That is a nice set of ratios.. are the bellhousings integral to the box? Probably on Japanese things.. That makes it a real bitch to deal with. What do they cost in North America, Land of 89% auto-tragic transgressions See I just got a Borg Warner T5 for one of the boys here for $150.. A little tear down, swap input shaft (maybe $75) and bottom gear (seen them for $125) and he has a gearset virtually indistinguishable in ratios from a Evobitchi 5-8, and thats pretty damn good---except for the overdrive 5th is taller---which works out good when going to a short final drive like 4.3 or 4.56/4.88 His 5th will be still OK for the long transits we sometimes have. I've done 55 mile transits before. So 1st thru 4th or zero to about 120 mph, then 5th for doodling all comfy down the transits. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
JohnLane John Lane Junior Moderator Location: Lynden Washington Join Date: 01/14/2006 Age: Possibly Wise Posts: 725 Rally Car: The Fire Breathing Monster |
Keep it N/A and mostly stock while building that end of the world turbo motor for when that can be fitted to the rallycar..... Getting out there and getting sideways is fun even if not going particularly fast.... Big thing is getting seat time. More important then burning through your cash for the engine is having the shell properly prepped for when it happens as there those who have.... those who will... and having suspension that WORKS and brakes that WORK every time! Choose well. Dave Clark installed the rollcage kit that JVL sourced for me many years ago. Has saved us and the car several times.
Al he's going to give it a Turbo motor in the future.... Turbo motors make HUGE torque. I chose a 3.0 final drive for my turbo six that has .... Count 'em..... Four ratios in the Nascar dogbox. Long legs to go along with a lot of torque.
As soon as it makes any torque it will be breaking axles. Weld it up for N/A use and fit a spool to the 8.8 or find the Toyota diff that JVL speaks of as having a really nice Limited slip if it is all that. I've not used it.... Love me spool for how consistent it is.
+ the reality that the Volvo gearset will break third gear or a mainshaft if it has an overdrive with anything more then standard Naturally aspirated power as soon as it finds grip.
True words these are! JohnLane Overkill is consistently more fun |
IIIRII Glenn Stewart Elite Moderator Location: Waiuku NZ Join Date: 05/22/2012 Age: Ancient Posts: 19 Rally Car: To many to list here |
John, the bellhousing is like a nissan box, NOT a w55 /57 t50 toyota type, so you cant just unbolt it and bolt it onto another bellhousing.
Most hibrids have a mating of the bellhousings tig'd (cut and lined up and welded) The Hilux / Supra LSD is complete crap, I wouldnt recommend them to anyone. They are friction only and have no ramping and rely soley on fixed clamping pressure. |
As I 99.9% knew it would be, everybody has been doing that.. Another reason we like the T5 over hear. Modding a bellhousing is easy
Would go all black and white and say its COMPLETE crap. It's strong and its cheap...and the things are easy to shim the hell out of.. Of course, no debate a nice rampy diff is way better, used one since 1985 in my old Saab, LOVE IT. Nice all steel unit based off the GKN "Salisbury" diff for MkII escorts..some plates and discs and cross shafts and 4 pinions but different splines for the side gears. But the first step is something and a whole diff and a good ratio with a OK diff that is shimmed up for $35-150 is better by a mile than an open wimpy diff with 3.64 and that's it... If a guy recovers from the "whole car build" costs, then he can swap in a nice diff with ramps into the housing he has. Only $1200, just money. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
