liv3mind
George Frederick
2004 Focus SVT 5door
Neub first post
June 12, 2013 03:01PM
regestered this morning, im a member on focaljet but find the rally area quite lacking in info. anyways finally picked up an 04 svt focus 5door of my liking to start my rally build ive been kicking around in my head for a few years. I plan to make my first event the Porterfield #4 rallycross at Glen Helen on september 7th and 8th. Then hopefully some stage stuff if i can find some within reasonable driving/towing distance (probably desert/primm stages in december if memory serves me correctly) the car sould be going in to be caged late july, between now and then the plan is to get some jvab coilovers ordered up. then wheels/tires and harnesses/seats. Anyone wanna fill me in on how to get the car setup on logbook? i have the nasa/RA specs for the cage for my fab guy, just need to know where to get it signed off after completion. idk what the classes are now but last i checked im wanting to build the car as a gr2 class pos. here is a pic of the car as it sits now.
Re: Neub first post
June 12, 2013 06:21PM
http://www.nasarallysport.com/main/Rally-University
Re: Neub first post
June 12, 2013 07:41PM
liv3mind
pretty color. How many miles on that poor SVT in there? Have you thought about Duratec when that blows its brains out? Those Duratecs are n-i-c-e....uh hum!
RALLYRS
Mike Ball
Nope...I wish...RWD 2 Door Jeep XJ 4.0 5-spd Dirt-o-cross car(we have no grass!)2.3 ZX3 rallyx car(sold)
Re: Neub first post
June 12, 2013 07:45PM
Alright..another Focaljet guy!
Yeah The Jet is a great Focus site..but the rally section grows cob webs badly.
And you're in Socal and have a blue 2004 like me(mines a plain ol' ZX3 with the 2.3 though).
Hope to see you at the #4 at Glen Helen....I'll be there.
You'll definitely get good advice from the guys here.
I hope you post your build here and I'm curious who your cage guy is...my cars just a cone squisher right now but I need to get in on some of that stage rallying thing....
You are making me jealous mentioning the JVAB suspenders-I want to order but have some other things I need to do to my car right now...maybe I can just send a deposit on the fronts for now....payments are good-right John?
Do we want 40's or 50's? Biggerer is betterer in 'Murica-right?
Support your Local North American Rally Forum!!
While they are still around-and get the hell off Farsebook!!
We still have Specialstage & RallyAnarchy.
Post up Here:
https://rallyanarchy.com/phorum/posting.php
and here:
https://www.specialstage.com/forums/forum.php
Re: Neub first post
June 12, 2013 08:09PM
RALLYRS
To both youse guys a note on the 50s: aside from the big increase in weight, the way your (and my Sierra stuff, too and for that matter MkIV Golves) with the strut socketing into the knuckle, there are a couple of problems vis a vis "ear " type struts.
A) the distance from front face of hub to the centerline of the strut socket is fixed and there's nothing we can do about that, it just is...
a) so the age old problem of---with longer travel struts we need longer travel springs and those springs are arf-ully close to the tire as it is with standard 2 1/2" ID coil over springs, which are around 3.5" OD.. In fact to be safe , if using a "real' Focus wheel with ET49-ET52 we probably want a 4-6mm spacer, or a Sierra offset around ET38-ET 40 wheel
So with 50mm insert and a 3" id spring, the problem is a little bigger (remember to think radius, the interfereence problem is only on the one side.)
cool smiley overall length is a big deal because we have to push the whole knuckle down below the whole strut to poke it into the knuckle, then let it rise up
b) this is easier, just some local grindy grindy, the a bit of weldie weldie---and you SHOULD be stitching and doubling up the crossmember where the pivot bolt pass thru so do it, OK
So, so far, this has meant most everybody (Focci and Xratti) have gotten 40mm or 41mm (yeah there's 41 out there too, same 36mm piston internally just a little thick wall--first seen on Sierras--which were a bit heavier than Escorts rwd which used 40s to such good effect.
More later, dinner calls.
liv3mind
George Frederick
Re: Neub first post
June 12, 2013 09:08PM
yeah my fav color, 1 of 48 made in 2004 (eap package) and i hate when people dont use them for what they want. its got 98k on the clock, just serviced timing belt and intake boots etc, im not sure about the duratec swap, its a possibility, although i had my sights set on a high comp itb setup on a spare 2.0 block that i need to source (maybe il find a duratec and try to finagle my head onto it haha). who knows what the future brings, hopefully i can get at least 20k out of this this revving the everliving piss out of it in gravel though.
liv3mind
George Frederick
Re: Neub first post
June 12, 2013 09:11PM
RALLYRS
im gunna try and get it there for sure, my cage guy is a long time friend (5th grade) and former welder/fab guy at "Richer Racing" now he manages "Pure Turbo" in oceanside and helps do fab stuff out of there (by the way the owner of Pure Turbo Jessie is the MAN to see about turbo stuff and advice.
liv3mind
George Frederick
Re: Neub first post
June 12, 2013 09:21PM
im hopefully ordering 5 et38 15x7 T/D pro rally (at that offset they (t/d) have assured me it will clear svt brakes) this week friday, my problem is: i need these beefy as fawk, if the 40/41 will hold up for a year or so im down with that, and prefer them to be relativly bolt on i have not a problem having my fab guy strengthen the stock shite and tying into the cage. but i prefer not to worries about building hoops/etc this time around for a year or so, at which time i will be moving to a spherical system and probably longer shocks (with john again im sure) but i want to get used to a ifs/irs off road vehicle (used to pre runners) before i get crazytown of isn. anyone got a suggest for tire size on a 15x7 et38 wheel (Off road) hoping to keep it around 200$ each ?
Edited 1 time(s). Last edit at 06/12/2013 09:24PM by liv3mind.
Re: Neub first post
June 12, 2013 10:30PM
So much at one time and I hates typing.. First 7 x 15 is what WRC turbo cars with just a smidge more BHP and maybe a tad more torque use...
Not going to say you shouldn't, this is America where bigger than whats sensible is a Constitutional right, but just because everybody else does something foolish and pointless, does that mean you have to? Big wheels and big fat tires suck up a LOT of power, not to mention gearing you UP maybe 7-8%, which hurts a lot with a relatively mild little motor..
Just going from 62cm tall tires to 65cm tall hurts my little V4--and I have 5.45 final drive and 11.3 or 11.4 compression ...
As for tires, there again nearly everybody uses tires way fatter---and therefore heavier and hurting gearing---more than normal..
Michelins wonderful 14/62 x 15 (14 cm on tread face, 62 cm tall and 15" rim) was developed for 2.0 Group N cars where power was anticpated to be in the 190-200bhp range and standard final drive....that's somewhere in between a 175/70 x 15 and a 185/65 x 15 for outputs around 190-200..
Just sayingsmoking smiley
liv3mind
George Frederick
Re: Neub first post
June 12, 2013 11:04PM
undrstood. yeah just a smidge and a tad hahahaha, thanks for the advice and a back to reality check, im not necessarily wanting to run a massive tire, and im definitely not arguing it being overkill, i was thinking of something in the 185/195/65 range on a 15x7 wouldnt be too huge or too wide. i suppose those sizes could technically be mounted safely to a 15x6 as well, sorry im new to this smaller width wheel and tires numbers game
Re: Neub first post
June 12, 2013 11:14PM
Hey George didya get the email wif the phone number.. My cuppa tea is gone but I still haz ciggies, It's much faster talking.. I am not of the generation the thinks typing is communicating.
RALLYRS
Mike Ball
Re: Neub first post
June 13, 2013 01:51PM
liv3mind
Sounds like he knows his stuff..i'll be watching for updates on your build...
Post up Here:
and here:
RALLYRS
Mike Ball
Re: Neub first post
June 13, 2013 03:01PM
Ok John-I understand the above,and you ALMOST have me talked out of trying 50's.
Now I joke about 'Murica! and BIGGER is better and all,but honestly,I'm not the type who has to have the tallest lift on his 4x4,biggest gat at the shooting range,etc.
Cuz sometimes lighter and more efficient is better...
I just don't want to go afterwards.."Shit..for XX$ more why didn't I upgrade to a beefier unit"(as wrong as that sounds)!
Know what I mean?
When I wanted to buy Braids-I listened to you when you said "go 38mm offset"
So when Paul offered me 15x6's in 38mm i went ahead and bought them.
BUT..so i'm already sticking out-what-12mm more offset from stock..and I'd still need wheel spacers to clear the bigger springs of the 50??...
If so- somehow scrub radius issues(among a few other things)not to mention my wheel bearings would seriously hate me even more than they already do....seeming to be NOT such a good idea when a 40 will do just fine....
Ok..so I understand the push the knuckle down to get the strut in-but do you mean I have to grind crossmember for clearnce to push the arm down more for these,and then weld the grinds back up?
Doesn't sound too "service area" friendly if one was swapping struts in a hurry if so...is there another way-or am I being dense here in understanding you?
So who here IS running the 50's..just curious..how they like them..thanks!
Post up Here:
and here:
liv3mind
George Frederick
Re: Neub first post
June 13, 2013 03:44PM
RALLYRS
Know what I mean?
after spending a good amount of time on the phone with john last night, the 40/41 sounds like it will hold up to ALOT of shit, although if you want the 50's he has some shit going on (testing) that sound bad mutha fckin ass if you can be a little patient, that will solve the tire/wheels clearence issues completely, definately take the time to let him explain it to you.
John im headed to wrecking yard friday to see if i can find a saab 9k wheel and send you some pics of clearences
RALLYRS
Mike Ball
Re: Neub first post
June 14, 2013 03:37PM
[/quote]
John im headed to wrecking yard friday to see if i can find a saab 9k wheel and send you some pics of clearences[/quote]
I've seen some posts here of some struts with funky offset bottoms on them..I think that's what you are probably talking about....and yeah-no rush for me on struts.....
Post up Here:
and here:
