Brakes
Posted by Racinkid13
Re: Brakes
April 27, 2013 11:04PM
im up. ill shower and head over. about 1.5 hrs. where you at again?
wE HAVE BRAKES.
nEXT BLINKERS
Re: Brakes
April 27, 2013 11:26PM
wE HAVE BRAKES.
nEXT BLINKERS
That's easy. Get a Clyde.
Re: Brakes
April 28, 2013 01:11PM
Max! I think the mushiness has to come from those rear hoses.
Don't know what I was thinking--I am getting more forgetful.
Those things are -4 it seems to me since the fitting was bigger..
That's the ONLY thing out of the ordinary. Master cylinder size OK, fron caliper size: OK.
Rear caliper size: OK, front hoses OK.
Rear hoses BIG and LONG= volume.
Hmmmmmmmmmmmmm.confused smiley
Max
1983 MKI GTI
Re: Brakes
April 29, 2013 07:50PM
I dont know what to do with it. I was told it was supposed to be like the calipers off a mk3. its not. i tried to match up mk3 rear flex lines. didnt fit. i got that hardline/flex line kit from Summit. Pegasus has a line kit for golf, but i didnt want to spend $127 if the stock ones didnt work.
Re: Brakes
April 29, 2013 08:03PM
I thinkin! Gonna go have another ciggie and THINK!
The big deal is: what's the thread INTO the caliper?
I say M10 x 1
------------> How did you terminate the hardline by the rear bulkhead?
What's on the other side of the wheelarch where the fat SS flexie line goes thru?
I have -3 line and some ends here---gonna goo look but gotta see how the harlind from up front ends.
Robert Culbertson
Out of this dumpster fire
Re: Brakes
April 29, 2013 08:46PM
Post up a picture of the rear caliper. The collective VW peeps can probably figure it out.
Max
1983 MKI GTI
Robert Culbertson
Re: Brakes
April 30, 2013 12:23AM
Those look like aluminum mk4 calipers. The hose comes into them at a different angle and the fittings are different... I think.
(runs and checks the vortex=> too much stance, must leave!)
So I checked with google, and they said to look here: Mk4 calipers on a mk2
Looks like they use a banjo, and you might need some "conversion" lines. John can most probably be mostly capable of helping you with that.
Re: Brakes
April 30, 2013 12:41AM
I say M10 x 1
I have -3 line and some ends here---gonna goo look but gotta see how the hardline from up front ends.
er um
Max
1983 MKI GTI
Re: Brakes
April 30, 2013 11:07AM
hard line into adapter into flex line
Max
1983 MKI GTI
Re: Brakes
May 13, 2013 02:14PM
Found a couple flex lines that worked. Changed it the folling setup.
http://i4.photobucket.com/albums/y121/racinkid13/IMAG0031.jpg
now its just hardline straight to the flex line. the braided was larger then these. Havent bled the lines yet to see how they feel. Im thinkin of cutting an old radiator hose up and wrapping both sides.
simoniac
Simon Wright
Rally Spec Focus
Re: Brakes
May 13, 2013 03:03PM
Not sure if you have enough hose there to allow decent flexing through the entire range of suspension travel. Did you jack the wheel up to see how much tension it's under?
Simon
Simon Wright
Owner/Driver USUK Racing - Home of the USUK Racing LED Light Bars!
North America Rally Map
Max
1983 MKI GTI
Re: Brakes
May 15, 2013 12:45PM
ive cycled it as much as i can using a jack and ratchet strap. seems to be just enough. im sure ill need a second set of eyes to make sure.
Towona
Tony P
MK2 Golf
Re: Brakes
May 28, 2013 10:38AM
I would recommend you get two of these brakelines (or similar), bend them back straight, then bend as needed to get them to travel up the rear arm and into a short female/female flex hose that spans from the arm to the body. Then attach your hard brake lines to that flex hose.
W0133-1620649
Runamuck Rally
