Building a Turbo Duratec. 2.0 or 2.3?
Posted by espacef1fan
Re: Building a Turbo Duratec. 2.0 or 2.3?
February 12, 2013 08:22PM
Hell he could just get one of the 2 2300 cores I already have----if a certain somebody hasn't lost everything or left them out in the rain.
Uh oh. Is he having troubles? Makes me wonder about the deposit I sent a year ago for a set of arms and rear beam. I've been leaving him alone regarding them since I understand how projects like that can take a long time and considering I've been waiting and dreaming of a square rear beam since back in the Patrick McVeigh days... When was that that Paddy was out there and you guys did some rear beam stuff. I'd guess March of 2006. So I've been thinking it was just around the corner for going on seven years now. It's just money after all.
Hope everything's okay.
He's Ok, he just doesn't "want to be a fabrictor, I wanne be a designer".
We're all artists, aren't we?
espacef1fan
Adam Escott
Don't have one.
February 12, 2013 08:33PM
So square beams aint gonna happen?
By the way John I have money ready to go for a supra diff adapter kit.... Would call, but it is a poor connection from Afghanistan...
espacef1fan
Adam Escott
Don't have one.
February 12, 2013 08:36PM
espacef1fan
The plot thickens.
2.3 for about $600 shipped
----OR------
2.0 for $350 shipped.
The plot jsut got watered down. I realized just to get the 2.0 up to Ranger block spec you ahve to buy a balance shaft delete kit for $100. THen a Ranger water outlet($50?) Then you still ahve a HEAVY crank with the balance shaft gear on and less displacement. The savings evaporate quickly.
darkknight9
Kirk Coughlin
Dreaming of escorts and xrats
February 12, 2013 09:43PM
espacef1fan
espacef1fan
The plot thickens.
----OR------
A balance shaft delete kit can be had for $29 from C-F-M The 2.3 Ranger crank is 5.1 lbs less than the 2.3 focus crank.
Kirk Coughlin
espacef1fan
Adam Escott
Don't have one.
February 12, 2013 09:55PM
darkknight9
espacef1fan
espacef1fan
The plot thickens.
----OR------
I understand the Ranger crank is still lighter than the 2.0 crank, as well.
Thats a delete kit I didnt know about, but I would still be saddled with the heavy gear on the 2.0 crank.
February 12, 2013 10:14PM
espacef1fan
it'll happen but maybe with Sean and I doing it since William is uninterested...
Yeah kits too ---half the fixtures at at Williams and I am avoiding driving 35 miles there and seeing my 2 Duratecs what I imagine to be strewn all over missing all the fasteners and miscelaneous bits that all cost money...
espacef1fan
Adam Escott
Don't have one.
February 12, 2013 10:16PM
espacef1fan
Well sooner is better than later(sometime this year hopefully) Otherwise I may be forced to use sometihng other than the Supra setup just to have something that wont spin the inside tire midcorner.. with a stock engine, nevermind the Duratec I am obviously cooking up.
espacef1fan
Adam Escott
Don't have one.
February 13, 2013 11:17PM
Upon further review, the 2.0 DOESN'T HAVE balance shafts. The rod journals are closer to the crank center line, which should translate to a LIGHTER AND STRONGER crank. If its not enough a 10+ MX5 steel crank can add needed strength. The deck height is about 1/2" shorter which is just a little more hood clearance, and a little lighter of a block.
Things are suddenly far less clear. What to do?
February 14, 2013 12:59AM
espacef1fan
first, don't worry about hood clearence, you wont have a tall valve cover and intake pipes going over the valve cover..
Second, you want to do something good? Use the tall block and a 2.0 crANK AND GO LONGER RODS...
Both motors have rod/stroke ratios around 1.62---1.64...
It'll be less side thrust with longer rods, more powerz, less wear..
In the YB it's also about 1.64 r/s... The day the rules allowed it--the onset of "World Rally Car" subset of Group A, Ford homologated rods about 10mm longer and got a much nicer 1.8 r/s...
And a piston with comp hgt of around 30mm, so much lighter reciprocating weight, and reciprocating weight is really worthwhile to think of, screw the maybe 1/2700 increase in engine weight that the block would be as a percent of the whole car
espacef1fan
Adam Escott
Don't have one.
February 14, 2013 06:50AM
I HAVE thought of the long rod motor as well. However, I've yet to price (or find) rods, built for this scenario. I have found decent 2.3 and 2.0 rods for about $300-$400 and pistons for about the same.
espacef1fan
Adam Escott
Don't have one.
February 14, 2013 07:24AM
Also, I disagree that hood clearance wont be an issue. Check out this swap thread:
Duratec Swap into XR- Merkurclub
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
February 14, 2013 12:05PM
Just buy a ranger 2.3L It is configured for RWD. Has a lighter crank and you don't have to mess with a balance shaft delete kit. Plus it is 15% more displacement. Some of the accessories bolt to the head like PS pump.
Also keep in mind that the accessory belt routing relies on some bosses on the front cover, at least depending on what you are running with. I am not sure if the front cover for the 2.0L motor has all of the right bosses to say run a water pump, PS pump and alternator with a Ford belt. Not saying this can't be overcome but its nice to be able to goto Autozone and get the right belt for the motor.
Also, I have a 2.3L in my focus with the balance shaft. I have had no issues spinning up the motor. I actually doubt you would notice the difference other than maybe on a dyno and we don't race on dynos.
February 14, 2013 02:03PM
2.O fwd cover may have trouble sealing..decl height on 2.0 is 216.9mm, on the 2.3 its 231.. Maybe a fat toothpaste like string of silicone might seat it
Correction on r/s on the 2.0: 1.76<------pretty good, was for a long time "the" desirable r/s for compromise between revs and spread in the "old days'
Basic figures
2.0.....deck 216.9....rod c-c 146.25....stroke 83.1 bore 87.5....47mm rod journal
2.3.....deck 321.0...rod c-c 154.78....stroke..94.....bore 87.5...50mm rod journal
Both compression hgt....28.6
Hybrid 2.3 block w 2.0 crank w 28.6 comp hgt. rod must be: 160.85mm
espacef1fan
Adam Escott
Don't have one.
February 14, 2013 04:16PM
Where is a good place to go for custom rods( at an affordable price) ?
February 14, 2013 05:28PM
espacef1fan
ME, OF COURSE.
