Matt Bobyn
Matt Bobyn
VW GTi
Running a welder off a generator
November 20, 2013 10:03PM
Is this possible? Google has turned up conflicting opinions and lots of "I did it back in '82, worked fine." sorta stuff. I'd like the ability to weld during service, but I've never owned or even used a generator and am not well versed in sine waves and electrical black magic and that sort of stuff.
So, I've got a small Lincoln 120v welder, its a Weldpak 140 I believe. It works off a standard 15amp household breaker, with the odd breaker pop when its turned up. The only other requirement is that the generator is portable; we don't have a truck to install it in or something like that.
And no, we can't just get a welder/gen combo or whatever their proper name is; for the welding I do I don't need two...
Thanks!
Re: Running a welder off a generator
November 20, 2013 10:13PM
Yes, you can absolutely run a welder off of a generator.
I've never done it...
I wouldn't know how to do it...
but I've seen it at least twice so I know it's commonly done.
(In fact, one of those times it was done to the car I was driving, and we borrowed the welder, so it must have been a reasonably portable generator that ran it.)
MattP
Matt Pullen
2002 Ford StRanger
November 20, 2013 10:22PM
Being a sparky, my only recommendation is to get the genset grounded before you start welding and use a good sized gen to begin with
Yes, it's a Ranger.
Xr4Ti, it is rwd and was made in Germany.
deaner
Dane Aura
PS4 controller
November 20, 2013 10:29PM
Yeah you can. I don't know any numbers of watts per voltage or any of that nonsense though, sorry. When I get around to getting a small, portable wire feed, it'll be powered off of 5-7k watt gen. More than likely overkill for a lil welder but will double as an emergency generator for the house and whatnot. I think snap on or someone makes a battery/rechargeable flux welder. Had a pretty decent duty cycle from what I can remember. The off road guys I ran with in MT ate em up vs using the battery to stick weld shit back together on the trail.
Edited 1 time(s). Last edit at 11/20/2013 10:30PM by deaner.
HiTempguy
2002 Subaru WRX STi
November 20, 2013 10:49PM
A huge issue with welders (especially if they are run off 120v) is they typically aren't supplied with enough juice. I'd strongly recommend at least 4000w's and a 30amp outlet (which will be pretty rare for a single outlet on a generator to supply). The problem is the larger you go with the generator, the harder it is to haul around, the louder it is (not to name any names of a service crew at PFR, but they put their generator behind their trailer so it wouldn't bother them. IT WAS DEAFENING to the rest of the service park), the more expensive it is, etc. And without the proper amount of POWA, you will end up with shitty welds... not that that might be an issue if the difference between you finishing is having the car in two pieces or one. I weld by the pound so take my advice for what its worth lol.
zerodegreec
Oh look, waffles....
see you on the stages
November 20, 2013 10:51PM
A few things to think about. The older mig welders and Arc welders were allot more resilient to low or questionable supply voltage (like you get out of cheaper generators). New Migs (like Yours) do a really good job of keeping a consistent arc and make welding allot easier. Most of the new Mig welders have a regulated supply via electronics. I have had a small Mig flake out and "reset" (power down and back on again) when using it on a smallish generator (although I had a 120' cord causing more issues). The issue was the generator was not able to prevent the voltage from dropping too low when I struck the arc. The supply voltage dropped faster than the generator could react to. The fix was to shorten the cord and crank the little generator to high (had an adjustable idle). My advise is to buy a good quality generator and look for one that can supply a higher wattage than the welder requires. Personally I would not look at a generator that can provide at least 15% more than the largest "tool" you plan to use with it. For example your welder is ~2400Watt at max output. Look for a generator that will give you 3000W.
Not saying that you cant run it off a smaller machine, just don't expect to get the max thickness out of your welder.
And Adam that could have only been Wims generator at PFR. Ken Block Jr as its affectionatly nick named due to its consistent fire breathing antics. Voice your concerns to the dutchman smiling smiley
See you at Big White?
Bryan
Intercom and electronics dude. www.zerodegreec.ca
Edited 1 time(s). Last edit at 11/20/2013 10:54PM by zerodegreec.
Matt Bobyn
Matt Bobyn
VW GTi
November 20, 2013 11:28PM
Thanks for all the responses! I figured a 3000W was the smallest I could get away with. I've been perusing Kijiji to find a used one, now I know what I actually need. I'll have to search and see if any models come with anything higher than a 15amp circuit.
Good to know this will actually work - theres been a couple times where a generator would of come in handy.
Any no Big White for us - just hitting two events in a month was tough, with the car down in Calgary and me up in Edmonton its just too much driving on my days off. Gotta spend some time with the girl right? Or at least she says so.... smiling smiley
November 20, 2013 11:50PM
Ohms law. Volt x amp = watt . Give yourself some leeway with the wattage. 4000w should be fine for a 120v welder
November 21, 2013 12:04AM
(Deleted)
Edited 1 time(s). Last edit at 11/21/2013 12:13AM by Morison.
November 21, 2013 06:19AM
used to HAVE to run my old mig from a generator because the wiring to the garage was shit and couldn't supply enough current.
markhuebbe
Mark Huebbe
1970 VW Beetle (Historic)
November 21, 2013 09:24AM
I once welded my cracked exhaust headed back together at Ojibwe 2011 using my Hobart 140 110v and a borrowed generator. The generator looked like one of the cheapo HF specials, but probably 3000W.
http://www.huebberally.com
tdrrally
edward mucklow
November 21, 2013 10:36AM
i have seen hundreds of welders run on generators
from the local dirt tracks to road courses to desert racers to oil and gas field service trucks and army welders under fire sticking things back together
in that groupe all brand of welders and some homemade units too
November 21, 2013 11:07AM
HiTempguy
I have told people to shut off their generators at service before. No one minds generators going for 20 minutes while you're welding or wrenching. Leave that shit running all day and making noise and that's just not cool.
tdrrally
edward mucklow
November 21, 2013 04:19PM
that's why they make batteries
November 26, 2013 03:52PM
I have MIG welded when running on my generator. Fairly big MIG using 220v 5500 watt gen. No problem.
Our job sites are full of MIG/Generator combo units that only run on gas...
