. WRC level cages were welded using MiG. There is no advantage to TiG.
A smart person would learn on less critical things than their first cage.. Horses for courses. Learn of brackets and junk like that---where a possible failure is not so potentially catastrophic.
You want to learn? The first step is listen to those with decades of experience.
And whatever you mean by "full racing FIA privileges" TiGing a cage has nothing to do with that. Just find the FIA affiliated body in USA and buy a license.
Littlelina
Lina Lipilina
1971 BMW 2002
February 28, 2012 10:15AM
thanks for the weigh ins - cant ever post pics from my camera because they are too large.
I may decide on MIG - both options are available (my original first choice) but why does everyone seem so 'afraid' of TIG - its allowed in all the rule books
February 28, 2012 10:28AM
Littlelina
Nobody here is "afraid" of TiG. I was trained to weld in a 2 year course (which I crammed in in less than a year) in Sweden and one of the things they hammered into our thick heads was "use what's appropriate".
Would you use a 3/16" stick weld for body sheetmetal 9that is .040 thick)?
There is no advantage to welding the cage with TiG.
There are disadvantages of welding the cage with TiG.
Time---and very commonly, undercutting. But mostly it is a huge waste of time for no advantage.
You want to actually rally the car some day?
There is LOTS!!!!!!!!! to do without deciding on a pure whim, backed with obstinance, to waste time.
Do things on the car for real advantages, not whims.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
February 28, 2012 12:45PM
if you end up Tigging instead of Migging. You'll still be welding your cage, when you could be out driving. driving your car in between events is important. I don't mean fast practice driving on dirt roads (though that is good) i mean just going to the store, or work, or the mall. get very familiar with getting in and out of your cage, and all the noises your car makes with no sound deadening.
what's that weird noise? coming from the back left... Its much nicer if on your first transit ever, you know what sounds, smells, vibrations your car should be making .
Also I don't like putting the navigator lower or further back then i sit.. there's a little something called "corner balancing" so your car turns left just as well as turns right. I haven't done that yet, but moving one person way further back then the other is gonna mess with your corner weights really bad... or it may help .. you need to know your corner weights first, (with and with out crew) if you don't have that as a start, then I wouldn't dare move one seat back or down for "weight distribution purposes" .
February 28, 2012 03:11PM
I moved the co-driver seat back and in for Safety Alex, the cars performance is secondary, and allready more than can handle.
February 28, 2012 03:16PM
Littlelina
MIG welding will alllow you much more access to rally since your car will be done decidedly faster.
No reason your MIG welds can't be pretty as well.
February 28, 2012 03:21PM
A1337STI
you've got an entire engine sitting over your front axle, your co-driver's position is irrelevant to corner balancing. low as possible for lowest CoG, and back as possible to put as much weight in the rear.
fine tune with your cool adjustable coilovers when you've got the car on scales. 1-2 mm of perch travel will add or subtract 2x Jeanna's weight.
hell, going from 25 to 30 psi in one tire, I watched that particular corner scale change by more than my own weight.
February 28, 2012 03:32PM
It doesnt take THAT long to tig a cage... I've done it.
The REST of the car is the long part... winking smiley
Edited 1 time(s). Last edit at 02/28/2012 03:32PM by Dazed_Driver.
February 28, 2012 03:33PM
Littlelina
anyway, soon will be back in the car getting it ready for cage installation - found a master builder (actually he found me when I was purchasing my materials at the mill) and offered me a PT apprenticeship where I can notch & TIG the cage into the old bmw I chose as my race car.
A Master Builder? A PT apprenticeship huh. Sure he's not a perve? What's he a master builder of? Ships?
The welding of a cage is so secondary to the build and design. Important, but I just saw the third or fourth car THIS YEAR that I would not even consider rallying in due to a shitty cage design. Welds may have been fine, but the cage was shit. Legal, but I wouldn't pay for them.
February 28, 2012 03:37PM
Especially when you are running four businesses, going to school full time, and feeding a family of Puffins you saved during a mountain bike ride around the Arctic circle.
A1337STI
Alex Rademacher
February 28, 2012 04:30PM
I still have yet to corner balance. its on my "would be nice list" hell sometimes i don't even do an alignment before a rally (Never my best results) that reminds me... my car needs an alignment
