sidewaez
Blake Lind
orange AE86
Front or rear steer?
January 19, 2013 04:27PM
Poll
Front steer or rear steer?
Only registered users are allowed to vote for this poll.
7 votes were received.
Front steer 3
43%
Rear stear 1
14%
Bacon 3
43%
All of my cars have always been rear steer: DSM, AE86, EVO and now the Celica.
But both systems seem to be equally popular all the Subaru's and 240's are front steer.
It seems to me rear steer has more points in pro's column: more protected tie rods, shorter steering column and Toe-out gain under compression/droop.
The only advantage besides circumstantial packaging I can come up with for front steer is that under hard cornering the outside wheels tie-rod is under tension making it less likely to bend from hitting stuff.
What am I missing here? If you were designing a car which one?
Iowa999
no-one of consequence
Re: Front or rear steer?
January 19, 2013 04:39PM
The one thing I loved about the WRX that I co-drove at autocrosses ten years ago was how we could align the car at -1.5 camber and zero toe for the drive to the event, slap the camber plates over during the tire change and have -3.5 camber and 1/4" toe out.
edit: in case that isn't clear, it's an advantage of front steer, but only when you want toe-out when you have more camber
Edited 1 time(s). Last edit at 01/19/2013 04:40PM by Iowa999.
January 19, 2013 04:43PM
Rally= everything dies eventually. Front mount, service is a snap, but chance for tie rod getting dinged is higher
rear mount: tie rods can still die, service/swap plumbing, everything is a bitch.
January 19, 2013 05:08PM
Front steer as John mentioned is easier to service, change parts. Damage results in a toe-in position. Rear steer results in toe-out position. Mostly the steering position is likely a result of design issues with the engine oil pan rather than a handling benefit.
sidewaez
Blake Lind
orange AE86
January 19, 2013 08:12PM
I have noticed that performance oriented front steer racks are easier to find.
John, Adam or Dustin what did you do on the Corolla to run Volvo spindles, run the left side on the right?
January 20, 2013 07:24AM
sidewaez
Toe change with droop hasn't anything to do with front-steer or rear-steer, you can get any kind of bumpsteer you want with either method.
Front steer allows you to more easily put the calipers behind the axle, which is nice for various reasons, and it means that control arm bushing compliance under lateral load tends to make the outside wheel toe out instead of toe in. Negative feedback loops handle nicer than positive feedback loops.
Besides that, though, theory is theory, what's the REST of the car like?
Edited 2 time(s). Last edit at 01/20/2013 07:26AM by Pete.
sidewaez
Blake Lind
orange AE86
January 20, 2013 03:35PM
the car is an 84 Toyota Celica coupe, we'll be using a 2001-2004 Tacoma 2.4l 4cyl "2RZ", it will be turbocharged.
We're not planning on using much of the mechanicals from the original car, so the original layout won't influence the build unless there isn't a good reason to change it.
January 20, 2013 03:54PM
sidewaez
Yikes! when did that happen? You don't think that thing would be fun enuf with just some non-smog cams?
Edited 1 time(s). Last edit at 01/20/2013 03:55PM by john vanlandingham.
John Reed
John Reed
Toyota AE86
January 20, 2013 04:24PM
sidewaez
I just want to be after them on stage, should be a clean line to follow and maybe some
fresh rubber laid down to boot!
John Reed
John Reed Racing
www.johnreedracing.com
johnreedracing@gmail.com
acrane
adam crane
corolla GT-yes
January 20, 2013 08:33PM
Running right on left, etc.
The steering arm gets shorter, higher to match stock Corolla power steering arms.
"I put the hurt on dirt" - adam crane
http://CraneRallyCrew.com
corolla gt-s "Patches"
Op: S.S.
90Alltrac
Gabe Grodzicki
1990 audi 90 quattro - under construction
January 21, 2013 09:49AM
John Reed
sidewaez
any reason you arn't going to just run a 3sgte in it?
Not driving a car like it was meant to be driven to keep it nice for the next owner is like not having sex with your girlfriend so her next boyfriend will enjoy her more.
January 21, 2013 12:15PM
90Alltrac
John Reed
sidewaez
I asked the same and Blake---who is a pretty clear thinking guy pointed out he can pick up these pick up motores for nada hellava lot. Like $150-250 and they are born N/S...
So he and I searched all the data like bore stroke, valve size, rod length, compression etc... and it was clear that just dropping the thing in bone stock would give a killer torquey motor, and just simple "girlie-cams" nothing HOT per se but something a little warm would be hilarious...
Hence my confusion and dismay at deciding to turbocharge the thing...
Like just how much power does a guy need?
90Alltrac
Gabe Grodzicki
January 21, 2013 12:27PM
90Alltrac
John Reed
sidewaez
good point the 3s is kind of spencie....
czwalga
steve czwalga
95 awd celica
January 21, 2013 02:05PM
90Alltrac
90Alltrac
John Reed
sidewaez
Yeah, I run a 3sge, has some pep in the upper rpms, nothing in the lower RPMS. Not sure who decided a transverse engine with awd was a good idea, but thats besides the point.
Maybe ill have to look into this 2rz engine... where can we get them super cheap?
January 21, 2013 02:07PM
90Alltrac
Well they are a superb motor and they are nice and compact, and with the bore of 86mm, they are down in the ideal 85/86mm range that works so well with restrictors cause they stand higher compression...
And they do pop up..
I found 3 at various times in the local pull-a-part junk yards between 2003-2008 and in those days, it would have been about 175 bucks complete.
But all the possible recipients were convinced turning it 90 degrees was too much bother so they got crushed.
I am confused though why Blake wants to make expensive problems for himself just to burn up tires faster...
