SteelSolutions William Timmins Senior Moderator Location: Redmond WA Join Date: 02/26/2008 Age: Midlife Crisis Posts: 648 Rally Car: 3 xr4ti/74 capri/02 bug eye |
I dont need a run down just seems silly to wast money on buying a crank
that already comes in the latter fords, rods pistons and head job is that not more than enough? and save the bucks. or just get the car running as stock everything and go have fun. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
espacef1fan Adam Escott Junior Moderator Location: Fort Campbell,KY Join Date: 02/04/2011 Age: Midlife Crisis Posts: 89 Rally Car: Don't have one. |
darkknight9 Kirk Coughlin Mod Moderator Location: Saint Paul, MN Join Date: 01/08/2006 Age: Possibly Wise Posts: 493 Rally Car: Dreaming of escorts and xrats |
He asked for hypothetical. Opinions. Thoughts. I never give a 'run down' unless someone jumps on my shit for sharing my opinion when asked for and uses false info in an attempt to talk down to me or others. Not a single dollar wasted on parts here. And did they just start using steel instead of a one-piece cast crankshaft in the Ford applications? Ford doesn't seem to agree with your wide statement of a forged crank "in the latter fords". He's got money to burn at the moment. He wanted thoughts. This site has taught me that while forged is more, it is alot more forgiving of youthful mistakes. And that the smaller the bores, the more reliably the block can handle forced induction pressure. Whether or not he gets out and rallies or just putzes in the street... he won't be able to say he didn't know about other options. You make some neat stuff Wil... just "stop with the
Huzzah! Don't forget the balance shaft delete unless you use a ranger block as well. Now do your cage whilst you dream of duratecs. And suspension stuff. Have you bought the book from amazon on the xrat yet? Kirk Coughlin Woodbury, MN and River Falls, WI Quemadmodum gladius neminem occidit, occidentis telum est. |
yep. I have "How to prepare the sierra for motorsport" two copies. one is for use.. the other is for the shelf.
![]() I already have jvab struts, Im going Supra diff, rear suspension needs coilovers but I have nice bushings everywhere. I have turbopoop rear brakes and Es-Vee-Tee Cuntour rotors with PBR calipers up front. Not impressive, but better than stock. I have all kinds of other random goodies too, including a V8 T5. |
really would like to see a worthwhile bell housing for the duratec to T5
I was told by a open wheel builder that the latter model 2.0 where all forged cranks.
all fords v6 for a fact are i have mixed alot of the v6 info in my head. I like the idea v6 personaly more bosted non bosted never have to take it apart or anything and get more than enough power. I did not mean to sound like a Cock im just bitter i help people every day finish or start there projects and i dont have time to make my go fast car. so working out a way to have the power i want drop in with out putting a built motor in sounds sooo good to me. also I wrote a bell housing guys in UK and they all have ford t5 patterns because the cosworth box and said little extra would go one for t5 and the extange rate is not bad right now. street car forged would be nice so you can get some rpm and alow to make up bad shifts and mild gear ratio gaps even in the v8 t5. TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
Ive thought of the Mustang V6 and trans. It is mighty tempting, but not quite inexpensive enough for me yet. If I was going to install a v something in there, it might be a V8 (LS-something..) just for the cost per performance ratio(and sound..) I personally chose the 4 cylinder Duratec because it simply fits the car's personality better in my opinion.
Also, where are these T5 bellhousings you are speaking of that fit the duratec? Ive searched high and low myself. As for my T5 its out of a 94 Mustang GT. Im hoping I can get the stock bellhousing to work with my tunnel so the shifter is farther back. |
mke723 Mike Lindenfelser Mega Moderator Location: Minnesnowta Join Date: 10/17/2012 Age: Midlife Crisis Posts: 154 Rally Car: 1995 Impreza L |
The rally worx, orange rental Capri has a cosworth built 2.3 duratec , running a t5.. I think it's a t5world class..Not sure where Matt sourced the parts to link it up...I suppose I could ask him... It makes 220-250 hp... And revs to 9k.. It's the one mike hurst rents and had at LSPR
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to. |
The rallyworx, orange rental Capri has a cosworth built 2.3 duratec , running a t5.. I think it's a t5world class..Not sure where Matt sourced the parts to link it up...I suppose I could ask him... It makes 220-250 hp... And revs to 9k.. It's the one mike hurst rents and had at LSPR.
Quad 4 rods. They make an ok product.. BUT it cost $500. Then you STILL have to knock a hole in the thing, and come up with your own clutch release setup. Additionally you STILL do not have the ability to install a SFI approved bell housing (or something equally as safe).
I think the Mustang V6 may be the next swap motor for some unspecified car, that I dont own yet once it gets cheap enough(which shouldnt take long...it is after all..ONLY a weak V6....compared to the V8 anyways.) |
Wha!!! SFI approved bell housing? The idea of that disgusts me. They make an ok product but it also happens to be the only product I've seen end up in running and driving vehicles and available for order and tested a proven. (see aforementioned Capri) Maybe the design is intentional. If you can't fabricate a clutch release setup you don't possess the skills to fabricate the other components required to make a RWD Duratec powered vehicle? ![]() Grant Hughes |
http://www.rwdmotorsport.com/
i emailed them a wile back about making it fit the ford t5 they have there and they said it would not be a big deal i dono if that means big deal if you order 5 or 10 of them i dont know. but they are around 260 us right now for a bell housing. the v6 i speak of is in the same family as the mustang but its the 3.5 out of everything else and its sooooooo cheap there are 2600 on car part just from the edge mkz and taurus. they all make 310 tuned with all stock componets intake cast headers. the only hard part would be the water passage in the back of the motor i plated mine and going to weld a bung going out the side. not trying to push the just some info of what its in and what not the only thing i dont like about it is the waterpump is inturnal ![]() is less than the price of getting a water pump put in any new car hahaha. 2007–2010 Ford Edge 2007–2010 Lincoln MKX crossover SUVs The engine produces 263 hp (196 kW) at 6,250 rpm and 249 lb·ft (338 N·m) at 4,500 rpm in the following applications: 2007–present Lincoln MKZ 2008–present Ford Taurus 2008–2009 Ford Taurus X 2008–2009 Mercury Sable 2009–present Ford Flex 2010–2012 Ford Fusion Sport The second generation of the Duratec 35 with TiVCT produces 285 hp (213 kW) at 6,500 rpm and 253 lb·ft (343 N·m) at 4,000 rpm in the following applications: 2011–present Ford Edge 2013–present Ford Taurus The engine produces 290 hp (216 kW) in the following applications: 2011–present Ford Explorer TSSFAB.US No HYPE just parts!!!! And check us out on Facebook!!! ![]() |
