vbares Vittorio Bares Ultra Moderator Location: Londonderry, NH Join Date: 04/10/2007 Age: Ancient Posts: 413 Rally Car: Audi 4k (3b conversion) |
You have to mod the floor a wee bit for it to fit.
I also modded the support brackets so I could move the thing back about 1/2, allowing the spares to fit without having to fight them in/out. This also required moving the tank stop behind it. |
DirkaDirkaJack Jack Russell Professional Moderator Location: Downtown Seattle Join Date: 06/05/2008 Age: Midlife Crisis Posts: 206 Rally Car: phil's GTI |
i did something kind of similar. when i got the rabbit the OE fuel pump crapped out and it was under the car in a really hard to access spot. I decided to install two aftermarket pumps in the passenger compartment, in a box, under the spare tire.
i only had to fab two sides of the box, since i used the spare tire well. be warned that if you use all AN stuff it will be super expensive. like, i could of bought another mint rabbit for how much i spent on this fuel system.... ![]() the line up top is from the OE tank into the wheel well, and the line on the bottom is the pressure line exiting. i also put a shut off on the line right after it exits the tank. i would recommend that, if you ever have to work on your fuel system and you happen to have a full tank of gas, you will be happy you have it. ![]() here you can see the box under the spare. it still needs a lid, but that is easy, i am sure i will get around to making it the night before the first rally of the season at 2am... ![]() i also put the fuel pump switches there on the panel on the left. i thought it would be a cool spot for them, but after getting some good testing this weekend (as good as possible with the snow on most roads) i think the switches need to be moved to the dash. Edited 1 time(s). Last edit at 01/22/2013 11:38PM by DirkaDirkaJack. |
Copy that - I like it! I was pricing AN stuff last night - without the hard lines looks like I'm at $150 or so - saw this from one of my sponsors - that after pricing, banjo's, crush washers, hose ends a Tee and 2 lines will actually cost less than all those put together (they're also a sponsor). 034 Dual Fuel Pump Rail Switches on the dash - that's where mine are as well - I like to go from one to the other every other stage or so, just so I keep them moving and I know they're working. |
OjNK Gordon Sleigh Godlike Moderator Location: Halifax, Nova Scotia Join Date: 12/09/2012 Age: Possibly Wise Posts: 56 Rally Car: 2000 Subaru Impreza 2.5RS P4WD |
Hehe, things found around the shop. The shop typically is used for large industrial jobs. It did the job for the test, we cleaned it up later. Atlantic Canadian Region Rallysport: http://www.rallyeast.ca - Ledwidge Lookoff Rally http://www.lookoffrally.com 2000 Impreza 2.5RS CARS P4WD (Sponsored by Rally-Tech, Great North Performance) |
That could be simplified and done for mere fractions of the $75 but if they're a sponsor like whatever. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
So after figuring out the fittings I need - I priced out anplumbing.com @$242 and discounthydraulichose.com (all steel fittings) @$83.39 for the exact same list...
Anyone see any downside with going with steel (besides the incredible weight it would add ![]() Particularly the shut off valve (my thought is to drill the handle and safety wire it open). |
aj_johnson A.J. Johnson Junior Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
20ft SS tubing
Saw there was Aluminum tubing as well, but have read that the alcohol in modern pump gas makes the AL very brittle. I wasn't real cool about the $2.50/ft though - I'd expect I can find regular ol'steel down at my hydraulic shop for much less. |
Well, I bought a bunch of junk (some 2-wire hydraulic fittings I'll never use - very stout!), anyway here is the result after buying a few more fittings from my local guy (about the same rates as the discount internet dudes, but without the shipping!)...
Any suggestions on how to build a top for this? |
