Shock absorbers are overrated. So are springs for that matter.
Posted by Doivi Clarkinen
Re: Shock absorbers are overrated. So are springs for that matter.
September 25, 2012 06:48PM
krisdahl
I can't believe that BMW would put that in single shear. Dumbfounded.
Everybody's doing it nowadays. I assume it makes the assembly process faster.
September 25, 2012 07:40PM
krisdahl
Din't those Maz-dog second gen RX7 do that on the bottom rear?
Dirty
Rotten
BASTARDOS!!!!
nick leone
Nick Leone
1982 AMC SX/4 V8
September 26, 2012 04:57PM
I'm not familiar with the normal E36 rear end. Can you guys do something like this:
And....curious if you think what we've done would be enough to avoid a similar fate?
Epic fix btw!!!
Dave,
In the picture is there a crack to the right of the circular plug? on the suspension member?
nick
Nick Leone
Former scca member
September 26, 2012 05:12PM
nick leone
Dave,
nick
I don't think so - it may be casting marks. Found a pic of another arm and it looks like there's a ridge there...so likely just a shadow from my phone cam.
October 02, 2012 09:27PM
Yep. So do most minvans, too. Including HHRs and PT Cruisers, which are mini-minivans. And then there are the (quite literally) millions of Ford twin I-beam trucks with the shock mount just a stud that is sort of plug-welded to the radius arm, which then breaks off after a while...
bknblk2
Tony Wood
83 Citation "Oskar"
October 02, 2012 09:36PM
might want to look into hydraulic bumpstops, the one's you've got put a heck of a dent in the top of your um, wood.
