Iowa999
no-one of consequence
Re: medium-locking rear diff on gravel
November 19, 2013 02:44PM
TRF
November 19, 2013 05:12PM
Iowa999
Squeaking tires aren't the issue, since no-one would be able to hear them over the brakes, anyway. But you're close. The problem is that, if you have an MZ, you must discard the yaw control. If you have an RS, you can keep it (and program around it on gravel).
Why would you lose yaw control?
Iowa999
November 19, 2013 05:14PM
In a nutshell (translation: from what I understand, which isn't complete), if the AYC is asked to "fight" against a diff that locks as hard as an MZ, the clutches will be chewed up very quickly. The most that they can be asked to work with (or against, depending on your point of view) is an RS.
