It's almost as logical as your hip pose regarding email. ![]() My phone is actually in pieces. I am not going to have a phone for a few months... But before then, no, I do not like talking on the phone. Why? Email is more succinct. In person is more personal. I actually get the full conversation via email or in person whereas I don't with phone conversations. And, I think you provide better service than most most of the time. And you're usually a phone call away if it's really important. Grant Hughes Edited 1 time(s). Last edit at 10/12/2012 08:44AM by NoCoast. |
Just got in from dressing up what has been a real pain in the ass since forever (actually the mid to late 90s when Bilstein went from a aluminum seal holder to the current steel one). The clearance between the tubes and inserts is held to around .0015" but the new steel seal holders at the very bottom have maybe 10 tiny little ribs and upon assembly those ribs bump the tube out by about .0005"-.0006" and that means in diameter the tube is 10 sided by about .001 to .0012, so I usually kiss the bumps a bit and open the clearance by a theoretical red c**t hair... You have to. Pretty hard to hammer in an insert that's a thou bigger than the hole in the bushing.. So today I bored some soft jaws so they ran dead nuts true and then with a sharp insert, knocked the tops of those bumps off... Also finished the annoying Subie ears with their horisontal oval 16.5mm x 18.5mm hole on the front, and the 14mm x 16.5mm vertical hole on the other ear. Tomorrow I will cut another 6 strut tops (while the soft kaws are set up for the 40mm inserts) and then welding begins.. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
wvonkessler Wilson von Kessler Mod Moderator Location: Lookout Mountain, GA Join Date: 02/28/2006 Age: Possibly Wise Posts: 1,127 Rally Car: Colts are in Finland; now '87 325i, '89 325i |
Off the shelf Bilsteins until you are on the ragged edge. Don't kid yourself. What a great product. "Talk about drugs. Driving a car like that, going that fast, it’s like all the drugs at once." - Tommy Byrne "Now, Pinky, if by any chance you are captured during this mission, remember you are Gunther Heindriksen from Appenzell. You moved to Grindelwald to drive the cog train to Murren. Can you repeat that?" - The Brain |
