AnthonyLatham
Tony Latham
2015 Subaru WRX
CARS Class Rule Change Proposal
June 27, 2013 01:17AM
So CARS has presented a revised class structure that would keep Group 5 cars out of the Open 4wd class after 2014 AND answer the concerns of the Group 2 competitors who see the Group 5 cars as having an advantage.
Its kind of an elegant solution actually; one based on vehicle weight. At first glance I really think its a smart idea but I would love to hear other's opinions.
-Tony
Here is the link:
http://carsrally.ca/index.php?option=com_content&view=article&id=120%3Abulletin-2013-10-large-displacement-rule-change-proposal&catid=1%3Acars-news&Itemid=14&lang=en
2015 Subaru WRX
Traded the Audi for the above
Sold the 1993 Honda Civic EG w/B16A Conversion to the Raw Racing boys
6 bicycles because, you know, global warming and all
darkknight9
Kirk Coughlin
Dreaming of escorts and xrats
Re: CARS Class Rule Change Proposal
June 27, 2013 02:56AM
AnthonyLatham
I'll get a committee on it straight away.
Kirk Coughlin
AlexeiS
Alexei Stapinski
1991 Suzuki Swift
June 27, 2013 05:53AM
It'll probably piss off both groups, so it sounds like the best fix to me spinning smiley sticking its tongue out
It does sound like the best way, having 2WD cars in Open4WD would have been silly. I'm liking it.
Andrew_Frick
Andrew Frick
Rally Spec Ford Focus
June 27, 2013 08:07AM
I am confused by the displacement limits. It looks like you have stricken the maximum displacement limits but there are limits to the weight categories? The way I read it there is still a displacement limit of 3.2L on NA motors and 2.5L on forced induction motors. Maybe you need a catch all displacement class that has a higher weight penalty. Like above the top line add 500 lbs.
Also, this is more of a general observation. I have never understood why in north american rally car weight does not include the driver / co-driver and their gear. If the goal is competitive weight balance then all items including people should be in the car during an official weigh in. The WRC includes the drivers and co drivers so does most other forms of motorsports. This makes larger / fatter drivers to no be unfairly penalized. Since the car weights are varying by as little as 200 lbs. You could easily get a driver / co-driver pairing that is 100+ lbs different and have all participants still be relatively fit.
June 27, 2013 09:52AM
As a fat man, I agree with Andrew's observations.
June 27, 2013 09:58AM
I see the same as Andrew. You're still regulating max cc at 3200 NA. While it is a step in the right direction (baby step) it still ignores many motors and the trend of manufactures to produce above 3500cc 6cylinders and forced induction in many of those.
I don't know what Nelsons or Hintzs BMWs weigh but adding weight increase stopping distances, reduces tire life, increases road wear, increases cost, increases distance or momentum of a vehicle leaving the roadway. Then you have the added grief of determining how to add weight, where, type of material, how secured etc. Still plenty to think about.
Seriously...G5 isn't a big lop sided for sure win and not every G5 driver is capable of driving one to victory. Massive effort for minimum problem. While I'm a supporter of 2 classes OA I still don't see CARS solution as a viable answer.
June 27, 2013 10:55AM
I got beatup on the first day at Nameless by a non turbo car.....second day we turned the boost down on the car, picked up the pace a bit and got closer in times, but still got beat in my big bad turbo car.....power don't mean shit.
One class: 2wd.
June 27, 2013 11:13AM
Bottom line, I hate all the classes we have, especially the ones that have low entries. I hate seeing all the "We got 1st place in class!!!" except they were a Production car, in a field of 1, who finished dead last in an event.
It's always tough on the G5 vs G2 arguments. Granted, many G5 drivers can't drive worth beans and end up being slower than the G2 guys or their cars are just larger displacement motors. The way I see it, with the regular competition, I wouldn't mind G2/G5 being put together. However, when guys like Doug Shepherd show up in a G5 car they'll put the hurt on the 2WD guys no doubt.
The weight limits are a good start, or at least maybe combine them but keep the adjusted displacement modifiers for turbo (1.7 multiplier) vs NA (1.0 multiplier). However that's not always the case that a 1.7 is right. 100hp/L is pretty good for NA motors that rev high, so my 1.6L B16 makes 160HP, if I slap a turbo on it, I should in theory be pushing out ~272HP by their displacement calculations. Do-able but that's a pretty hot little turbo motor. Even taking a 2.0L motor @ 200hp, at turbo in theory should be pushing 340hp.
So finding that balance to what is within reason could be a challenge but I'd say why not just keep the 1.7 multiplier. Basically, if you want to bulid a turbo motor with a peak HP that can be used on gravel roads and be right on the line of perfect power/weight limit, build a small displacement turbo motor.
The issues with weights (at least when I compare to Rally 'Merica weights) are almost unobtainable on lower displacement cars. My minimum weight on my Civic is legally 1848lbs. There is no way in hell that I can reasonably get there. The other issue from this comes down to regional rally inforcement where having a set of $1000 scales isn't really something that every regional group has and would likely be something that only happens during a concurent regional/nationl event...
Thoughts?
Reamer
Jeff Reamer
Subaru
June 27, 2013 11:18AM
I dont get the max displacement rule but the weight rule is dead on I think. Spewing agruguments about how to mount lead and bring up stop disatance is a joke when 90% of the rallycars competing wiegh more then 2700lbs to 2900lbs. If CARS came up with a wieght of 4000lbs then I would agree. These weights seems close to actual wieght of most large displacement cars no? I say good job!
Can be like Subaru and carry spare parts as ballast. I seen tie rods control arms tools all sorts of spares in Higgins car.
First rally 2013
Rally car type AWD subaru
Total rallies as driver 6
Total rally cars built 2
Total rally cars caged 3
Like 31motorsports on FB!
June 27, 2013 11:24AM
Doug Shepherd would smoke 90% of the 2wd field in a Geo.
June 27, 2013 12:10PM
Forced Induction Engines:
Restricted Induction Up to 2000cc –No Minimum Vehicle Weight
Restricted Induction 2001cc to 2500cc –Vehicle Minimum Weight 2700lbs
Un-Restricted Induction Up to 2500cc –Vehicle Minimum Weight 2900lbs
Does that mean that restrictors are still required for 2wd turbo cars unless they weigh 2900+ lbs?
Edited 1 time(s). Last edit at 06/27/2013 12:10PM by Carl S.
June 27, 2013 12:37PM
Except he's wrong..
FIA weights is with oil, water.
Re the important things:
12.6.2.1 Engine Displacement and weight.
Vehicles must meet the following minimum weight, dependant on the engine displacement and use of forced induction.
Naturally Aspirated Engines:
Up to 2500cc –No Minimum Vehicle Weight
2501cc to 3200cc –Vehicle Minimum Weight 2700lbs
A) Restricted Induction Up to 2000cc –No Minimum Vehicle Weight
cool smiley Restricted Induction 2001cc to 2500cc –Vehicle Minimum Weight 2700lbs
C)Un-Restricted Induction Up to 2500cc –Vehicle Minimum Weight 2900lbs
Logically if one is making options--fair options---there should be some consistency.
Normally in thinking its almost natural to think--If this, then that and if THAT, then this'
So once the idea of weights is breached it makes sense that there's SOMETHING stated--so those that have to meet some weight feel the weight things is applied fairly...
And since there IS under A) a restricted up to 2000cc
and a "retricted/unrestricted" dialectic for the 2001cc to 2500cc
There should be a "restricted/unrestricted " pairing for the up to 2000cc pairing
Thus:
Restricted 2000 max..........................whatever 2300
Unrestricted 2000 max..........................whatever 2500
Restricted 2500 max..........................2700
Unrestricted 2500 max..........................2900 pounds (pounds? poids? Que?)
The steps are really rather coarse 500cc is 25% the volume of a 2.0 motor, and 25% is a lot. especially considering the sheer numbers of popular 2300cc motors and the rarity of actual 2.5s
The progression seems obvious in the above--when its presented that clearly..
And of course there is the obvious fairness principle of
"Open is open so if one open class gets 34mm Restrictor, then logically the other open class gets 34mm and cannot have less without logically justified reasons" and since there are no logical reasons ---
what's good for the one Open class must be good for the other Open class
That was unaddressed as far as I could read an dit should be clearly stated: whatever Lola wants, Lola gets--uh Good for the goose, good for the gander.
One for all and all for one.
Note: Bulletins really don't need the trick semi transparent graphics that are mainly black, kill the computer-nerds that have to show their creativity. kill them and burn their bodies. It is the words we need to see, if i want to look at a pretty piccie , I'll look at a pretty piccie.
AnthonyLatham
Tony Latham
2015 Subaru WRX
June 27, 2013 01:38PM
For me this was really the heart of the issue. We needed a class that would help produce more Doug Shepard-like drivers and I believe we now have it in Canada.
HUZHAAA!!!
2015 Subaru WRX
June 27, 2013 01:48PM
AnthonyLatham
For me this was really the heart of the issue. We needed a class that would help produce more Doug Shepard-like drivers and I believe we now have it in Canada even though it's competely removed from the reality of the automotive enthusiast industry.
Ha.
June 27, 2013 02:08PM
AnthonyLatham
HUZHAAA!!!
Tavarich Lathamski you are a Structualist! The structure does not produce above ordinary results. That comes from inside the individual. The structure (organisation) give the person with the drive a tableau on which he can carry out his art.
The thinking that other people by manipulating rules and regulations can "spark" something inside Joe Blow's skull is wrong thinking...
The question you are grappling with is where are the people that want to test themselves and have the drive to stick with the sport long enough to accumulate enough experience to do well...
Obviously, with the shift in who is mainly in the sport to the current mainly desk-bound, white collar , more than average affluence type people, we have seen a shift from emphasis on "doing" to the dominant social model of "consumption".
And the problem of finding MORE people with internal "drive" and "grit" is now far harder....
This is the heart of the question is many areas including schooling of our children..
Very fundamental differences in how different people regard and approach challenges and uncertainty.
And this dichotomy is reflected in "real world" things like the increasingly polarized politics in both my country and yours.
Serious shit.
