Im search of Navigator
Posted by ChrisKobi
Billyee
Billy Irvin
Re: Im search of Navigator
June 18, 2012 12:20AM
Adam next time i am near yo and your car i would like to try out your intercom
June 18, 2012 07:26AM
I'll be looking for a codriver soon too. My goal is Mt Hood.
let me know! im trying to either codrive olympus or actually drive the rx7 (yikes!). Then mt. hood i want to make as well one way or another.
June 18, 2012 09:07AM
Sump guards are aluminum grinning smiley Most are 3/16 or 1/4in.
Really? Maybe you need to do an internet search on "steel sumpguard." And, of course, you can get composite ones as well.
June 18, 2012 09:30AM
mental note made, thanks!
Max
1983 MKI GTI
June 18, 2012 10:18AM
I was going to post something, relavent to Chris' needs. And I totally forgot what it was. So ill just post up to let everyone know just how little of my mind is left.
Crap, I really cant remember. I had it, clicked reply, poof.
June 18, 2012 12:21PM
Problem is steel is roughly 300% heavier by unit than aluminum and nothing says mundane, nondescript sheet steel is particular stronger than some of the alloys of aluminum coomonly available
Notice we use almost exclusively aluminum wheels.
So with aluminum we can get close on strength, but go thicker, and with that exceed the strength of thinner steel.
1/4" aluminum is the ideal thickness...little point, except as ballast, going thicker----it is a sumpguard, we're trying to prevent puncturing or crushing the sump so we don't pop a motor...
Composites are absurdley expensive, and difficult to make and secure and really for a clubbie don't do anything for the expense that 6061 does just fine. It's nice for the rich guys, but aside from one or two, they aren't here, and it definitely ain't our man Chris here.
Max
1983 MKI GTI
June 18, 2012 12:34PM
Chris, you driving the Focus over?
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
June 18, 2012 12:58PM
Yes!
Also, figured out the sump guard situation. Yes I will pick up some 1/4 aluminum and also the necessary's for securing it into place.
Found a Navigator also, So the ball is rollin' and a plan is in motion!smileys with beer
June 18, 2012 01:12PM
ChrisKobi
Yes!
Run your ideas past some of us'n before you get too deep into it.
There are hosted here lots of photos of good ways to mount things up, and most guys get it really wrong first 3-4 times..
CaliMeatwagon
Dave Miller
Hopefully my 91 745
June 18, 2012 10:28PM
[/quote]Run your ideas past some of us'n before you get too deep into it.
There are hosted here lots of photos of good ways to mount things up, and most guys get it really wrong first 3-4 times..[/quote]
John, on a Volvo could I put the skid plate (sump guard) in the same location as the plastic ones and use the same mounting locations?
June 19, 2012 03:19AM
CaliMeatwagon
John, on a Volvo could I put the skid plate (sump guard) in the same location as the plastic ones and use the same mounting locations?[/quote]
If the sump guard is going to do any good I think it needs to be mounted securely and be supported. I made some mounts like these for the Xratties and they are stout:
A L angle goes between the 2 sides and the leading edge of the aluminum plate nestles into the L with the L forward <----. That was there's no way in the word to catch the front edge of the plate when the car is nose down braking and you stuff it..
The middle of the sump guard is supported with this:
right where we're trying to protect the sump
Here was my pile o stuff:
Comparison real "909" Ford and JVAB "606" version
Front side parts. You can see how the shape directs blows rearward and up into the chassi legs and how it does triple duty as sump guard mount, towing eyelet and jacking point ( you make a thing to drop on the pad of the trolley jack and it has a bar stocking out which nestles into the notch just behind the towing eyelet both sides and yo can lift from there the whole front easy without fishing around under the car)
At the rear we make something like in the MKII Escort book hosted here which you find under "Manual scans".
If you can't find it I'll find it.
June 19, 2012 08:38AM
I assume the L angle is part #6 in the B0-10 drawing there?
Any pics of it in the flesh? (I'm pretty sure I get the idear, but real world pics always help with understanding)
ChrisKobi
Chris Kobayashi
2000 ford focus zx3
June 19, 2012 10:16AM
I was just reviewing This thread, may be helpful.
June 19, 2012 10:22AM
My "L" that runs between the tow plates is a bit more ellaborate, but here is how I utilized Johns parts.
