OK can you dig up a part number for what you have in front? and even what you have on the rear... And photos of the stuff installed. , piccie worth a thousand words etc You have to have the cars set that high? This is an important one: how much droop travel ? As in when you jack the car, how many inches before the wheels are in the air? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Dazed_Driver Banned Mega Moderator Location: John and Skyes Magic Love liar Join Date: 08/24/2007 Posts: 2,154 |
X Monâ„¢ Matt Rhoads Senior Moderator Location: Oxford, Penna. Join Date: 05/02/2012 Age: Midlife Crisis Posts: 32 Rally Car: The silly seat |
318 fitment (85-84) as he has an early 318'
Fronts: OUTSIDE DIAMETER OF TUBE: 51mm - P 36 136 , 45mm - P 30 128 Rears: B 36 2028 The larger diameter fronts would typically occur by using M20 motored (drei twa fuenf) cars rather than M10s. IIRC, there is NOT a valving change for the heavier cars. The iX Fronts are different, but the rears are the same. -Sorry I've been doing E30s almost as long as John has been bitching about Volvos. |
And now knowing what a whining useless little live-at-home-and -never-finish-a-car-for-6-years-total-wanker you are I would not ever even answered the first question.. But do we really care about one little live-at-home-and -never-finish-a-car-for-6-years-total-wanker? Get off this thread, punk. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Good more experience. Notice how high the car is.. Me seems to recall they usually aren't that high. I also recall that cars OEM replacements have about 125-145mm travel Stimmt mit du? John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Naja nür 145 oder 155mm schlag...zu wenig für schotter und absolut zu wenig für schotter in Kalifornien... Und einstellung zu schwack. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Tree18is Daniel Serna Super Moderator Location: Los Angeles 9121; Join Date: 06/08/2011 Posts: 29 Rally Car: BMW 318i |
Hey just thought, maybe you can answer easier: do you have a measure from say bottom of the knuckle (where the ball joint hits its usually a nice flat surface) up to say the top surface of the top mount? At some point we're going to want to know what the starting point was in terms of OAL.. And a piccie of the relationship of tire to strut body would be nice cause the distance from hub face where the wheel hits to centerline is fixed in old school struts like those or most old rwd cars where the bottom tube is welded into the bottom forging... This is usually a pain im heck weisst du! EDIT. just checked and my list from just a little North of BRD show P36-0135...and vavling 300/120, not bad but that is shown as Clubsportracing patron...and when they say racing, they always mean "roadracing"...like short travel.. Rear they show Bak Clubsportrace stötdämpare 260/120 B36-0604 We need more info. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. Edited 1 time(s). Last edit at 01/03/2013 11:54AM by john vanlandingham. |
The Sport dampers are shorter stroke than that of the HD's. The sports were to be used with "lowering [harshening]" springs, wereas the HD's are for stock ride height. Pretty sure your numbers are for the sport variant. It is my understanding that the HD's used the same shim stack/valving, so rates should be similar. Either way, I agree that the strokes are too short.
As I'm mainly in to vintage AWD BMWs, I don't have a good RWD canidate to measure right now. I would have to go hunting through factory literature to see if that dim is provided. If someone has a "built up" spare boinger, you should be able to pick up this measurement off car. EDIT: Found the spring tables. Dependant upon what was on his 318 vs what is installed, BMW had provisions to gain up to 21mm just in spring swap. This can be coupled with thicker pads, 3mm nominal stock, upto 9mm available, for a total of 33mm of suspension gain in the front. The E34 springs should (Willy Von K - did you ever put the ones I gave you on?) fit the E30 uppers and lowers as well, and are longer statically, as well as stiffer. -M ++ DoublePlus Racing |
Ferdinand Ferdinand Trauttmansdorff Professional Moderator Location: Ottawa, ON Join Date: 12/08/2007 Age: Ancient Posts: 59 |
My E30 is a 325, but a previous owner installed H&R lowering springs and Bilstein Sport shocks. The Sport shocks definitely have a shorter stroke, otherwise the rear springs would fall off their perch at full droop.
It looks 'cool' and handles okay on tarmac, but I'd really actually prefer to have the car back at its OEM height. ![]() |
Whatever John. You form your own delusional opinions of me. And no, frankly I don't give a shit about "all the people you talk to" and what THEY think either. I'm semi convinced they're in your head, or just putting up with your shit for their own reasons.
Anyhow, good luck with your pitch. He's already interested. Its up to you to nail a payment plan and deposit that works for him to get him to say yes! Welcome to the cult of JVL drink the koolaid or be banned. |
Shut the fuck up Timmay and get off this thread. Whatever you wrote. cause that is the only answer to a little trolly boi no matter what you write. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
sometimes i miss my 325IS. Didnt like the steering very much, and was nose heavy feeling, but overall was enjoyable as a car.
