Re: Should I care what my camber is?
July 22, 2013 02:00PM
we ran camber bolts up front on the impreza for the tarmac at ESPR. didn't have any problems. wouldn't do it (not needed) on gravel.
Edited 1 time(s). Last edit at 07/22/2013 02:17PM by KTurner.
Jard
Jared Lantzy
Free range navigator
July 22, 2013 02:05PM
Hmmm...I was wrong. The rears are supposed to have the washers and the fronts just use regular Subaru camber bolts.
http://www.dmsnorthamerica.com/PDF/2f%20-%20Alignment%20Washers%20Setup.pdf
http://www.dmsnorthamerica.com/#/support
The owner's manual also has the recommended alignment settings for various surfaces.
Edited 1 time(s). Last edit at 07/22/2013 02:07PM by Jard.
imnotcrazy
Don Kennedy
Impreza
July 22, 2013 07:59PM
That must be new. Mine don't have that (original ones bought in 2000. Used ones I bought from Calif don't either).
Don Kennedy
krisdahl
Kris Dahl
Integra, Civic
July 22, 2013 08:24PM
3 degrees is quite a bit, but I'm not sure I'd bother to take it out.
Would be nice to fix the rear.
I'm not sure if you'd even be able to notice the difference though.
A1337STI
Alex Rademacher
93 GC with an 01 RS swap!
July 24, 2013 12:25PM
Go with something like -1.5 front, -1 rear. for camber.
if you've done less than 10 rallies, you should go with 0 toe all around or maybe even a little toe in. setup the car to understeer "In steady state" (on the dirt)
Steady state means driving in a big circle as gentle as can be. as you slowly , gently increase speed you want the front end to wash out.
even if a car understeers in the steady state you should be able to make it drift (oversteer) with weight transfer, if you can't yet, work on that.
if you setup your rally car well it should start to suck a bit at rally cross. if you have an ideal rally cross setup, then its wrong for stage. smiling smiley rally cross requires a car that over steers @ steady state, and one that is very finicky (toe out front and maybe rear too, or a big rear sway, or both)
Dan McGinn
July 31, 2013 02:50PM
That's my old car Tim. Check the strut mounts, we had to swap that left rear during service at NEFR (before you bought the car) with some piece of shit NAPA part we picked up in Rumford. I bet that's the issue. Also, change your tie rods, ball joints and wheel bearings, if you did RNY and NEFR, they are due for it.
-Dan
TronDD
Tim Meunier
96 Subaru Impreza
July 31, 2013 08:49PM
Yeah, after NEFR, I need a full suspension rebuild.
Tim.
July 31, 2013 09:39PM
TronDD
Tim.
What do you have on that blue thang?
July 31, 2013 10:20PM
TronDD
Tim.
But, but, but...I thought NEFR was going to have glass-smooth roads this year?
Something something Cold Bits?
Dan McGinn
August 01, 2013 07:24AM
TronDD
Tim.
Should still be DMS 50mm
TronDD
Tim Meunier
96 Subaru Impreza
August 02, 2013 07:18PM
Yup. The rest is stock. Not sure the maintenance history on the DMS stuff, so I'll send 'em out for a full rebuild. I have grpN rubber to put in the front. Need to do something for the rear. Tubular with rod ends, or is that weaker?
Tim.
TronDD
Tim Meunier
96 Subaru Impreza
August 20, 2013 07:52PM
Turns out the front struts have both, slotted holes AND camber bolts. Don't know if it was really at the limit of adjustment or if the shop didn't check what they working with.
We'll see when it goes back together.
Still trying to get rear apart. The long bolts through the bottom are being stubborn. Strut mounts looked fine so I still haven't found the cause of the positive camber. Gotta get the arms off...
Tim.
