Re: Front or rear steer?
January 21, 2013 08:47PM
mekilljoydammit
What do you think the utter collapse of Subies WRC competitiveness stems from?
Since we're offtopic and shooting the shit more than anything. winking smiley
Oh noes this is as serious as a heart-attack!!!
I think it's kind of a lot of things. I got into a chat with someone who worked at Prodrive, who said that the move to Sachs dampers in '05 killed driver feedback,
wait a second.. I read an extremely long interview with the Belge Christian Loriaux when he was still head hero at Pro-drive and the "new" Dodge Neon version was the thing, and there he said quite clearly that "all the systems on the car are too complicated for (pea-brained children ) drivers to understand anything so ---(in essence) I have to trust all the data, and have the cars set up like i say and they should just (shut up) and drive"
It was abundantly clear that he was uninterested in driver feed back....
and the new style body had all sorts of issues with the rear geometry.
That is mighty suspect, the rear was completely conventional, what could be wrong with long links...he (designer Loriaux) had been there for 10 years, all the the glory days with McRae.
I think that Prodrive may have been leaning on fully active diffs for tuning more than the other teams, so when they got banned they had a bunch more work to do to make up the gap and that hurt them even more.
that was 06 and Subie seemed to be struggling but you're right 06 and he was way down with only 3 2nd places worth mentioning..and that was it
At the same time Ford and Citroen were stepping up their game.
Ford hired Loriaux starting 02 season
Layout-wise... I dunno. Yeah, the engine's hanging out there farther, but it's not like an Audi I5, it's a short little thing and it's aluminum.
Ain't that short and its way way wider and there's a lot of aluminum.. Aluminum is roughly 1/3 the weight but for strenth you use 2-3 times the thickness, and there's a lot of that engine...
Whether that beats a cast iron thing and transmission in front of the axle centerline but not as far forwards, I dunno. Ford put a lot of bucks to moving the transmission guts behind the axle centerlines back in the day on the Fuckus.
Yes the first version, but they went to conventional with the 0 something model.
seems what everybody does is tilt the engine rearward so the weight is more over the axles.
I prefer the YB arrangement but apparently the production engineers didn't or something, go figure.
Well I do too but that's because I, a mere schmuck, can afford one and as a stock engine, its way stronger than any other with a nice steel crank, steel flywheel and good forged pistons...and its a drop in deal in the right car.
mekilljoydammit
No rally car yet
January 21, 2013 10:03PM
Weeeeell, mebbe having the car not give feedback to the driver worked better when it was all active gizmos. The Imprezda that looked like a Fuckus originally had some multilink fuckery in the back, which apparently was terrible on gravel and got swapped for struts. I won't claim to know the folks in charge, just thought I'd chip in with some stuff I came across and noodled over.
As for aluminum vs iron... given perfect castings sure, but outside of F-1 the engine castings aren't perfect, and there's a lot of excess mass on the iron blocks because you can't rely on the holes being in quite the right place... not that I think any of this is news to you. I know it's not apples to apples, but I did scale an EJ25 I have sitting around (sans turbos and shit which are going to be the same for everything, ish) and it was around 240 pounds, oilpan to intake manifold. I dunno what a 4G63 is, but I'd bet it's a bit more, and from wrestling one around, I'd lay money on the 3S-GTE being at least a hundred pounds more (maybe I should weigh my brother-in-law's spare one some day when it's less cold)
In Group N use, I still bet the biggest thing the Mitsu has over the Subie is a homologated engine and turbo that works better breathing through a restrictor... and for that matter, there's the air bypass turbo witchery thingadoodles on the Evo exhaust manifolds too for more good antilag, which is probably on the stock (older ones at least) ones for homologation. Though I dunno. There really are a spate of problems compared to the Evo (I say this as someone with a WRX as a grocery getter, at least it's not a blue one)
90Alltrac
Gabe Grodzicki
1990 audi 90 quattro - under construction
January 21, 2013 10:15PM
mekilljoydammit
I cant speak for the fully assembled long block but the 3sgte bare block is 80lbs, the crank is ~41lbs and the head is 50lbs
Not driving a car like it was meant to be driven to keep it nice for the next owner is like not having sex with your girlfriend so her next boyfriend will enjoy her more.
January 22, 2013 06:21AM
Sure, but how much forward of the axle centerine? About half the width of the motor to the center of the crank... The block is say 6 or 6.5" wide...
And weight---a LOT more??? I forget what a whole 4g62 weighs but its is a LOT lighter than a YB Cosworth....crank is much lighter, rods are lighter, pistons are lighter, and the block being narrower and shorter has to also be a LOT lighter than YB... but compared with EJ I can't say..
If you told me that a Subaru transmission weighed as much as the engine, I wouldn't doubt it. I've never weighed either, just pulled a couple of each out of the trunks of cars.
Point being, the actual drivetrain C of G is not that dissimilar, and MAY be actually in the Subaru's favor.
No idea. But, as I'm sure you're aware, cars are complex systems that can't be distilled down to one or two checklist items that determine how good they are. Diffs? Better internal engine geometry (huge Subaru bores vs. Mitsu not-so-huge bores)? Better turbo response with the turbo bolted to the engine instead of a 4' long tube? Better suspension geometry?
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
January 24, 2013 12:54PM
Easy, two things
1. $$$$$$$$$$$$$$$$$$$$$$$
2. $$$$$$$$$$$$$$$$$$$$$$$
Citroen started outspending everyone to win. Ford sorta matched them. Prodrive had an off year and Subaru likely saw what Citroen was putting into their program and said, maybe our marketing dollars spent better elsewhere.
Josh Wimpey
Josh Wimpey
Sneak the Golf
January 24, 2013 01:30PM
[/quote]
Didn't they just give up when an inline-4 configuration was mandated....Not that they had been competitive in the couple years just before that change anyway...
One. Class -- 2WD
www.quantumrallysport.com
January 24, 2013 02:55PM
Josh Wimpey
Didn't they just give up when an inline-4 configuration was mandated....Not that they had been competitive in the couple years just before that change anyway...[/quote]
I am not aware that the inline is mandated, just max capacity
Josh Wimpey
Josh Wimpey
Sneak the Golf
January 24, 2013 03:58PM
I am not sure either but that was certainly talked about when they started moving toward the super2000plus WRC setups at that time. Maybe the boxer format was not ruled out but the rules essentially required a transverse layout with the change to center differential rules which meant, more or less, no boxers... Subaru/prodrive pulled out well before the rules actually came into effect so who knows what their reason was...
One. Class -- 2WD
January 24, 2013 05:10PM
Subaru stopped caring well before the spec gearbox was announced, though.
