mavrick211 Jeremiah Hoffman Mod Moderator Location: Port Angeles,WA Join Date: 03/17/2007 Age: Midlife Crisis Posts: 7 Rally Car: working on it |
rallyspecV Peter Barnes Super Moderator Location: Bend, OR Join Date: 02/10/2007 Age: Possibly Wise Posts: 14 Rally Car: '03 Sentra SER SpecV, 91 Sentra Lemons/Chump car |
We are running a fast little car that once the susspesion is worked out will be a finnisher. The b15 platform is easy to build and easy to find, we have the Ser SpecV version but the 2.0 versions has the same motor with a shorter through so it has a higher Revelimeter and simalar axle and control arms as the ser. Panels are cheap, I would know. Parts are out there and the after market is getting caulght up.
Jeremiah,
In R-A you are restricted from starting in an EVO or an STi; the R-A rules say you start in G2 or P, but there are some exceptions, but I'll bet and EVO or STI would not be excepted. In NASA, you can start in what you like. Since all the events in your area switched recently to R-A sanctioning, you need to follow along with R-A rules OR be prepared to drive south to CA nad east to ID for NASA events until you get enough experience so that you will be past the begineer qualificatoin rules for R-A events. Now, having said all that, there is merit in NOT starting in an EVO or STi. As others have said many times, there is a large wad of $$ tied up in just acquring one of those cars, much more to get it ready for rally and then keeping it running in rallies. Most of the high HP car trannies have limited life in rally use so you have that to contend with. Add all the engine goodies and so on, and it is significantly more expensive to rally these cars. This is just an opinion but I think you will be happier with a simpler, less expensive 2WD car. Regards, Mark B. |
Greg Donovan Greg Donovan Mega Moderator Location: Fargo, ND Join Date: 04/12/2007 Age: Possibly Wise Posts: 423 Rally Car: 95 Impreza Sedan |
mavrick211 Wrote:
------------------------------------------------------- > roger that > > i am looking for a fwd none turbo subie what year > and model should i be looking at > my hope is that if i decide to go to awd and get > another car that i may be able to use some parts > off my 1st subie unless i tear it in 2 if you really want to rally a subaru i suggest getting a AWD impreza. you should look into a 90-94 legacy sedan too. but i think the impreza has a bit more potential and is a couple inches closer to the magic 100" wheelbase than the longer Legacy. and it is getting harder to find rust free legacies. then get a FWD subaru for parts. specifically the transmission and the stuff for mounting up the 2wd rear suspension as it is different than the awd stuff. front suspension is the same. with the changes to G2 in Rally America you can run a EJ22 (or even a EJ25) powered FWD subaru in that class now. you could even put a WRX motor in it later and run in G5 and eventually put the AWD stuff back in if you want after you have gained some more experience. that is to say if you dont wad it into a little ball of scrap metal before then. |
Greg Donovan Wrote:
- > > > if you really want to rally a subaru i suggest > getting a AWD impreza. you should look into a > 90-94 legacy sedan too. but i think the impreza > has a bit more potential and is a couple inches > closer to the magic 100" wheelbase than the longer > Legacy. and it is getting harder to find rust > free legacies. > Aside from the rust issue, which is easy to solve by towing a rust free shell back from the parts of the world they don't salt the shit out of the world, if I had to make a choice I would choose a car on the LONGER side of the supposed "magic" 100" wheelbase. Remember, all the great results from ALL the WRC cars comes in cars with fully adjustable camber, CASTOR and toe both front and rear. So shorter than 100" cars can be made to be STABLE at the speeds the WRC averages (around 55mph/90 km/hr-----except Finland and Sweden) which is pretty close to what most of us average on US roads, and the average is even higher in most Canajian events. So IF YOU DON'T HAVE fully adjustable settings, particularly CASTOR, the we can get stability on the straights by the longer wheelbases of cars like the Legacy, Galant, Xratty, and Volvo 240. Sure the shorter cars like the Impreza feel more nimble, but most of us normal human beings can benefit from the stability on the starights and the little bit slower reactions entering corners at a higher speed MORE than the marginally quicker response. ALL the shorter cars like Escort Cossie, Impreza, and Lancer (and the WRC Corolla) were attempts to optimise the cars for ASPHALT events with lower average speeds and when the WRC cars had insane amount of grip from all those differentials. in short, there can be big advantages for the privateer in a slightly longer car. And has anybody looked at the wheelbases of current Focus, Mitsubishi, Citroen? > > John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
JB JB Marti Junior Moderator Location: Bawlmer, Mahrlin Join Date: 02/16/2006 Age: Midlife Crisis Posts: 94 Rally Car: 1985 Trabant |
------------------------------------------------------- > And has anybody looked at the wheelbases of > current Focus, Mitsubishi, Citroen? for the non-infidels (i guess we're the fidels?!?!): focus: 2.640m wrx: 2.545m 307: 2.610m fabia: 2.462m xsara: 2.555m c4: 2.608m |
JB Wrote:
------------------------------------------------------- > john vanlandingham Wrote: > -------------------------------------------------- > ----- > > And has anybody looked at the wheelbases of > > current Focus, Mitsubishi, Citroen? > > for the non-infidels (i guess we're the > fidels?!?!): Expressed in the system based on some mythological king's thumb: > > focus: 2.640m------103.9" > wrx: 2.545m........100.2 > 307: 2.610m........102.75 > fabia: 2.462m.......96.9 > xsara: 2.555m......100.6 > c4: 2.608m---------102.67" John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
gemorris Glenwood E Morris Junior Moderator Location: Raleigh NC Join Date: 05/02/2006 Age: Midlife Crisis Posts: 40 Rally Car: none yet |
George Doganis and I have been running one in CRS's P-Stock class for the last 2 years with much success. The car needed ongoing development but we've got a great setup now and the car is very reliable. If you want speed, we saw a true 115mph on the rally odo on a 1600 meter straight at Desert Storm. Thats fast enough thank you.
Tom Smith |
gemorris Wrote:
------------------------------------------------------- > never would have guessed the focus was the > longest. Especially never would have guessed it > was longer than the 307. Dude, you said it right: Never guessed. Don't guess. Don't assume. Work from the premise "That worked good" and then track down exactly why it worked good. Work backwards from results to general principals rather than inch forward from fragmentary ideas, whims and desires towards some possibly erroneous conclusion. COPY SUCCESS, don't discover you don't know enough. Choose a car you have information for and can AFFORD TO RUN that is PROVEN OK. Xratty 102.7" wheelbase Volvo 240 104.1", 103.9" ?? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
tedm Ted Mendham Ultra Moderator Location: NH Join Date: 02/17/2006 Age: Ancient Posts: 697 Rally Car: once upon a time drove WRX, Sentra, SAAB 99 |
gilbrock Eli Gilbert Ultra Moderator Location: San Diego, CA Join Date: 03/30/2006 Age: Midlife Crisis Posts: 307 Rally Car: 91 Galant, 02 WRX |
gemorris Wrote:
------------------------------------------------------- > never would have guessed the focus was the > longest. Especially never would have guessed it > was longer than the 307. part of the reason is that the focus has such a short front and rear overhang. there is a lot of car in front of the wheels on a 307 and a wrx. |
Untouched Nissan SE-R with manual trans at Affordable Autowrecking, on Martin Luther King Way in Sleezattle.
