HiTempguy Banned Professional Moderator Location: Red Deer, Alberta Join Date: 09/13/2011 Posts: 717 Rally Car: 2002 Subaru WRX STi |
Curious as to what everyone does?
Obviously, it really wouldn't hurt to do it every rally, but the cheapass in my says that with modern day synthetics, it really shouldn't be necessary. We drive our cars flat out for typically less than 20 minutes at a time, I'd think a day of time attack would be just as hard on a car and lord knows I sure didn't change my STi's oil that often (went with the severe service interval, which is like 3k miles or 5k kms on synthetic). I was thinking about going with an "every second rally" interval. Seem reasonable? Should I change the filter and just top up a bit? |
czwalga steve czwalga Professional Moderator Location: Pittsburgh, PA Join Date: 09/16/2011 Age: Midlife Crisis Posts: 376 Rally Car: 95 awd celica |
Yes, get a Ford. no worries about remembering miles. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
SeanP Sean Lane Elite Moderator Location: Sacramento, CA Join Date: 07/29/2011 Age: Possibly Wise Posts: 334 Rally Car: 2000 Dodge Neon G2, bruised |
I do it about every other rally - mostly to check to see if there's anything unusual happening internally.
I had a main bearing go bad years ago and only caught it because of the flecks of brass in the oil. Saved myself a chunka change by catching it before the whole motor seized. Since then I've been a little paranoid about it. Self-righteous douche canoe |
Andrew_Frick Andrew Frick Godlike Moderator Location: Greenville, SC Join Date: 05/18/2007 Age: Midlife Crisis Posts: 684 Rally Car: Rally Spec Ford Focus |
modernbeat Jason McDaniel Super Moderator Location: Dallas, TX Join Date: 12/14/2007 Age: Possibly Wise Posts: 401 Rally Car: 1963 SAAB Historic, 1995 Impreza Open Light totaled at WRC Mexico, 2005 STi Pikes Peak winner |
For the Subaru, every event. Not because the oil is worn out, but it's a gauge of the engine's health. And it's a minor expense compared to the overall cost of an event. For the SAAB, duh, there is no crankcase oil. The oil goes in the gas tank. Jason McDaniel |
derek Derek Bottles Mega Moderator Location: Lopez Island/ Seattle WA Join Date: 12/20/2005 Age: Possibly Wise Posts: 853 Rally Car: Past: 323, RX2, GTI. Next up M3 ? |
You guys should hear airplane owners go on and on about oil.
As I understand it the main reason to change synthetic oil is not because it gets worn out but rather water, fuel, combustion chemicals, dirt etc make their way into the oil and have a corrosive effect on the metal parts in the motor. The Oil (mostly additives to the oil) does its best to protect the metal bits from these but at some point its effectiveness declines. In the long run reality always wins. |
fliz Chad Eixenberger Infallible Moderator Location: Grafton, WI Join Date: 02/01/2007 Age: Midlife Crisis Posts: 484 Rally Car: 1988 VW Golf #687 |
On that note, the three to six months sitting around between events is probably worse for the oil than a single rally. |
Do It Sidewayz Chris Martin Godlike Moderator Location: Toronto, Ontario Join Date: 01/15/2006 Age: Midlife Crisis Posts: 567 Rally Car: E-85 powered Impreza |
What oil are you using?
Are you using $35/5 liter Rotella? Or are you using $25 / liter Motul? For the cheap stuff, without a doubt i'd change it every rally. If you are running $$$ stuff, i'd probably stretch it out to 2 rallies... Do you have any idea what oil temps you are running, so we have an idea of how hard you are pushing the oil? Chris |
Yeah the cheap stuff that coast to coast truckers use in their turbo diesels running hard (and sustained going up them Rockies) day in and day out in their motors that cost 80-90,000 bucks... Love that cheap stuff. And Plus Juan on the Oil Temp....Just having a"discussion" on some Mare-kooooooor forum about turbo timers and "I let my engine idle for a minute till the oil temp goes down"... So far, nobody has oil temp gauge, but they know everything else... Oi. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Funny thing is, one of the differences between $$$ racing oil and regular oil is that the $$$ oil has fewer/no additives to deal with the usual oil contaminants like moisture (from sitting and from combustion) and the like. It's assumed that the racing oils are in racing engines that are on a much more frequent service interval than street car "i change the oil once a year whether it needs it or not" style maintenance. So if you're using the $25/liter Motul, I wouldn't leave it in the engine for very long, while the Rotella should be just fine with ignoring it a while. Different oils have different priorities, you know? Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Derek: I use AeroShell, change it every 25 hours, and send it off to Blackstone. And whine a lot about it using a quart every ten hours.
Most GA engines are between 25 and 45 years old and are virtually unchanged from the original designs in the 50s. Self-righteous douche canoe |
I do agree, but at the same time, i feel that $$$ racing oils will hold up better to higher temperatures and not break down as quick. Chris |
True, and that's where it boils down to how the oil is degrading. If it's breaking down from heat, use better oil, or at $25/liter put a better oil cooler in the thing (ex-NASCAR oil coolers the size of a small mattress for $100-200 on eBay, for example...) since bearing materials generally start to come apart at around 300f no matter what kind of oil you're running.
If it's just getting dirty, put a better air filter and/or crank breather setup on it. Or if you have a rotary, change the oil when it gets a quart or two overfull from the fuel wash, so use whatever 20W50 or straight 40 you feel like using, because it'll be only a few hours before it's as thin as the crap in your parts washer... ![]() Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. Edited 1 time(s). Last edit at 05/07/2012 05:11PM by Pete. |
