xratty steering rack on volvo 240
Posted by ryanfay
Re: xratty steering rack on volvo 240
June 03, 2012 12:34PM
Many of the japanese cars are the same 12.5mm thread on the inner rod. I use Subaru impreza inner tie rods on my XR
pist'n broke
kevin zidkovich
June 06, 2012 01:46PM
would you be able to give me a length on these? are they shorter/longer than the stock ones
what could go wrong?
June 06, 2012 03:03PM
Longer, and have fine pitch threads at the outer end. I trim them down about 3/4". I also use a BMW 320i outer tie rod, it has the matching fine pitch threads, and the same pin size and taper
ryanfay
guess
1983 volvo 242tic
June 06, 2012 07:38PM
The volvo tie rod does fit the xr rack
open | download - blarg-006.jpg (127.4 KB)
June 06, 2012 07:57PM
ryanfay
OK so memory worked. (whew)
Ryan check the length of the rack bar----end to end not including the screw in "inner socket assembly" as Ford calls the tie rod assy.
Like scribe a mark on the concrete for the Ford, lay the Volvo on one line and scribe a mark, measure the difference. That's where I was thinking the Ford is just 3/8" longer.
Next look in the female hole---I betcha you like looking in female holes---and see how deep the threads go, then measure the depth on the Ford..
We wanna know if i could take off 3/16 of the bar on each end to make the bar length the same as Volvo....It might take a minute on the lathe.
pist'n broke
kevin zidkovich
June 06, 2012 08:26PM
when i measured it it was more like about 1 1/2-2" we need to lose in overall length. if i cant find anything off the shelf may just remove a section, weld and add a sleeve. the biggest fear i would have is the steel becoming brittle after welding
Edited 2 time(s). Last edit at 06/06/2012 08:32PM by pist'n broke.
June 07, 2012 12:10AM
pist'n broke
On the Length Over All of just the rack bar?
We're not talking the same measurement...
ryanfay
guess
1983 volvo 242tic
June 07, 2012 12:45AM
The xr rack is 3" longer overall. So 1.5" on either side. I donno if there is enough thread on the volvo tie rod for end and lock nut. I'll check tomorrow.
ryanfay
guess
1983 volvo 242tic
June 07, 2012 12:49AM
I managed to box in one notch on the crossmember...
open | download - blarg-005.jpg (103.7 KB)
ryanfay
guess
1983 volvo 242tic
June 11, 2012 12:57PM
The bar is 3" longer. The threads extend roughly .680" into the bar. Oddly, the passenger side hole is drilled in almost the length of the bar (its hollow). Does this help?
FYI only thing better than looking into a female hole is sliding my mic in there (for measurement purposes ofcourse).
nohbudi
Kiriakos Kalpakidis
September 23, 2012 12:30PM
Updates?
pist'n broke
kevin zidkovich
September 23, 2012 08:51PM
yep, figured it would be easier to put an xratty rack in an xratty... just bought this
open | download - xratty.JPG (83.2 KB)
nohbudi
Kiriakos Kalpakidis
September 23, 2012 09:58PM
Yea, I found a shell for $400... Sadly classing a xrat to run with volvo power gear sounds less than awesome, and when you buy this many volvo power parts, you use them.
pist'n broke
kevin zidkovich
September 23, 2012 10:33PM
yeah understandable, im kind of at the no turning back point with the volvo too, but the xr popped up in my hometown at a steal of a price, and its 75% done. it'll be another year before the volvo could see a stage. been waiting 8 months on suspension and thats kinda step 1. ill still build the volvo, but ill do it over time and stuff that i was gonna pay to have completed can now be done on my own as i will have something to get out on stage with. plus the xr has all jvab goodies, so i can reuse stuff when the inevitable wadding up of the fist car happens. as for the rack swap it seems like a howe steering quickener is a lot simpler of a solution...
build or buy????
both...
September 24, 2012 12:49AM
pist'n broke
build or buy????
both...
2.6 turns with real good on center feel is good enough..
And its in the car already..
Let's talk on the phone.
