Max
1983 MKI GTI
Brakes
February 12, 2013 09:26PM
Im missing something here.
I replaced the stock master cylinder with a new stock.
I ran new stock size line. two from cylinder into one, into cabin, thru manual valve, then split back into two to the rear new disc brake set up. Im bleeding, as ive seen described on here. Yet im getting crap for pressure at the rear. one side is no grab when peddal is depressed, other side has minor grab.
What am I missing? Ive found no leaks. I have two manual valves and tried both.
Re: Brakes
February 12, 2013 10:10PM
Did you plumb the handbrake correctly---in into out and out outta out?
Piccies.
Re: Brakes
February 12, 2013 10:53PM
What JV is saying is a lot of the handbrake masters are counterintuitive for plumbing. Flip flop your "in" and "out" and try again.
May also just have to crack bleeders and walk away for a while and let gravity do its thing....
Robert Culbertson
Out of this dumpster fire
Re: Brakes
February 13, 2013 01:27AM
Same as above, check the plumbing: are there any high spots where air could get trapped? Did you bench bleed the MC before install?
When you tee'd your lines together, how were the lines coming off the MC? They rears on the mk2 come off the front. You have to tee the right and left line together, or plug one side. This shouldn't really affect pressure though, as the bore is the same for both pistons in the MC.
I use a one way valve bleeding system, like a "speed bleeder" but universal, or the good old vaccum pump. I usually can't get anyone that knows how to slowly pump a brake AND let it return all the way.
The Mity-Vac is awesome becouse it will/can pull air out of the system that has been trapped somewhere.
Max
1983 MKI GTI
Re: Brakes
February 13, 2013 02:37PM
Ill try flippin the valve around. Didnt try that. Figured in was in and out was out.
I have a lil hand pump bleeder that i was using.
Re: Brakes
February 13, 2013 03:12PM
Which hand brake do you have? If it is the CNC one, pull the brake handle all the wy to the stop, and it will bypass fluid for bleeding. That was the trick to finaly get my rears to bleed.
Max
1983 MKI GTI
Re: Brakes
February 13, 2013 04:40PM
its not a handbrake, its a manual valve, http://www.summitracing.com/parts/ssb-a0707-1
Max
1983 MKI GTI
Re: Brakes
February 13, 2013 04:41PM
Oh, and the way this master was plumbed, was the rear came off the bottom of the master and the fronts from either side of it. And yes, i went thru bench bleeding steps i looked up on the interwebs.
Max
1983 MKI GTI
Re: Brakes
April 26, 2013 07:21PM
Hey John, Robert? Either of you going to be around this weekend? Could I bring the GTI by and have you tell me what the hell I did wrong with these brakes? I found a minor leak. But i still have no damn brakes. My smart phone is MIA, since monday. So email is the only way to get hold of me.
Ckgtimk2
Corey Kline
Used and abused Mk2 GTI
Re: Brakes
April 26, 2013 09:14PM
Nevermind. I skimmed.
Less talk. More rally.
Edited 1 time(s). Last edit at 04/26/2013 09:48PM by Ckgtimk2.
Re: Brakes
April 26, 2013 09:22PM
There's always alternatives mang, Like HERE. Yeah drop by. Arrive early! I have all sorts of brake lines and fittings and hoses and hose ends...
You find a Cow-driver yet?smoking smiley
Re: Brakes
April 26, 2013 11:31PM
So you are going to drive it with shit brakes? Bad idea.
I wish that I could help you but I'm swamped with work.
Max
1983 MKI GTI
Re: Brakes
April 27, 2013 01:31AM
no. i was gonna tow it to where ever.
no, no codriver.
Re: Brakes
April 27, 2013 10:10AM
no, no codriver.
When ya coming? I'm up and watching the weather. They allege possible rain in afternoon.
Max
1983 MKI GTI
Re: Brakes
April 27, 2013 11:23AM
im up. ill shower and head over. about 1.5 hrs. where you at again?
