Need some help
Posted by CaliMeatwagon
JohnLane
John Lane
The Fire Breathing Monster
Re: Need some help
April 25, 2013 08:44PM
Ken Rogers
No slop in fittings installed in that tin-foil is still fatigue failure even in street-driven cars! tongue sticking out smiley
There is actually a vertical brace that the weld nut is spot welded to.
As you may know the load runs on the surface as tension, and some sort of bracing or gusseting is usually needed to spread the load.
So by bolting the flat of the brace to the surface, the energy transfer is made without stressing the spot welds.[/quote]
I usually get to see them with the nut hanging out in open air with a gaping hole + cracks in the tin.
They sure are flimsy as hell before we go to work on 'em.
JohnLane
