mavrick211
Jeremiah Hoffman
working on it
Re: Nissan SE-R
March 23, 2007 04:01PM
roger that
i am looking for a fwd none turbo subie what year and model should i be looking at
my hope is that if i decide to go to awd and get another car that i may be able to use some parts off my 1st subie unless i tear it in 2
rallyspecV
Peter Barnes
'03 Sentra SER SpecV, 91 Sentra Lemons/Chump car
Re: Nissan SE-R
March 24, 2007 12:13AM
We are running a fast little car that once the susspesion is worked out will be a finnisher. The b15 platform is easy to build and easy to find, we have the Ser SpecV version but the 2.0 versions has the same motor with a shorter through so it has a higher Revelimeter and simalar axle and control arms as the ser. Panels are cheap, I would know. Parts are out there and the after market is getting caulght up.
Re: Nissan SE-R
March 25, 2007 08:47AM
Jeremiah,
In R-A you are restricted from starting in an EVO or an STi; the R-A rules say you start in G2 or P, but there are some exceptions, but I'll bet and EVO or STI would not be excepted. In NASA, you can start in what you like.
Since all the events in your area switched recently to R-A sanctioning, you need to follow along with R-A rules OR be prepared to drive south to CA nad east to ID for NASA events until you get enough experience so that you will be past the begineer qualificatoin rules for R-A events.
Now, having said all that, there is merit in NOT starting in an EVO or STi. As others have said many times, there is a large wad of $$ tied up in just acquring one of those cars, much more to get it ready for rally and then keeping it running in rallies. Most of the high HP car trannies have limited life in rally use so you have that to contend with. Add all the engine goodies and so on, and it is significantly more expensive to rally these cars. This is just an opinion but I think you will be happier with a simpler, less expensive 2WD car.
Regards,
Mark B.
Greg Donovan
Greg Donovan
95 Impreza Sedan
Re: Nissan SE-R
April 13, 2007 08:57AM
mavrick211 Wrote:
> roger that
if you really want to rally a subaru i suggest getting a AWD impreza. you should look into a 90-94 legacy sedan too. but i think the impreza has a bit more potential and is a couple inches closer to the magic 100" wheelbase than the longer Legacy. and it is getting harder to find rust free legacies.
then get a FWD subaru for parts. specifically the transmission and the stuff for mounting up the 2wd rear suspension as it is different than the awd stuff. front suspension is the same.
with the changes to G2 in Rally America you can run a EJ22 (or even a EJ25) powered FWD subaru in that class now. you could even put a WRX motor in it later and run in G5 and eventually put the AWD stuff back in if you want after you have gained some more experience. that is to say if you dont wad it into a little ball of scrap metal before then.
Re: Nissan SE-R
April 13, 2007 01:44PM
> free legacies.
Aside from the rust issue, which is easy to solve by towing a rust free shell back from the parts of the world they don't salt the shit out of the world, if I had to make a choice I would choose a car on the LONGER side of the supposed "magic" 100" wheelbase.
Remember, all the great results from ALL the WRC cars comes in cars with fully adjustable camber, CASTOR and toe both front and rear.
So shorter than 100" cars can be made to be STABLE at the speeds the WRC averages (around 55mph/90 km/hr-----except Finland and Sweden) which is pretty close to what most of us average on US roads, and the average is even higher in most Canajian events.
So IF YOU DON'T HAVE fully adjustable settings, particularly CASTOR, the we can get stability on the straights by the longer wheelbases of cars like the Legacy, Galant, Xratty, and Volvo 240.
Sure the shorter cars like the Impreza feel more nimble, but most of us normal human beings can benefit from the stability on the starights and the little bit slower reactions entering corners at a higher speed MORE than the marginally quicker response.
ALL the shorter cars like Escort Cossie, Impreza, and Lancer (and the WRC Corolla) were attempts to optimise the cars for ASPHALT events with lower average speeds and when the WRC cars had insane amount of grip from all those differentials.
in short, there can be big advantages for the privateer in a slightly longer car.
And has anybody looked at the wheelbases of current Focus, Mitsubishi, Citroen?
JB
JB Marti
1985 Trabant
JB
Re: Nissan SE-R
April 23, 2007 07:16PM
for the non-infidels (i guess we're the fidels?!?!):
focus: 2.640m
wrx: 2.545m
307: 2.610m
fabia: 2.462m
xsara: 2.555m
c4: 2.608m
Re: Nissan SE-R
April 23, 2007 08:42PM
> fidels?!?!):
Expressed in the system based on some mythological king's thumb:
> focus: 2.640m------103.9"
> wrx: 2.545m........100.2
> 307: 2.610m........102.75
> fabia: 2.462m.......96.9
> xsara: 2.555m......100.6
> c4: 2.608m---------102.67"
gemorris
Glenwood E Morris
none yet
Re: Nissan SE-R
April 24, 2007 01:15AM
never would have guessed the focus was the longest. Especially never would have guessed it was longer than the 307.
typerr
typerr
Re: Nissan SE-R
April 24, 2007 09:21AM
George Doganis and I have been running one in CRS's P-Stock class for the last 2 years with much success. The car needed ongoing development but we've got a great setup now and the car is very reliable. If you want speed, we saw a true 115mph on the rally odo on a 1600 meter straight at Desert Storm. Thats fast enough thank you.
Tom Smith
Re: Nissan SE-R
April 24, 2007 01:47PM
Dude, you said it right: Never guessed.
Don't guess.
Don't assume.
Work from the premise "That worked good"
and then track down exactly why it worked good.
Work backwards from results to general principals rather than inch forward from fragmentary ideas, whims and desires towards some possibly erroneous conclusion.
COPY SUCCESS, don't discover you don't know enough.
Choose a car you have information for and can AFFORD TO RUN that is PROVEN OK.
Xratty 102.7" wheelbase
Volvo 240 104.1", 103.9" ??
tedm
Ted Mendham
Re: Nissan SE-R
April 26, 2007 12:24PM
B13 (1991-1994 US model, still made for other markets) Sentra wheelbase = 95.7 in. How can millions of Mexican cab drivers be wrong?
The 2007 Sentras apparantly have a wheelbase that is 10" longer.
Ted Mendham
Ted Mendham
www.rensport.net
gilbrock
Eli Gilbert
91 Galant, 02 WRX
Re: Nissan SE-R
April 27, 2007 10:11AM
Prepped SE-R for sale on rallyclassified.com now for cheap
Greg Donovan
Greg Donovan
95 Impreza Sedan
Re: Nissan SE-R
April 27, 2007 10:21AM
part of the reason is that the focus has such a short front and rear overhang. there is a lot of car in front of the wheels on a 307 and a wrx.
Re: Nissan SE-R
April 27, 2007 11:12AM
Untouched Nissan SE-R with manual trans at Affordable Autowrecking, on Martin Luther King Way in Sleezattle.
