Time to cut that out!
Posted by NoCoast
Re: Time to cut that out!
January 18, 2014 02:37PM
It's subject to the discretion of the scrutineer. I see cars all the time with cages whose welding isn't beautiful but is passable. No one submits welding samples and clearly no one's going to cut apart a cage to test, so it's just a visual check. And yeah, everyone knows you can't tell if it's a good weld, just if it's a good-looking weld. But can catch a lot of bad and incomplete welds. And undercut welds. And crushed tubing. And poor fits. And so on.
Bolt-in cages are allowed both for R-A and NRS. There're rules for making the backing plates and mounting feet and the bolts - see App J Art 253.
Robert Culbertson
Out of this dumpster fire
January 18, 2014 03:13PM
You learn something new every day. I can definitely see the reason for good backing plates and mounting feet!
January 18, 2014 07:10PM
Wow.... This is my favorite. The intersecting tube isnt really welded to the
junction..http://www.mouthbreather.net/chriscage/PS_RT_AFT_VIEW3.JPG
Creech
Scott Creech
Audi 90 Quattro (WIP)
January 18, 2014 09:13PM
junction..
I like how they did not even knock the slag off the plate from the torch-cut.
Honorable Mention to the whiskers, inclusions, and bug-holes in the weld to the lower-right....
I am:
I know:
I am from:
Nobody.
Nothing.
Nowhere.
Mad Matt F
Matt Follett
January 18, 2014 09:38PM
that has to be a case of multiple folks welding same cage...
one ok bead, then "here you finish this up, I'm getting a beer"
Edited 2 time(s). Last edit at 01/19/2014 10:03AM by Mad Matt F.
January 18, 2014 10:50PM
Really funny that the vertical plate isn't even welded to the shock tower! Why even bother....
