after spending a good amount of time on the phone with john last night, the 40/41 sounds like it will hold up to ALOT of shit, although if you want the 50's he has some shit going on (testing) that sound bad mutha fckin ass if you can be a little patient, that will solve the tire/wheels clearence issues completely, definately take the time to let him explain it to you. John im headed to wrecking yard friday to see if i can find a saab 9k wheel and send you some pics of clearences[/quote] I've seen some posts here of some struts with funky offset bottoms on them..I think that's what you are probably talking about....and yeah-no rush for me on struts.....[/quote] Naw the offset bottom deal is too expensive to pull off in short runs and even combining Xratties and Fucci, that is still short run. The idea is, and we're already in process is to run larger diameter springs like circle track 5 or 5.5 OD springs... Comrade Tony in Czechcago was given assignmenet to look up spring travel for a constant rate as a function of diameter, it confirmed what I "knew' (in my gut) that larger diameter for a given rate means we can get the 190mm travel we want in a shorter spring than the common 14" or the nicer ones I've begun using, the "Long Travel 12" springs" A 10" free length in a 5" ID will be fine.. But now there's the need for making some slip over spring perches to fit over the existing upper and lower registers.. Comrade Sgt Escott in Kenntucky is back from blowing up Afganiac terr'ists and has the set up test big perches that he should be checking out on his Xratty... But don't want to blab too much till we see if something jumps up and bites us in the bum.. In his case he's making a hot road car and wants wide wheels which will want to rub on the springs, on our case its the packaging even if we use sensible 6" wide wheels with ET38 We'll see but I feel we can do it OK at marginal additional cost. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
John Reed John Reed Junior Moderator Location: Portland, Oregon Join Date: 06/09/2012 Age: Possibly Wise Posts: 176 Rally Car: Toyota AE86 |
Except for on the forum! Hahahaha And to the OP, my JVL 40s that John built up for me this past winter have been amazing. Although this is 'Murica so I want a set of the 'fitties now! John Reed John Reed Racing www.johnreedracing.com johnreedracing@gmail.com |
liv3mind George Frederick Elite Moderator Location: Vista, Ca Join Date: 06/12/2013 Age: Settling Down Posts: 11 Rally Car: 2004 Focus SVT 5door |
aj_johnson A.J. Johnson Professional Moderator Location: Pendleton OR Join Date: 01/07/2011 Age: Midlife Crisis Posts: 1,381 Rally Car: 88 Audi 80 |
no and you will have a really tough time finding the saab wheels. The audi 5k FWD and the 90/coupe quattros all run the 4*108 bolt pattern and an et 37 offset on a 15" wheel. Vittorio runs the coupe speedlines and i don't think he is kind to them. I picked up two sets of the 5k wheels for 50$ each set. The speedlines will run you ~200 for a set of 4.
the center bore is off a bit, you can run a small spacer, or take em to your local machine shop and have them punched out a smidge |
http://www.audifans.com/marketplace/show.php?table=pm_audifans_Parts&id=20892
here are a couple for testing... |
Don't forget a bore and chamfer. At least xr rear hubs aren't square shouldered... Grant Hughes |
lol, got bikes on my mind... was thinking what would he be doing with a honda rim??? then it clicked. The foci have a shoulder on the hub? |
I had a set of Compo TH2 that a friend had bought for PPIHC for his Audi S2, but he broke two of them at one race. He sold the car but kept the wheels. Then he started building a Focus and bought two Focus wheels. He owned a mill so bored the Audi pair to the diameter needed for the Focus. He sold the Focus then ended up giving me the wheels in exchange for my codriving duties with him that year. I put them on the Merkur and they were bad ass. Found out though that the Merkur hub is slightly rounded at the face so the wheel he did that didn't have a chamfer would never sit flat or get tight. Lucky I noticed before I
http://nocoastmotorsports.net/Build/Merkur/08Mar15Rear.jpg Grant Hughes |
Such a nice car---put the damn piccie up ![]() 4 extra clicks on the keyboard...sheeesh. Put that thing together and pound it. John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Such a nice car---put the damn piccie up ![]() 4 extra clicks on the keyboard...sheeesh. Put that thing together and pound it.[/quote] That car is sex |
That car is sex[/quote] Isn't it great we can swap Foucus suspention directly ober by just swapping upper mounts on both ends? (nudge nudge , wink wink, knowwhatmean, eh? Know--What--- I ----mean?....a nod's as good a s a wink to a blind horse!) John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
Escort? No point in USA cause a) insanely expensive, b) no advantage Yeah that's a tarted up Xratty. Grant says he's going buy one of these fully rebuilt YB Cosworth motors I have several of laying around.. I am holding my breath. ![]() John Vanlandingham Sleezattle, WA, USA Vive le Prole-le-ralliat www.rallyrace.net/jvab CALL +1 206 431-9696 Remember! Pacific Standard Time is 3 hours behind Eastern Standard Time. |
I might be rejoining the workforce sooner than hoped. If so that will mean more money coming in, but less time to work on stuff. Double edged sword. Gotta finish this thesis first. Still on campus working, mind hurting... Principal variation component analysis is kicking my ass...
Grant Hughes |
