mekilljoydammit Senior Moderator Join Date: 09/22/2010 Age: Midlife Crisis Posts: 336 Rally Car: No rally car yet |
Weeeeell, mebbe having the car not give feedback to the driver worked better when it was all active gizmos. The Imprezda that looked like a Fuckus originally had some multilink fuckery in the back, which apparently was terrible on gravel and got swapped for struts. I won't claim to know the folks in charge, just thought I'd chip in with some stuff I came across and noodled over.
As for aluminum vs iron... given perfect castings sure, but outside of F-1 the engine castings aren't perfect, and there's a lot of excess mass on the iron blocks because you can't rely on the holes being in quite the right place... not that I think any of this is news to you. I know it's not apples to apples, but I did scale an EJ25 I have sitting around (sans turbos and shit which are going to be the same for everything, ish) and it was around 240 pounds, oilpan to intake manifold. I dunno what a 4G63 is, but I'd bet it's a bit more, and from wrestling one around, I'd lay money on the 3S-GTE being at least a hundred pounds more (maybe I should weigh my brother-in-law's spare one some day when it's less cold) In Group N use, I still bet the biggest thing the Mitsu has over the Subie is a homologated engine and turbo that works better breathing through a restrictor... and for that matter, there's the air bypass turbo witchery thingadoodles on the Evo exhaust manifolds too for more good antilag, which is probably on the stock (older ones at least) ones for homologation. Though I dunno. There really are a spate of problems compared to the Evo (I say this as someone with a WRX as a grocery getter, at least it's not a blue one) |
90Alltrac Gabe Grodzicki Mega Moderator Location: the murder mitten Join Date: 01/18/2013 Age: Settling Down Posts: 11 Rally Car: 1990 audi 90 quattro - under construction |
I cant speak for the fully assembled long block but the 3sgte bare block is 80lbs, the crank is ~41lbs and the head is 50lbs Not driving a car like it was meant to be driven to keep it nice for the next owner is like not having sex with your girlfriend so her next boyfriend will enjoy her more. |
If you told me that a Subaru transmission weighed as much as the engine, I wouldn't doubt it. I've never weighed either, just pulled a couple of each out of the trunks of cars. Point being, the actual drivetrain C of G is not that dissimilar, and MAY be actually in the Subaru's favor.
No idea. But, as I'm sure you're aware, cars are complex systems that can't be distilled down to one or two checklist items that determine how good they are. Diffs? Better internal engine geometry (huge Subaru bores vs. Mitsu not-so-huge bores)? Better turbo response with the turbo bolted to the engine instead of a 4' long tube? Better suspension geometry? Pete Remner Cleveland, Ohio 1984 RX-7 (rallycross thing) 1978 Silence is golden, but duct tape is silver. |
Easy, two things 1. $$$$$$$$$$$$$$$$$$$$$$$ 2. $$$$$$$$$$$$$$$$$$$$$$$ Citroen started outspending everyone to win. Ford sorta matched them. Prodrive had an off year and Subaru likely saw what Citroen was putting into their program and said, maybe our marketing dollars spent better elsewhere. |
[/quote] Didn't they just give up when an inline-4 configuration was mandated....Not that they had been competitive in the couple years just before that change anyway... ____________________________________________________________- One. Class -- 2WD www.quantumrallysport.com http://www.facebook.com/home.php?#/pages/Quantum-Rally-Sport/281129179600?ref=nf |
Didn't they just give up when an inline-4 configuration was mandated....Not that they had been competitive in the couple years just before that change anyway...[/quote] I am not aware that the inline is mandated, just max capacity John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I am not sure either but that was certainly talked about when they started moving toward the super2000plus WRC setups at that time. Maybe the boxer format was not ruled out but the rules essentially required a transverse layout with the change to center differential rules which meant, more or less, no boxers... Subaru/prodrive pulled out well before the rules actually came into effect so who knows what their reason was...
