reasonable place to buy fuel line?
Posted by aj_johnson
December 14, 2012 12:54AM
Any suggestions for a reasonably priced place to buy -6AN fuel line? (assuming that is the right size)
Re: reasonable place to buy fuel line?
December 14, 2012 12:59AM
Steel hard line at Napa or similar. SAE unions excprt the transition to flex lines in AN.
If you mean HOSE well that's sumpin different..
IF hose do you NEED teflon inside and purdy stainless weave outer?
December 14, 2012 01:12AM
No, the rules simply state it must be of braided construction
"Any nonstandard fuel line located
in the passenger compartment shall be made of metal or metal braided
construction, with self-sealing threads at all connections, or comply with"
The factory lines are in great shape, but about 2 feet to short. If I'm going to stick with hard lines I'll reuse those and still need a few feet of the braided crap to put the dual fuel pumps anyway
Edited 1 time(s). Last edit at 12/14/2012 01:12AM by aj_johnson.
December 14, 2012 05:28AM
No, the rules do not simply state it must be of braided construction
or metal braided
Just to clarify. OR!
Vorpal_Rally
Stinkfinger Lipschitz
December 14, 2012 09:23AM
A reasonably well stocked speed shop ought to be able to assemble what you need.
It is useless for the sheep to pass resolutions in favour of vegetarianism, while the wolf remains of a different opinion.
William Ralph Inge
TANSTAAFL
SeanP
Sean Lane
2000 Dodge Neon G2, bruised
December 14, 2012 02:53PM
Summit has all that stuff
December 14, 2012 07:09PM
So would any industrial hydraulic shop have single steel braid, often with a Nomex woven cover for flexible lines...for a lot less money.
Now maybe he wants the shiny stainless look, then yeah Summit or Jegs.
brianallmotor
Brian R. Barton
Mazda 323 BP-T
December 15, 2012 07:52PM
teflon coated or the car will smell of gas... right ?
December 15, 2012 08:39PM
brianallmotor
See this stuff? Weatherhear SAE 100R5
Aint gonna stink no stink gas.. But he ain't intending to run HOSE in the car.
STEEL PIPE thru the car, HOSE to the things that get connected...a short bit top the fuel rail and some tank to pump to filter to hard line.
December 16, 2012 12:24AM
Yes, gas will be run through the car using factory steel lines that are in great shape., however if someone knew of a screaming deal on the pretty stuff, I'd be pretty easily persuaded. If the best we got is summit... better spent elsewhere.
Edited 1 time(s). Last edit at 12/16/2012 12:25AM by aj_johnson.
Ian S
Ian Seppanen
1991 Nissan 240SX
December 16, 2012 11:08PM
Amazon.com
I scored a bunch of -6 and -8. 10 feet of each for $60 or so.
I Seppanen, Car #240
b00sted
David Barrett
December 29, 2012 10:23PM
Summit and Jeg's have good pricing on their braided hose. However, steer clear of their brand fittings...Earl's or Aeroquip are the only two brands I'd go with. They're pricier, but they won't seize up like the junk Summit brand stuff did to me on many occasions(with a car that never saw bad weather)
b00sted
David Barrett
December 29, 2012 10:24PM
Here's about 1250hp worth of plumbing in a 2700lb car. winking smiley
December 31, 2012 03:51PM
So shiny!
b00sted
David Barrett
January 01, 2013 04:12AM
That's the great thing about drag cars...They're much easier to keep clean. winking smiley
