100 Acre Wood Discussion
Posted by MConte05
darkknight9
Kirk Coughlin
Dreaming of escorts and xrats
Re: 100 Acre Wood Discussion
February 22, 2013 12:03AM
John Reed
[url=
]FY Racing Shakedown Video - with MoTeC data[/url][/quote]
Neat video!
Kirk Coughlin
TylerEstes
Tyler Estes
E30 325E "practice girl"
February 22, 2013 10:26AM
Good luck with lodging.
Best bet is Rollins or whatever that town is called. Might have trouble finding a room there even. Just hook up with some local grade D slut and stay in her trailer for the weekend.
I was going to go, but the weather sucked and I drive like Tyler Estes. Which means that I spent almost 6 hours in my car in a ditch. And also, puked 11 times in 6 hours today. Hopefully life won't get in the way by the time the Perryville rally is held. smileys with beer
Why do you even need brakes? Are you some sort of pansy or something?
mke723
Mike Lindenfelser
1995 Impreza L
February 22, 2013 11:49AM
John Reed
Crazy weather here, we will see what tomorrow holds! "Snow" still on the ground here but warmer than expected so maybe it will at least not turn into a big mess of ice overnight.
Spent the day doing last minute prep and setup on the FY Racing Subaru, thankfully in a warm garage!
For those not on Facecrack, here is a video I did using footage from one of the GoPro cameras the FY crew had on the car and sync'd it up with the MoTeC data I had for the stage. This was the official shakedown stage we ran on Wednesday.
[url=
[/quote]
its nice seeing the speed-o-meter, and gps of the road, too bad no co-driver reading the notes, but that can happen next time. I saw the wiring on facespace a few months ago.. looked amazing.
question for ya... does the didgital cluster thats in the car require any special computer of sensors? or can i buy one and wire it in the suby harness? any plug and play units?
I be sorry as a muthafucka I did, still sorry I did n' hustled ta peep what tha fuck I holla'd a lil' bit better, or at least try to.
February 22, 2013 02:16PM
mke723
Does it make the car quicker? I don't understand the desire? Does it make the car more reliable, or stronger?
Or do you just have LOTS of money laying around burning a hole in your pocket?
LOTS.
John Reed
John Reed
Toyota AE86
February 22, 2013 02:21PM
mke723
John Reed
[url=
[/quote]
question for ya... does the didgital cluster thats in the car require any special computer of sensors? or can i buy one and wire it in the suby harness? any plug and play units?[/quote]
The digital cluster is a standalone data acquisition unit, so while it doesn't require any "special" sensors, it does require sensors for whatever you want to monitor. On most modern cars we can also get a lot of data off the OEM CAN BUS if it is still running mostly stock electronics.
John Reed
John Reed Racing
www.johnreedracing.com
[email]johnreedracing@gmail.com[/email]
February 22, 2013 03:13PM
Oh, I fully understand the desire. It's cool! I want one too! grinning smiley
I don't $2000 want one, though. (or whatever they cost)
John Reed
John Reed
Toyota AE86
February 22, 2013 03:15PM
mke723
LOTS.
Quit being so grumpy JVL, and get back to work on my fitty's. :-)
The best way to save money and keep the rally car reliable is leave it in the garage and go play golf or something.
John Reed
John Reed Racing
February 22, 2013 03:19PM
Hey, any people who are at 100AW going to be on the friday night rally chat tonight?
February 22, 2013 04:56PM
John Reed
mke723
LOTS.
Not grumpy at all. Trying to learn why people make decisions they do. We learn by asking, not assuming...
In a competition when budget is presumably limited, it seems the number 1 priority is to make dollars yield something tangible like a more reliable car or a quicker car so the results per dollar spent are higher, and the fun quotient is higher..
But what da fawk do I noez?
February 22, 2013 04:59PM
I don't think it would make the car quicker, but with the right sensors and with the right testing and with the right analysis it could help make the driver faster.
A friend, and engineer, sensored the shit out of his car and identified more than a couple of bad habits that were slowing him down. (Specifically I recall braking too early and too hard, leading into back on the gas then braking again going into corners.)
Could the same have been learned by simply watching in-car with extreme attention or taking a faster - and sharing type - driver for a ride? Almost certainly, for most. Some, on the other hand, see great things in graphs and numbers better than they do in the 'real' world.
Thinkig about it though, depending on the car, it could make the car quicker.
Well thought out custom alarms and shift lights could help you get the max performance out of the car. An example would be setting shift lights based on peak torque on the bottom of the gear split. Depending on the dash, I think you can set shift points differently based on the selected gear.
That's all money, of course, since you'll need to dyno the car and have a good understanding of where the power and torque really are.
Again, setting alarms to custom values may not make something more reliable but could help prevent catastrophic failure, making repairs potentially cheaper. Again, you could also set minimum values on sensors so you know if you've hit minimum temps for beating on the car. (not generally a problem in rally I wouldn't think)
There are certainly better ways to spend money on rally that will make you faster. (A driving school as an example) Sometimes boys just want toys. (and for the vast majority here what are rally cars if not toys.)
Edited 1 time(s). Last edit at 02/22/2013 05:00PM by Morison.
February 22, 2013 06:04PM
You and "technology". Hey Morison, almost everything you suggest has one and the same answer: Could it have been learned by OPENING HIS EYES and being HONEST about what he is doing? LOOKING at the road, LOOKING at SS times and results?
Buy this buy that, video cameras, Data logging, your absurd vehicle tracking idea.
All this bullshit stuff just to paly wanky wanky car rally for fun now andf then...
Jeeezuz.
Less is more.
The constant imagining, searching, wondering about external "solutions' to things ultimately inside people's heads--the pattern, indicates faulty thinking...
Whatever, I have to go make chips out of aluminum for a fellow in Quebec...
February 22, 2013 07:11PM
I guess you missed it, but I essentially said that.
Here it is again:
Looking at SS times can only tell you so much - the general pace gap - and doesn't really tell you where you're losing time.
Besides, people tend not to be honest with themselves about their own mistakes and tend to remember things in the absolute most favorable light.
Once again, you're ascribing ideas and comments to me that I didn't, and wouldn't, make. I never advocated buying data logging equipment nor would I for the average person. BUT, my mind is open enough to not only see that some people would see some value in it but also that technology can bring advantages to the table that can result in real, measurable, improvements.
Do I advocate people use in-car cameras tied to the intercom and review their in-car videos? Absolutely.
For (well) under $500 you can get a camera that will record what you actually do on stage and will let you listen to the notes and their delivery. It's probably the best tool out there for reviewing performance and having an honest look at what you've done and seeing where you can improve.
Example: I had a driver give me shit for not calling a note in the middle of a stage. Reality was that I not only called it but had also repeated it. Reviewing the in-car footage not only got me an apology, it also helped us figure out why he missed hearing the calls in the first place.
Another example: Another co-driver was able to make a side-by-side stage video between his car and the car that won the stage by a few seconds. By watching it they saw where they were losing time to the other team and where they needed to focus their attention.
Um... My vehicle tracking idea? I don't even know where to start with this one.
- Not my idea, for one, although I was one of MANY people who wanted to see what was out there for vehicle tracking and car-to- car communications.
- If it were MY idea, why are there at least four different systems in use globally? Tracking is clearly something that is important to rally organizers world wide.
- The push to look into systems was driven by several competitors as well as organisers and the CARS board.
- Competitors have proven that they can't handle simple triangle rules on their own, so automating it to a certain degree needs to be looked at.
(I'm still STUNNED that we had nine cars drive past a car on its side, in the middle of the road, with no triangles or OK sign at one event and a dozen cars drive past a triangle at the edge of a significant exposure with no crew and no OK sign at another)
- If you don't look at what's available and if you don't ask questions then you're just left to your own ignorant assumptions. We (several of us) looked for tracking solutions, asked the competitors what price point THEY think is reasonable and have a much better idea of what is - or isn't - possible.
- The cost of using the RallySafe system is about the same as half the cost of a single new rally tire per event. Yes, it's death by a thousand cuts as each cost is added on but Martin and Ferd spent 4 minutes in a snowbank that could have been avoided - the other choice would have meant body work on two cars well in excess of the $120 for a system that WOULD have made a difference.
- As someone who has run rally events and who has had to deal with near fatal accidents and with cars that have been confirmed as 'missing' - as in unseen by following cars - I can tell you that tracking systems would make my life, as an organiser, much MUCH better.
- If you think tracking, and car to car status communication, is absurd then you clearly have a very narrow perspective of the sport.
Interestingly, when I talked to drivers at Big White, the vast majority thought tracking and car-to-car coms were a good idea. Many would gladly pay and only a couple thought it was a waste of time/effort.
100% agreed. People tend to spend too much time thinking about improving 'the car' without paying attention to what really makes the car fast... the driver.
But, blindly ignoring simple, easy technology to help you better self evaluate performance and behavior is also faulty thinking.
Edited 1 time(s). Last edit at 02/22/2013 07:11PM by Morison.
Ckgtimk2
Corey Kline
Used and abused Mk2 GTI
February 22, 2013 07:54PM
...so back to the rally. Any word on road conditions for cars further back? Are the front runners getting through the snow/ice? Are cars further back seeing any gravel?
Less talk. More rally.
Josh Wimpey
Josh Wimpey
Sneak the Golf
February 22, 2013 08:16PM
My guess is that FY has it not just because it is cool but because it is cool enough to add significant interest to videos they produce and thus value to sponsors who want to capture the attention of the audience they want to sell goods to.... These guys have plenty of marketing experience from touring the world in a band (and apparently plenty of $$$) and have brought that with them to rally. It __seems__ that they have been successful at courting sponsors as a result although none of us knows the details of any of their deals...
Short answer --- Dollars spent to return on investment seems good even if it doesn't make them any faster.
One. Class -- 2WD
www.quantumrallysport.com
February 22, 2013 10:11PM
I like the incar data display, it adds a lot of info to the videos. Not everyone in rally is on a pbj budget.
The tracking systems would be useful also but reality says it simply can't be relied on 100% .
Looks like ACP is leading 2wd and I can't figure out what is goping on with Block. RA still can't get reporting an event right. Imagine tracking systems under their program...
